07-22-2022, 02:06 PM | #45 | |
Rep 1,545
The F90 felt lighter and nimbler with increasing speed, It was possible to accelerate hard before apex and it went exactly where I wanted it, at a T-junction, just put your foot down and it slingshots you out of it. I was afraid the steering feel would be compromised, by all this torque dispatched to the front axle, but it didn't. Also it felt neutral at all times. I remember I was totally flabbergasted with this experience, three years back. Since that day, I've changed religion. |
02M3ForMe4343.00 buckybadger1600.00 |
07-22-2022, 02:44 PM | #46 |
Rep 686
Vic
m3number86258.50 |
07-22-2022, 04:03 PM | #47 |
Rep 87
I think the addition of the M version of X drive as an option that is not paired with trim level or anything else is all positives, but that wouldn’t be the case.
Those who want it can also disable it and have RWD dynamics with little added weight Those who don’t want it lose nothing except: My problem with Mx drive is how BMW have implemented it in a tiered system on the M3/4. I would prefer a competition or CS if I was getting an M3/4, except that both of those mandate AWD, which mandates the ZF auto. Because a subset of people really want AWD that then indirectly kills manual sales, which does affect those of us who want a manual. I have an F90 comp and I can say it’s the best AWD system I’ve driven by far. It’s truly rear-biased and the transfer of torque to the front is seamless on dry roads. On lower traction surfaces you can feel the transition some when it happens more abruptly. It also completely disables if you want to hoon around. The BMW tuning on the ZF8 is also the best torque converter box I’ve ever driven. If you’re someone who can deal with (or who likes) autos, I’m sure it’ll be fine in the M2 as well, but I’m really itching to get back into a manual after having the M5 for a few years. The slight delay for paddle inputs and automatic downshifting when slowing really bother me (sometimes causing a double downshift when I’m off the gas and use the paddle to do the same thing not realizing the car already has). But it’s also better than others’ tuning of the ZF8 and worlds better than the Aisin box my wife has. As far as M RWD traction, it’s good on a flat well-maintained surface with warm tires. I have a freeway ramp on the way home from work that slopes down to the freeway and is too close to the parking garage to have any heat in the tires, even when it’s warm out. The M5 will reliably break out the rear from a second gear roll and sometimes in 3rd… and this is dry pavement, 80 degree weather. I’m fine with that, but sometimes you just want to put the hammer down and merge. There’s something to be said for the Jekyll/Hyde created with the M shortcuts and Mx drive. |
07-22-2022, 05:28 PM | #48 | |
Rep 3,023
buckybadger1600.00 m3number86258.50 |
07-22-2022, 05:32 PM | #49 | |
Rep 3,023
The usable day to day HP is almost identical. https://bluesparkautomotive.com/proj...4c-m2c-testing |
07-22-2022, 08:04 PM | #51 | |
Rep 1,545
1. the tiering you discuss is more engine output driven than A/RWD. The manual transmission can't cope with more than 550Nm. A lot of forum members would like to see their niche version of the M manual they prefer, but I believe we have to be happy we still get ONE variant. Worldwide MT represents the small minority and bean counters want to ditch it to reduce costs every occassion they can! 2. You want to get back into a MT to be more connected? You might be in for a negative surprise, the ZF shifts 20 times faster than the mediocre manual they provide. Also, shifting down (even with heel-toe) requires a lot of time, certainly compared to a simple flick of your right foot with the ZF. The haptical experience from shifting is only average at best and the clutch travel is way too long with a high positioned clutch grip point in that travel. So yes, a short throw box with a short travel clutch would be nice, butI'am afraid you need to get a Honda for that. |
07-22-2022, 08:14 PM | #52 | |
32875
Rep 9,939
Quattro be damned All you have to do is turn-off DSC, then xDrive really goes to work
KoenG1400.00 |
07-22-2022, 09:24 PM | #53 | |||
Rep 250
07-22-2022, 09:29 PM | #54 | ||
Rep 250
Ppl are driving gt3 manuals. It's the connection not the technology. The technology is undeniably great though. |
KoenG1400.00 |
07-22-2022, 10:27 PM | #55 | |
Rep 3,248
Drives: 21 Vantage, 18 Vantage, 00 WRX
I reckon it will be more like the G82 to drive. Supremely capable and a lot more refined which is what most people prefer these days. It's also why I will keep my current M2 forever. |
07-23-2022, 01:24 PM | #56 |
Rep 6,680
I think given the weight and size increases I'm more likely to get an m3 this time around. If it's going to be this fat, a longer less playful wheelbase, it might as well have four doors and come with more power.
07-23-2022, 01:40 PM | #57 | |
Rep 6,140
I'd imagine this car will already be sitting around ~3800 lbs as is. An AWD variant M2 would tip 4000 lbs, that would be the definition of contradictory.
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
07-23-2022, 07:04 PM | #59 | |||
Rep 250
Just watched a video on it. It looks like all its doing is spinning tires to compensate for terminal understeer lol |
KoenG1400.00 |
07-23-2022, 09:20 PM | #60 | ||
Rep 87
Further it's not an argument for the auto being the slushbox they've gone with. DCTs are even better in all those categories. The BMW implementation of the ZF8 is the best of the slushboxes... but it is not a PDK and it is certainly not a 3 pedal. For me personally I looked at the M3/M4 but between confining the manual to the base, continuing the old mediocre manual without any development, and that front end -- I'm out. Tried for a GT3, but I'm not paying $100k over sticker and I'm not some "influencer" with connections to get one without getting screwed. Ended up putting in an order for an Emira, we'll see how that goes with Lotus' history -- a topic for a different forum Was following the M2 primarily as a backup for that. Now, if they made an M2 with both mX AWD and a manual, then that could be an interesting proposition for a 4-season car.... that's all. They won't so it's moot. The next car will be a manual -- that was decided long before the brand or even the number of doors. I'd get a Civic before I got an M2 with an auto personally. |
KoenG1400.00 |
07-24-2022, 02:20 PM | #61 | |||
Rep 250
KoenG1400.00 |
07-24-2022, 08:45 PM | #62 | |||
32875
Rep 9,939
Hilarious 😂 😷 🤣
3RDSECTOR480.50 |
07-25-2022, 02:46 AM | #63 |
Rep 1,427
New M2 is going to be very nice..
07-26-2022, 12:56 AM | #64 |
Rep 1,767
07-28-2022, 02:41 PM | #65 |
Rep 87
They say December, so maybe by March?
I really mean it. There's just an inherent contradiction to me between a torque converter and a performance car. I understand it's not a common opinion or that it bothers others to a lesser degree, but I would really rather daily an SI or R than an M2 auto, not joking one bit. Maybe a WRX GT would be a better example? I'd rather daily a non-luxury mark with a manual generally than a luxury/sport torque converter. The build quality and local service on my M5 has left me with zero brand loyalty. It's fast. The ride is good. The interior design is nice without being over the top. The AWD system is phenomenally good. The automatic is good for an automatic, but it just isn't there in terms of engagement or theater. It overrides you on down shifts. There's a delay on paddle response. Launch control requires putting it in manual mode for it to shift automatically. It does change gears noticeably faster than a manual on the single gear upshifts (but everything does these days). On the other extreme, the M-tuning doesn't have an eco+ mode to "clutch" and coast down long hills while traveling the way my wife's non-M does. I think smoothing out a DCT compatible with AWD would be a much better overall solution. If they made an M5 that I could truly drive 4 seasons AND have a manual I'd keep it forever and pay someone outside BMW to take it apart and fix all the rattles that my local dealer can't or won't... In that respect it's the worst car I've ever owned. The surprise that paying for "full leather" didn't even include the full door card, or that mine was the year they decided that carplay was actually a subscription service, or that they had quietly removed passenger dimming mirrors in the US after around 2017 at any price/package, were just cherries on top of endless rattles. So yeah, all in all I really did choose engagement first including transmission after being severely disappointed by choosing largely by brand. I previously might've been scared off by the prospect of something like endless rattles buying something like a Lotus, but I spent $126k on a new Bimmer and I've had it to the dealer 4 times for rattles and it's still so incredibly annoying... The current one sounds like the 3rd brake light and it's so rattly the factory exhaust noise is enough to get a continuous buzz going on startup. |
