BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      08-17-2023, 01:32 PM   #23
AZG87
Drives: G87, 2018 Mustang GT traded in
Originally Posted by Game View Post
Lowering it got rid of the rubbing. So glad I didn’t do any cutting.
Up front I lowered it about 28mm.
Excellent to hear. I'm only doing the MP HAS so only 10mm down but if I can get by with at least a 12mm in there without rub that should fill out most of it even if not fully flush. So 12/15 should be in play or even possibly 15/15 based on your feedback.
      08-17-2023, 04:35 PM   #24
Game
Game's Avatar
8139
Drives: G80 LCI, G87 (sold)
I’ll likely be going 18mm in the rear…maybe even in front as well.
AZG871157.50
      08-17-2023, 05:34 PM   #25
rcouchh
rcouchh's Avatar
Drives: BSM G87
Ordered some 15F/18R spacers to rock while my wheels get made. If my car ever arrives I'll be sure to post up detailed pics
AZG871157.50
Ronin761488.00
      08-17-2023, 05:34 PM   #26
AZG87
Would be great to see and confirm.
      08-17-2023, 06:19 PM   #27
Game
Game's Avatar
8139
R44 has a video with 18mm spacers front and rear on YouTube.
Ronin761488.00
      08-17-2023, 07:38 PM   #28
AZG87
Found this one they did, 12 f 15 r on one side then 20 /20 on the other. First I have seen take it all the way to 20.
Game8139.00
Ronin761488.00
      08-17-2023, 08:13 PM   #29
sl0m0
Drives: Sedan
I have 15mm front, mphas at the 10mm, and no rubbing.
AZG871157.50
baron951866.00
Ronin761488.00
      08-17-2023, 08:16 PM   #30
AZG87
Welp that right there is awesome to hear. So even full lock like backing up etc still 0 rub on your front liner?
Did you go 15mm rears too or 18mm in the back?
      08-17-2023, 08:18 PM   #31
sl0m0
Drives: Sedan
12 mm rear, I will double check full lock backing up tomorrow once I get the car back from ppf.
AZG871157.50
      08-17-2023, 08:27 PM   #32
AZG87
Excellent, appreciate it.
      08-17-2023, 11:29 PM   #33
Game
Game's Avatar
8139
Must’ve misheard because that’s 20/20 as well. Looks great here…may have to do the same.
AZG871157.50
      08-19-2023, 03:32 PM   #34
AZG87
By chance did you get a chance to test / confirm this?
      08-19-2023, 04:29 PM   #35
sl0m0
Drives: Sedan
I pulled out of a spot full lock today and didn't notice any rubbing, once I get back home tomorrow I'm actually going to check in my garage and peak into the wheel well to double check. Its too hot where I am now to be getting onto the ground and peak.
      08-19-2023, 04:37 PM   #36
AZG87
Awesome, appreciated. Sounds promising though.
      08-21-2023, 10:18 PM   #37
Mrwatchdawg
just ordered the KW HAAS and was wondering what do you recommend for a perfect mix with no rubbing?
Also, camber plates available to keep alignment in check?
      08-22-2023, 01:06 AM   #38
baron95
baron95's Avatar
1866
Drives: BMW G87 M2
Pirellis or Michelin?
My car is coming with MP suspension (port install default height), and I'd love to do 12 front and rear. But I heard Pirellis rub, where Michelins don't.
Thanks.
G87 M2 BSM On Order
      08-22-2023, 10:58 AM   #39
rcouchh
rcouchh's Avatar
Drives: BSM G87
Thanks.
12mm will not rub no matter how low your MP HAS is. You don’t have to worry.
sl0m01304.50
ourlee1557.00
      08-22-2023, 11:15 AM   #40
sl0m0
Drives: Sedan
Thanks.
Mine is with Mich's
      08-22-2023, 10:28 PM   #41
Mrwatchdawg
So you are suggesting with KW do 12 and 15 with camber plates. I should not have any rubbing.
      08-23-2023, 12:06 AM   #42
baron95
baron95's Avatar
1866
Drives: BMW G87 M2
Thanks. Has anyone verified that this iss true with Pirellis also? Heard Pirelli owners having rubbing issues with anything more than 5 mm.
G87 M2 BSM On Order
      08-23-2023, 08:25 PM   #43
DivergedM2
DivergedM2's Avatar
Drives: G87
I’m on a 285/295 20’ setup with 15f/12 rear, lowered on KW HAS. I rub in front with 15s at full lock. I did not rub on a 10/12 setup if that helps anyone!
I’m either gonna cut the liner or bite the bullet and buy the fender liner clearance piece from IND. Undecided
AZG871157.50
mrcheyl253.00
      08-25-2023, 03:04 PM   #44
gcmak
gcmak's Avatar
Drives: G87 & IS500
I've started taking a dremel to the louvers and it's still catching...wondering how much I have to remove...or all of it and shove netting inside!
rcouchh2656.00
Search this Thread:
Advanced Search
