      08-26-2024, 07:51 PM   #3543
rk95
rk95's Avatar
Drives: BMW M4
Originally Posted by daddyjaxx View Post
I replaced the OEM shifter rear carrier bushing with Rogue Engineering's upgraded bushing. I put the car on jack stands and wiggled myself under it. I pulled back the heat shield just enough to get some working space. 2 screws are holding the stock bushing in place and take an 8mm socket. I used a flexible socket extender to get to the bolts. I was extremely careful not to drop the screws because they would have fallen behind the drivetrain heatshield. I just took my time. I used long needle nose pliers to wiggle the stock bushing off the shift fork. Then, I wiggled the RE bushing on and tightened down the bolts.
The shifts are smoother and less notchy. The lever glides into gear now. This upgrade has significantly reduced the binding feel when shifting into first and second. Overall, gear changes now feel more sturdy and polished.
The notched feeling from 1-2 does bother me as well. This seems like a great mod
      08-27-2024, 11:56 AM   #3544
daddyjaxx
daddyjaxx's Avatar
117
Drives: 2024 G87 6MT
Originally Posted by mrdudley View Post
How long did this take you?
It takes about an hour or so, depending on how good you are with your hands in tight spaces.
      08-27-2024, 11:58 AM   #3545
NewToM
NewToM's Avatar
Drives: M2 G87 Brooklyn Grey
2024 BMW M2 G87  [9.53]
Based upon my wife’s feedback this would take me days…
Appreciate 12
daddyjaxx116.50
BradMX5523.00
Cefoskey565.50
JMcLellan2919.00
mrdudley599.50
apez841.00
LAGWAGN668.00
BmwIowa251.00
xtougher788.00
      08-27-2024, 12:02 PM   #3546
daddyjaxx
daddyjaxx's Avatar
117
Originally Posted by Cefoskey View Post
Did you skip the delrin front bushings? I thought these were only sold as a kit with the rear carrier and front bushings.
You can buy the rear carrier bushing and front bushings separately. I skipped the front bushings because you have to remove the shift fork to install them. To get the shift fork out, you have to drop the trans a little, and I didn't think it was worth it. The ideal time to install the front bushings is when you install an SSK.
      08-27-2024, 12:23 PM   #3547
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
My BBS LM limited edition black w/blue flakes are going in for refinishing tomorrow for a completely new look. I am sick of how the black just blends in. It’s time for some real bling!
Should be done by Bimmerinvasion LA. My car will be on display at Cencal booth if anyone wants to slide by and say hi.
Will also be paint matching an R44 rear lid spoiler (won’t be done by bimmerinvasion).
      08-27-2024, 12:26 PM   #3548
BradMX5
BradMX5's Avatar
523
Drives: 2019 MX5
Impatiently waiting for pics
      08-27-2024, 07:24 PM   #3549
it.g.ma_g87
Senpai
it.g.ma_g87's Avatar
Drives: 24' M2
RK Titanium intakes and strut bars in a custom finish to match my brushed light gold LM. Gonna complete this weak ass engine bay. The cover is AW with gold flake
IG: it.g.ma_g87
      08-27-2024, 08:48 PM   #3550
mrdudley
mrdudley's Avatar
Drives: BMW X3 M40i
Hands in tight spaces, not a problem. But I am fantastically skilled at dropping screws I’m not supposed to drop.
NewToM1749.00
apez841.00
daddyjaxx116.50
      08-27-2024, 10:54 PM   #3551
mdrobc13
mdrobc13's Avatar
451
Drives: Made in Bavaria or nearby
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Originally Posted by NewToM View Post
Just picked it up from EAS.
. Nice what front spoiler is that? Looks good.
'23 BMW M2 (Z. Blue/black) - weekender, '22 BMW M4 Comp (SSG/Black) - gone, '16 BMW M4 (Shakir Orange/Black) - gone, '15 BMW M3 (Black/Black) - gone not forgotten,'10 BMW X5M (Black/Black) - gone not forgotten,'08 BMW M3 (Space Gray/Black) - gone, '03 BMW M3 (Black/Black)
      08-27-2024, 11:07 PM   #3552
NewToM
NewToM's Avatar
Stradale Design. Have had it on for a bit with no complaints.
https://www.stradaledesign.com/g87-m...gts-lip-g87-m2
mrdudley599.50
      08-29-2024, 06:24 PM   #3553
rk95
rk95's Avatar
Drives: BMW M4
Anyone have the AA EL non res midpipe fitted to the MAD exhaust? MAD has a good Labor Day deal going on rn and am considering the exhaust.
      08-29-2024, 06:41 PM   #3554
mrdudley
mrdudley's Avatar
Drives: BMW X3 M40i
Would also be interested in hearing what folks have to say about this combo (though I have the AA single). I’m afraid cold start will be thunderous.
      08-29-2024, 06:55 PM   #3555
BradMX5
BradMX5's Avatar
523
Drives: 2019 MX5
Only one that need to be afraid are your neighbors
mrdudley599.50
      08-29-2024, 07:02 PM   #3556
Southtown
Southtown's Avatar
541
I’ll let you know after next Friday
mrdudley599.50
rk95436.50
      08-29-2024, 07:50 PM   #3557
rk95
rk95's Avatar
Drives: BMW M4
Please do! Do you currently have the AA EL on the car? Would be great to get the comparison of that currently versus the EL + exhaust.
      08-29-2024, 08:08 PM   #3558
Southtown
Southtown's Avatar
541
Currently have the AA equal length and evolution racewerks cross over pipe. The MAD axle back will be here tomorrow. Then putting it on the next Friday. Also I have a SST valve controller. So I’ll see how bad cold starts are with it fully closed.
      08-29-2024, 08:33 PM   #3559
Newgenbimmer
Newgenbimmer's Avatar
Drives: BMW M2
A little Kies action!
      08-29-2024, 09:05 PM   #3560
Cefoskey
Cefoskey's Avatar
566
Drives: 2024 BMW M2
1998 Porsche 944  [10.00]
2024 BMW G87 M2  [10.00]
Does this setup on G87 require a ton of trimming on the plastic seal trim covers at each end? G80/82 look very different in that area.
2024 G87.............| FGM | 6MT
1988 944.............| ZSM | 5MT
2006 355 Z71......| Red | 5MT
      08-29-2024, 09:36 PM   #3561
Newgenbimmer
Drives: BMW M2
Not 100 percent sure as I am installing this weekend.Its possible that the black tie in brackets that sit on each strut tower may require some trimming.
      08-31-2024, 12:39 PM   #3562
RussV
Drives: 2024 BMW M2
Got mine yesterday
      08-31-2024, 09:22 PM   #3563
AZG87
Drives: G87, 2018 Mustang GT traded in
I wouldn't expect it to be bad with stock dp. Cold start with valves closed if needed.
I have the AA EL mid but oem axleback for now. Cold start valves closed is still quiet, valves open is much louder obviously, but nothing compared to my last car with long tubes on a v8 lol.
      08-31-2024, 09:33 PM   #3564
M_Power Rob
Drives: '23 M240 and '23 M2
Yeah, no matter what the setup, its an inline 6...I wouldn't call it "thunderous" under any circumstances.
I have highflow catted downpipes, catback exhaust with valves open on a tuned ecu and it's still not that obnoxious (in my parking garage at work, there is a Tesla that parks behind me and if it's there when I leave, I do set off it's alarm...then again its a Tesla so I am not that concerned).
