07-01-2024, 11:26 AM | #3213 |
Rep 2
Hey guys,
Love this thread. My M2 that’s fun to drive and looks great. |
07-01-2024, 12:59 PM | #3214 |
Rep 296
Installed the SST Valve controller yesterday. At WOT I can't tell much difference between Sport+ and Sport+ with valves 100% open. The mid-pipe made a much bigger difference there. But I can tell a big difference in normal driving and lower RPMs. I think it's because the valves were normally much more closed in these instances and are now 100% open.
07-01-2024, 01:09 PM | #3215 |
Rep 73
I'm in the same boat as you. I want to buy the cross-over pipe but I'm afraid it won't do anything (other than slightly improve exhaust flow). I'm skeptical about people saying it improves sound because it could be a placebo. I wish ER (or anyone) would take a stock exhaust G87 and just replace the crossover pipe to see if there are any noticeable differences in sound and/or power.
07-01-2024, 08:24 PM | #3216 |
Rep 86
07-01-2024, 08:28 PM | #3217 |
Rep 832
Drives: M2 G87 Brooklyn Grey
07-04-2024, 03:22 PM | #3218 |
Rep 74
Today my car got lowered (KW Has), with spacers, 12.5mm front and 15mm rear. Shop said that with 15mm spacer in front it would rub… (I asked for 15/12.5). They did not swap my spoiler with the CS one, afraid to damage my frozen paint 😐.
A bummer cause I was looking forward to it. |
13
LAGWAGN668.00 gondolafanclub421.50 JMcLellan2919.00 Baller203.00 Cefoskey565.50 bmwimsafan28.00 Frank414.50 DarkNight707980.50 Zaskar96.00 daddyjaxx116.50 richardm02257.50 mrdudley599.50 Kevin_The_Clean14525.50 |
07-04-2024, 04:41 PM | #3219 | |
Rep 1,715
2020 X5M Competition
2024 M2- Sold 2019 M240i- Sold |
G87DRVR123.50 |
07-04-2024, 09:49 PM | #3220 | |
Rep 101
Drives: 2024 BMW M2
Also, the spoiler removal on frozen paint just takes more time and you cant really safely use a 3M stripe wheel. Just copious amounts of goo-gone solvent and meticulous use of paper towels and microfiber.
2024 G87.............| FGM | 6MT
1988 944.............| ZSM | 5MT 2006 355 Z71......| Red | 5MT |
07-05-2024, 03:41 AM | #3221 | |
Rep 74
Did you remove your spoiler with fishing wire? Why did you use paper towels? To wipe the gunk? |
07-05-2024, 09:13 AM | #3222 |
Rep 138
Are you at the 10mm port install drop?
07-05-2024, 09:39 AM | #3223 | |
Rep 101
Drives: 2024 BMW M2
I removed the lip with a heat gun very slowly, using tape wrapped pry tools and fishing line to get the ends up, then gently pulled while heating the rest of the span. Then you lay paper towel over area and let them absorb and soak goof off spray keeping it on the remnant adhesive. Once the solvent soaks it sufficiently, you can start to gently wipe the adhesive off with more paper towels or microfiber. Just a matter of being slow and letting the chemical do the work.
deleted_807865_k0a0df9ee6876.00 |
07-05-2024, 10:07 AM | #3224 |
Rep 1,715
Yes. It's set to the port install drop. 15mm front and 18mm rear spacers.
07-05-2024, 10:49 AM | #3225 |
Commander-In-Chief
2419
Rep 9,044
15mm front does not rub with stock tires. I ran 15F/12R before new wheels.
G87DRVR123.50 |
07-05-2024, 12:33 PM | #3226 |
Rep 3,863
07-05-2024, 01:53 PM | #3227 |
Rep 183
Fresh wash and Reload application yesterday. Break-in service completed today.
BroDoze2333.50 gondolafanclub421.50 |
07-05-2024, 02:02 PM | #3228 |
Rep 832
Took advantage of parents easy hose access and washed the car. Finished ordering parts and now just waiting for wheels. HAS arrives today.
07-05-2024, 02:56 PM | #3229 |
Rep 175
07-05-2024, 11:36 PM | #3230 |
Rep 101
Drives: 2024 BMW M2
After today, no more rubbing in reverse.
07-06-2024, 12:24 PM | #3233 |
Rep 101
Drives: 2024 BMW M2
special delivery
