08-11-2022, 01:13 AM | #23 |
Rep 1,759
Depending on what tyres….all the high grip tyres have stiffer sidewalls than the PS4S so going from 20 to 19 on those tyres won’t give you a squirrelly rear. Also the damper settings are now adjustable
08-11-2022, 01:27 AM | #24 |
this is the way
20464
Rep 9,050
Where did you see that they are adjustable dampers? I've never seen a M car come with adjustable dampers from factory. I have only seen BMW offer M Performance suspension kits in the aftermarket that are adjustable.
08-11-2022, 05:44 AM | #25 | |
Rep 8,274
Fuck big rims, I'm going to put the stock 18/19s on from the base M3 |
Karmic Man1993.00 |
08-11-2022, 11:50 PM | #26 |
Rep 502
Yeah those rear 20s are real concern especially if you are looking to drive the car year-round. I am thinking to run all season (DWS 06+ or Crossclimate or Quatrac Pro if available) or even winter tire setup with the 18/19 combo from the base M3 from October to May.
BMW CCA Member ID: 592739
08-12-2022, 12:28 PM | #27 | |
Rep 447
Ronin761698.50 |
08-12-2022, 12:35 PM | #28 |
Rep 502
Lack of sidewall to absorb impact. Makes a big difference in our Colorado winters when our roads gets destroyed with potholes everywhere.
08-12-2022, 02:10 PM | #29 |
this is the way
20464
Rep 9,050
Now that I'm thinking about it you could fit 285/35 19" to the rear and overinflate the tires to add some stiffness and stability back if it feels too squirrelly.
08-13-2022, 02:56 PM | #31 | |
Rep 3,615
Just a friendly FYI, getbmwparts is the BMW Center in Silver Springs, MD. Husker BMW in Lincoln, Nebraska formerly had great prices online (https://www.bmwdirectparts.com/) as well as the BMW/MINI Store in Cincinnati, Ohio. (https://www.thebmwminipartstore.com/) Last edited by T_U_D; 08-13-2022 at 03:02 PM.. |
08-13-2022, 04:28 PM | #32 |
Rep 1,587
The 19" that he picked are gorgeous!!
I will be honest though...I know nothing about offsets which sucks. Also can anyone explain what he meant about being within 1% of tire sized for an AWD car? Last edited by Ronin76; 08-13-2022 at 04:40 PM.. |
08-14-2022, 09:01 AM | #33 |
Rep 8,274
Can't deviate too much from baseline tire circumferences set by BMW for the xDrive system. Maybe it's 1%, maybe it's not, I don't remember it now but, it's explained in ISTA/AIR and each generation xDrive VTG (transfer case) + DSC is different. Even different tyre thread depths front to back can throw the systems off.
Ronin761698.50 Expert@ApexWheels4037.00 |
08-15-2022, 05:17 PM | #34 |
Rep 846
Decent video, seemed more like a paid promotion vid for Apex's new forged wheels on the G80/82 though. That guy didn't even know why BMW has 20 inch rear and 19 inch fronts from factory... seriously? lol
Also he went with continentals instead of michelins just cause he uses them on his other cars... okay..? Eye candy video, taking his opinions with a grain of salt though. The 19F/20R sizing is like that for a reason and provides much better dynamic mechanical grip when it comes to acceleration or cornering.
Instagram: @Project_F87
Ronin761698.50 |
08-15-2022, 07:09 PM | #35 | ||
Rep 7,036
-Tom
08-15-2022, 07:23 PM | #36 | |
this is the way
20464
Rep 9,050
I don't get why he decided to run Conti's either. Maybe they were sponsoring him and he got them for free? I thought it was weird that he though at first the front wheels were 20's because of the calipers. I've never in my life seen a car with larger wheels and/or tires up front, unless it was a FWD car or AWD that was biased up front. I believe BMW runs 20's in the rear because they need to keep the overall wheel/tire diameter within tolerances. OEM Front 275/35-19" Overall diameter 675mm OEM Rear: 285/30-20" Overall diameter 679mm If they ran a 285/30-19 in the rear the diameter would only be 654mm so the wheel/tire combo would be too short. If they ran 285/35-19 it would be 682mm which would be too tall. The base M3/4 come stock with Front 18" and Rear 19" wheels and if you do the same math with wheels that are the same size you'll run into the same tolerance issue. Even though he used 19's front and rear he had to get wider tires than stock, Front 285/35-19, Rear 295/35-19 which helped keep the wheel/tire diameter within acceptable tolerances. |
08-15-2022, 07:30 PM | #37 |
Rep 1,587
How is the fitment of BMW stock wheels? Meaning are they pretty flush with the fenders are are they regressed (not sure if thats the right word to describe it) inward a little bit like most auto manufacturers?
08-15-2022, 07:41 PM | #39 | |
Rep 1,587
08-15-2022, 07:56 PM | #40 | ||
Rep 1,146
Ronin761698.50 |
08-15-2022, 07:58 PM | #41 | ||
Rep 7,036
-Tom
Ronin761698.50 moodyhank82591.50 |
08-16-2022, 09:57 AM | #43 |
Rep 1,438
Plan to run my BCF RZ21 from my G80 M3. It's OE spec 19&20. Currently running them with spacers 18F & 13R, but I might end up either not needing spacers or get different sizes.
08-16-2022, 10:06 AM | #44 |
Rep 1,587
Do you guys also change the suspension of the cars as well or just put the spacers on and call it a day? I have never done either so not very knowledgeable about this sort of thing.
