      02-04-2024, 01:25 PM   #2047
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Originally Posted by Kevin_The_Clean1 View Post
This makes complete sense. They've also done some interesting but reasonable things to other M cars. My X3 M for example (that has been lowered on DINAN springs) can only achieve 1.2* of negative camber in the left / passenger side front. But the right / driver's side front can achieve the full 1.5* of negative camber. [this is not adjustable on many cars] It's not ideal but been confirmed with other X3 M owners that this was built into the existing chassis. I guess for the crown in the road maybe. I know this is close to comparing apples to oranges here. But I think there's some similarities in regards to the thoughts behinds these basic measures BMW took to offset & counter balance some things.
It’s interesting how BMW does things like this. I honestly would have never noticed unless I did the finger test and measured. I’m not upset as when I sit in it it’s completely level now due to weight distribution and probably same applies to your X3 M with the camber. Glad BMW M Performance team thinks of these things.
      02-04-2024, 01:47 PM   #2048
AZG87
Drives: G87, 2018 Mustang GT traded in
Originally Posted by ScottyRyan2019 View Post
I had 305/35/20 on my Mooostang
Had a MY18 s550 before the g87. Ran 315/35 Nitto 555r2 on the rear 20x11. Could hook even when running e85 and had cooler weather. Good setup.
      02-04-2024, 06:21 PM   #2049
ScottyRyan2019
Licensed Professional Slacker
ScottyRyan2019's Avatar
Drives: 2024 M2 and 2025 i4 M50
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
I was running a Wengerd E85 tune. My biggest complaint ( and it's not a very big complaint) of my 2022 10R80 was light throttle transmission response. With those 10 gears it could get a little finicky at times during cold operation or light throttle. Medium to WOT it was a great trans. I was speaking with a tuner before I decided to sell it and get this G87 and he said he had the trans shift tables from the 2024 which could be brought into the S550 and it makes a world of difference from what he said. In an event, I'll miss the car as it was fun to drive and good quality, but I'm REALLY LIKING this M2👍
2024 M2 and 2023 Mazda CX-30
AZG871304.00
      02-05-2024, 09:22 AM   #2050
JMcLellan
JMcLellan's Avatar
2919
Drives: 2020 X5M Comp
Originally Posted by rons e92 View Post
Pulled the ECU out of the car and dropped it off at DHL. It's time for some ethanol.
Have folks determined yet what type of mix is allowable with the stock fuel pump?
2020 X5M Competition
2024 M2- Sold
2019 M240i- Sold
      02-05-2024, 09:29 AM   #2051
rons e92
60-130 Enthusiast
rons e92's Avatar
GTP is setting me up with a flex fuel map and an e40 kill map. I've heard of people pushing e60 with the stock fuel system and no port injection, but I don't know too much about that. Hoping to learn as I go.
In the summer we'll change out the LPFP and add a CSF intake manifold and PI and see what we can do.
JMcLellan2919.00
      02-05-2024, 11:15 AM   #2052
M2 CCO
M2 CCO's Avatar
Drives: 2024 M2
2024 BMW M2  [9.00]
Coded out the active sound design. Car sounds much more natural inside the cabin now with my full cat back exhaust and music seems to sound better as well. May just be placebo, but I’m going with it.
      02-05-2024, 12:05 PM   #2053
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Interested as to how you did that?! I bet the Eisenmann you have sounds even more luxurious now.
M2 CCO1383.00
      02-05-2024, 02:52 PM   #2054
MineralGreyMetallic
MineralGreyMetallic's Avatar
1114
Drives: 24 BGM M2 6MT
I saw a few posts a while back that said it wasn't possible to code out in the G87.
How did you do it?
      02-05-2024, 03:32 PM   #2055
DailyDownshift
Battle Tactician
DailyDownshift's Avatar
Drives: TR G87
Hey what did you use for this? I assume you used bimmerlink, how much did it cost? Thnx
YouTube & IG: @Dailydownshift
Current: TR G87 Stick
Previous: LBB 16' M2 | 20' Corvette C8 | AW 18' M2 | AW 20' M2c |
      02-05-2024, 03:33 PM   #2056
DailyDownshift
Battle Tactician
Drives: TR G87
Just placed my order for the TFL Italy fully catback system!! Super excited, hopefully it's here within a week or two!
      02-05-2024, 03:36 PM   #2057
M2 CCO
M2 CCO's Avatar
Drives: 2024 M2
2024 BMW M2  [9.00]
BimmerCode. Had to turn it to non active as well as deactivate the code. I followed the prompts it gives you in order to make sure it’s fully off. I heard the speakers cycle when I deactivated the code in the second step. Sounded a bit like unplugging an instrument from amp IMO.
Edit: used the M3 vehicle designation also
      02-05-2024, 03:46 PM   #2058
M2 CCO
M2 CCO's Avatar
Drives: 2024 M2
2024 BMW M2  [9.00]
Oh yeah I’m loving it even more with ASD off!
      02-05-2024, 10:18 PM   #2059
JABCAT
Professor
JABCAT's Avatar
4850
My Corvette is the same with the driver side just slightly higher than the passenger side. The Corvette has height adjustment bolts though so making changes to ride height is fairly simple.
Geighty72779.50
      02-06-2024, 09:21 AM   #2060
JMcLellan
JMcLellan's Avatar
2919
Every day brings a new learning and observation for me. I programmed the settings for my M1 and M2 buttons. I basically put all settings into Sport for M1, then for M2 everything is Sport except for the Engine and Chassis which I set to Sport Plus.
Anyone else notice that the exhaust note in Sport plus is louder than in Sport? Is that just the cabin noise changing or is the exhaust actually louder? I haven't had a chance to test with someone else behind the car yet.
2024 M2- Sold
2019 M240i- Sold
AZG871304.00
Geighty72779.50
      02-06-2024, 09:47 AM   #2061
AZG87
Sport + is more pronounced especially with the trans in d3. Of course this combo really woke up adding the AA EL mid.
JMcLellan2919.00
Geighty72779.50
Resoelg328.00
      02-06-2024, 09:58 AM   #2062
JMcLellan
JMcLellan's Avatar
2919
Cool, thank you. So many options with these cars. I may just disconnect the exhaust valve control and affix the valve open so I don't have to be in sport or sport+ for all the sounds. But maybe it isn't that simple with these cars.
2024 M2- Sold
2019 M240i- Sold
      02-06-2024, 11:44 AM   #2063
CadolinaRipr
CadolinaRipr's Avatar
446
Drives: BMW M2
It definitely is that simple to fix the valve open with wire or pull the fuse, but I like to be able to control it. I highly recommend the SST controller. Hit up mike@x-ph.com if you're interested. I love mine.
AZG871304.00
JMcLellan2919.00
      02-06-2024, 11:53 AM   #2064
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
I’ll raise you a CANflap from Awron and really wake her up lol. The AA EL is my favorite component made for this car besides a pair of front bushing conversions.
AZG871304.00
JMcLellan2919.00
      02-06-2024, 11:56 AM   #2065
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
+1 for SST , its a simple install, reasonable price and its got all the features you will need.
You can 1-keep the valves open, 2- keep them closed, 3- keep them stock 4- set them at 50%
you also can program your mirror buttons to control the valves on the fly.
https://x-ph.com/sale/
Phone number 702-494-9435
      02-06-2024, 11:58 AM   #2066
AZG87
Awron controller also an option to maintain in car button control instead of separate remote. Not sure if Mike carries them yet but definitely go with him if he does.
Geighty72779.50
      02-06-2024, 11:59 AM   #2067
AZG87
Beat me to this as a controller option suggestion!
Geighty72779.50
      02-06-2024, 12:01 PM   #2068
mike@x-ph.com
We don't offer Awron, It's an excellent product as well.
Given the price difference between the 2, its a personal preference on whether customers believe this extra feature is worth it.
Regardless of which controller they choose, I'm confident they won't regret the decision
