02-29-2024, 12:05 PM | #2399 | |
Licensed Professional Slacker
1924
Rep 1,104
Drives: 2024 M2 and 2025 i4 M50
I took that pic right after I took the wheels off. I have blocks sitting off to the side to rest it on if need be, but that brings up a point. I am using jack pads and the floor jacks to lift it at the lifting points. Where does one place the blocks or jack stands? Can they be placed near the lifting points on the "frame rail" for lack of a better term? Thanks 👍
2024 M2 and 2023 Mazda CX-30
MineralGreyMetallic1114.50 |
02-29-2024, 12:07 PM | #2400 | |
1924
Rep 1,104
DSTR1480.00 |
02-29-2024, 12:24 PM | #2402 | |
Rep 80
The front jack point is fairly obvious, but I'm not sure about the rear jack point. I think you use the rear diff. Can anyone confirm that they've done that? |
02-29-2024, 12:28 PM | #2403 | |
1924
Rep 1,104
When the tire shop did my new tires they just used four floor jacks and jack pads using each lifting point. Car sat on those floor jacks for over an hour.
02-29-2024, 12:38 PM | #2404 |
this is the way
20508
Rep 9,063
02-29-2024, 01:20 PM | #2405 |
1924
Rep 1,104
02-29-2024, 01:51 PM | #2406 |
Rep 97
You have any pictures of the 12/12? I was thinking about doing the same thing when my car arrives.
02-29-2024, 01:56 PM | #2407 |
1924
Rep 1,104
I shall post once I have them on but remember my rear tires are 295/30/20 so they will poke a bit more than stock with the same spacer.
Lost2385.50 |
02-29-2024, 05:38 PM | #2408 |
1924
Rep 1,104
Got the passenger side done. Time consuming but it went well.
Took the wheels off, washed them, iron remover and degreased along with calipers. Final cleaning with IPA diluted to approx 18%. I used Armour Wheel ceramic which went on easy. Put two coats on. They look amazing and feel super slick. Put the 12mm spacers on and had the kid help because my alignment pins had not shown up yet. PITA to line up the wheel and spacer without help. I'm happy with the 12/12 especially with the 295/30/20 rears. I would have definitely gone 15mm rear with the stock 285/30/20. As for fronts the 12 mm with the stock 275/35/19 is fine for me. I don't feel it's worth going to a 15mm with stock tires and it not being lowered. Maybe lowering it makes a difference and one needs wider spacers? Anyway, the other side will get done tomorrow
02-29-2024, 06:33 PM | #2409 | |
Rep 1,267
Since you aren’t lowered, I’d keep the 12mm in front until you decide what to do with springs. |
02-29-2024, 06:36 PM | #2410 | |
1924
Rep 1,104
02-29-2024, 07:12 PM | #2411 |
Rep 1,267
sclouzon18.00 Mr. Hankey1665.50 |
02-29-2024, 07:56 PM | #2412 |
Rep 3,869
Geighty72779.50 ronin130131110.00 |
02-29-2024, 09:29 PM | #2413 |
1924
Rep 1,104
02-29-2024, 10:49 PM | #2414 | |
Rep 131
I’m still in break in, so I have to be careful top end,and keeping it in full DSC for now, but the shift from 40 in 2 into 3 is where I want power the most. Maybe switching to MDM gives a bit more drama in the 2->3 shift?
Whoever said "money can't buy happiness" clearly never drove an M2.
03-01-2024, 08:53 AM | #2415 | |
Rep 1,724
When I'm driving 3rd does feel the most hesitant to me. It is most likely turbo lag like Geighty7 says but it's a weird stumbling/hesitancy feeling that reminds me more of timing corrections than turbo lag.
2020 X5M Competition
2024 M2- Sold 2019 M240i- Sold |
03-01-2024, 09:25 AM | #2416 | |
Rep 131
After 1300 miles, gonna try shifting 2->3 once I maybe hit like 6200ish rpm. Curious to see if I get less lag at that point.
03-01-2024, 09:40 AM | #2417 |
Rep 1,052
12 is conservative but still fills out the gap some. I did 12 f/r as well as a band aid until the new light weight wheels with proper offsets go on and the boat anchors can away. They definitely help.
03-01-2024, 09:46 AM | #2418 | |
Rep 1,052
https://www.bimmerpost.com/forums/sh...php?p=30932942 |
L3G0TS181.00 |
03-01-2024, 10:39 AM | #2419 | |
Rep 350
Wishing you a hasty break-in. |
Geighty72779.50 |
03-01-2024, 10:40 AM | #2420 |
1924
Rep 1,104
Yeah they are definitely heavy wheels and tires. I had to have my kid lift them due to some injuries and he told me they are damn heavy.
AZG871305.50 |
