BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      12-23-2023, 02:15 PM   #67
AdiSinghV12
India
73
Drives: 320d M-Sport, X1, 525d
Originally Posted by IND-Distribution View Post
This confirms our recommended stock ride height spacer fitment of 15mm front and 12mm rear to keep a uniform look. Like the G8x, on stock suspension you can also run 15/15.
This is essentially how we ended up on our 'aggressive' recommendation. Lowered with a little added camber, 18/15 is great fitment, but again you can run the square 18/18 for a bit more aggression in the rear.
Do you advice 18/18 for regular use on complete stock suspension with track usage? As I live in India lowering is out of question so at best can get the fender liners if needed
      01-05-2024, 07:22 PM   #68
G87_mtwo
G87_mtwo's Avatar
Drives: G87 m2
I do have spacers 12mm & 15mm. Can anyone tell what extended lug nut size I need for them? What should be tread length?
Resoelg325.50
      01-06-2024, 09:41 PM   #69
Ronin76
Ronin76's Avatar
Drives: 2018 Tesla Model 3
Originally Posted by rcouchh View Post
This is +15F +18R on KW HAS. Rear is almost perfect and front could use a few mm.
IND tricked a lot of people into buying poor fitting 12mm spacers.. maybe they had a huge stock they needed to flip 🤣
I think 18F 20R will end up being the best in the future.
Looks amazing....and mean! well done sir.
rcouchh2656.00
      03-16-2024, 06:01 PM   #70
apez
Drives: BMW G87 M2, F25 X3
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
Well, I just tried 18F 15R with the default port installed MP HAS drop and Sottozeros. Definitely rubbing in front.
      03-17-2024, 10:06 PM   #71
rcouchh
rcouchh's Avatar
Drives: BSM G87
Probably just need to heat and push the plastic fender liner in a bit. Easy fix for G8X, check youtube
apez822.00
      03-21-2024, 11:33 PM   #72
Resoelg
Resoelg's Avatar
Drives: 2024 M2 ZV-Blue
OP. Greatly appreciate the photos and post. Gives the community great information about possible mods.
Sure did for me.
Question....noob to spacers. Does increasing the thickness of the spacer (changing the wheel position)
create a noticable change in handling, cornering dynamics, or ride stability? I'm not planning on suspension change at this point.
      05-02-2024, 07:24 PM   #73
Don-DiGorno
Drives:
Recently got a set of these but I noticed there’s no Future Classic in bold white branding on them. Instead, etched into them is Fall-Line along with the size and bolt measurements. Are these legit? Lol
      05-03-2024, 03:16 PM   #74
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
10056
Drives: G82 M4 / G87 M2
Absolutely, your Future Classic spacers are genuine. Fall-Line has always been the manufacturer for Future Classic parts, including these spacers. While you may have noticed a change in branding from laser-etched Future Classic logos to engraved Fall-Line logos, rest assured, this alteration doesn't affect the quality or performance of the spacers. Fall-Line, known for their excellence in racecar construction and fabrication, ensures that these spacers meet the same high standards as before. If you have any further questions or concerns, feel free to reach out.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      05-03-2024, 03:24 PM   #75
Don-DiGorno
Drives:
Thank you so much for the quick response and education. I really appreciate it. You guys are awesome and it’s been a pleasure doing business with you!
      05-07-2024, 04:11 PM   #76
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
This thread along with other member feedback helped me decide on spacers. Just ordered from IND today some 15mm and 18mm with extended lugs. Going to try 15 front and 18 in the rear.
2024 M2
2019 M240i- Sold
Ronin761522.00
      05-14-2024, 06:20 PM   #77
SlezbuckG87
Slezbuck
SlezbuckG87's Avatar
101
Drives: 2021 Civic SI, 2023 BMW M2
This is super helpful! Thank you!
      05-15-2024, 08:35 AM   #78
apez
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
FYI, I went with the IND future classic 18F 15R option and had rubbing full lock in reverse.
For now I just trimmed the offending 3 louvers down to about half the normal size. It was an ugly hack job, but it has solved my problem. I may end up going with some of the aftermarket mesh inserts if I can find a reasonable priced pair.
Car looks so much better now.
      05-15-2024, 09:59 AM   #79
AZG87
Drives: G87, 2018 Mustang GT traded in
When I was waiting for my forged wheels I had Future Classic 12mm all around. Conservative but filled out nicely. MP HAS at port installed height. No rub at full lock.
      05-31-2024, 09:04 AM   #80
Skooba1231
Skooba1231's Avatar
257
Drives: X3 M40i, M2
Just got 15F/12R done and decided to skip the HAS kit as the wheel gap isn’t as big of an eyesore with the spacers IMHO.
JMcLellan2772.00
      05-31-2024, 10:45 AM   #81
Digitalprty
Digitalprty's Avatar
Drives: 2024 M2
Which tires do you have, if I might ask? I have the Pirellis, which I hear might be more susceptible to rub than the Michelins.
I also have MP HAS at port installed height and will be installing my FC 12 mm all around today.
AZG871157.50
      05-31-2024, 02:34 PM   #82
AZG87
PS4s but wih 12mm there really should be no issue even with pirellis.
      06-08-2024, 05:51 PM   #83
G87DRVR
Drives: G87 Frozen Pure Grey
Will 15f 12r rub with kw has kit? Have the michelins… Thanks
      06-10-2024, 04:26 PM   #84
IND-Distribution
BMW obsessed
10056
We did not experience any rubbing on the G87 with up to 18mm spacers.
G87DRVR120.50
      06-11-2024, 12:38 AM   #85
Sleeper
Sleeper's Avatar
Drives: 2023 X5M, 2024 M2, 2006 M3
My front left tire rubs in reverse at full lock with the KW HAS kit a quarter turn up from max low, 18mm Future Classic spacers, factory Michelin tires. But do I care?
      10-12-2024, 07:20 AM   #86
mks
mks's Avatar
86
Drives: 2024 M2
Rubbing with 15F/12R wheel spacers on stock ride
If not to disabuse some who may be considering spacers (certainly spacers larger that IND's standard fitment), than this is just to present my experience with the so-called standard fitment. I went with 15F/12R on stock suspension but removed all because of the contact/rubbing the 15mm produced--and the 12mm would likely produce according to my measurement.
My M2 is on Yokohama Advan Sport V107s (OEM tire) and stock suspension. Contact seems to occur with wheels turned somewhere within ~20 to 45 degree range (IDK). Horrible sound produced by contact with the louvers, which increasingly protrude just enough to catch the tire as it's pushed out at least 15mm (12mm also a likely no-go--which I believe some others experienced). Cutting into the louvers just not worth it for spacers (and can't justify the $800+ for wheel well liners designed to accommodate them).
      10-12-2024, 10:16 AM   #87
fanofbmwe46
Originally Posted by mks View Post
If not to disabuse some who may be considering spacers (certainly spacers larger that IND's standard fitment), than this is just to present my experience with the so-called standard fitment. I went with 15F/12R on stock suspension but removed all because of the contact/rubbing the 15mm produced—and the 12mm would likely produce according to my measurement.
My M2 is on Yokohama Advan Sport V107s (OEM tire) and stock suspension. Contact seems to occur with wheels turned somewhere within ~20 to 45 degree range (IDK). Horrible sound produced by contact with the louvers, which increasingly protrude just enough to catch the tire as it's pushed out at least 15mm (12mm also a likely no-go—which I believe some others experienced). Cutting into the louvers just not worth it for spacers (and can't justify the $800+ for wheel well liners designed to accommodate them).
Attachment 3574194
Attachment 3574195
I get similar slight rub in reverse at almost full lock with yokos, 12mm spacers, and about 20mm drop on MPHAS. Might switch to 10mm spacers instead.
      10-12-2024, 11:40 AM   #88
mks
mks's Avatar
86
Drives: 2024 M2
I could have trimmed the louvers, I suppose. But, the why prevailed over the why not argument.
BTW, beautiful car...color, stance, wheels, etc. It's all there.
Search this Thread:
Advanced Search
