BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      11-27-2023, 09:52 AM   #133
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by TwinWhistles View Post
I hope someone can clarify this for me regarding the RaceChip map setting. Do you need to add downpipes at any point to increase the level? If not, is there any benefit, other than sound, to adding the DPs?
I miss the old Cobb AccessTuner days on my '08 335i where you knew which map to load based on your mods. Also, wish there was the pro-tune option like there used to be with Cobb.
DP only beneficial if you are running flashtune.
Other than that, just for sound.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEAL!! | MSS SALE
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      11-27-2023, 11:58 AM   #134
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Originally Posted by azlightning213 View Post
Mike - any Cyber Monday sales on the JB4 for the G87? And will you guys ship to California? (I know Burger does not ship to CA).
Dm sent
No need to add downpipes to the Racechip, all their maps are optimized for the stock car. Its mostly about the octane you are using than your mods.
https://x-ph.com/sale/
Phone number 702-494-9435
      11-27-2023, 02:39 PM   #135
ZPD
ZPD's Avatar
658
Drives: 2022 M850i GC, 2023 G87
Woah- really? There's no HP gain from DP unless you tune? Even if it is catless or high-flow?
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
r33_RGSport13642.50
      11-27-2023, 02:42 PM   #136
r33_RGSport
Yes.
Something is different with the S58 O2 sensors data usage.
      11-27-2023, 04:28 PM   #137
swrdply400mrelay
Drives: VN
Can the dealer detect Racechip if it's been removed?
      11-27-2023, 04:32 PM   #138
rons e92
60-130 Enthusiast
rons e92's Avatar
According to my tech and my service advisor, it depends.
When you bring the car in, no they can't. They can scan the key to get info about your car, but that won't show that you had the car on a piggyback.
They can read the ECU which is a more in depth scan. That looks for boost pressures above what the car was targeting. If they scan the car that way, there's nothing you can do. It's stored forever. As soon as your car sees boost above the target it's flagged, and once they read your ECU your car is flagged in their system forever as being tuned.
I got a commitment from my advisor and tech that they'd never do a full read of the ECU on my car.
I could be wrong, so please correct me if I am, but this is how I understand it.
r33_RGSport13642.50
      11-27-2023, 10:06 PM   #139
mike@x-ph.com
The answer varies based on who you ask, but it does not really matter.
from 15 years of history on this forum and hundreds of thousands of tuned cars, here is what we know for sure.
1-dealerships go out of their way to deny warranty claims. Unless you're trying to get a stock part that you broke repaired for free, they don't really care.
2- Proven tunes are unlikely to damage stock parts, so this situation is rare.
the fact that warranties were not denied to hundreds of thousands of other users means it won't happen to you. However, nothing in life is entirely risk-free. If you find these odds worrying, it might be best to keep your car stock
      11-29-2023, 10:37 AM   #140
Reesnat
India
161
Drives: BMW G87 M2
How does the hardware speed compare between RaceChip and JB4? While the JB4 seems to look at more parameters, the actual processing isn’t as fast as the RaceChip?
      11-29-2023, 11:32 AM   #141
mike@x-ph.com
You'd have to check with the manufacturers for the exact specs of their processors, but it won't make any different on the street if there are differences, its in the milliseconds.
      11-29-2023, 11:26 PM   #142
Reesnat
India
161
Drives: BMW G87 M2
Will do! was hoping some on the forum would know. As for the milliseconds, my guess is that is what makes the difference in how smooth and responsive it feels. Goal is to get to stock levels of smoothness.
Some of the JB4 maps have a very jagged response curves on the dyno, hence the Q.
r33_RGSport13642.50
      11-30-2023, 11:34 AM   #143
mike@x-ph.com
I think you are listening to too many sales pitches from vendors.
"IF" there is a difference, it's not noticeable unless you are a professional driver. That said, if you are leaning more toward the Racechip, get the tune you are more comfortable with.
At the end of the day, either one will get the job done.
But Milliseconds are not a time difference you will feel. It's a great sales pitch and would help me score more sales, but I would be dishonest to convince you otherwise.
But to address your question, here are a few dynos of the JB4; the boost spool is exactly like stock, just higher RPM. I don't see any noticeable lag.
      11-30-2023, 10:38 PM   #144
r33_RGSport
Your statement is what many of my customers described when they switch to RaceChip.
      12-01-2023, 08:03 AM   #145
M Division
M Division's Avatar
1245
Drives: G87 M2, G42 M24, X6, R34 GTR
I've been running jB4 for about 3 months.l on my G87, no issues, then suddenly the car goes into limp mode...
New "Exhaust Cam Signal High" error today on Limp mode & Drive Train error (I've attached JB4, BimmerLink and ProTool error log dumps).
Dash error with Engine Light & Limp Mode, Warning: "Can continue Driving, Contact service, etc"
Read Codes through JB App received "164030: Exhaust Cam Signal High"
Deleted codes with engine off and Diagnostic mode and restarted engine
Limp mode and Error returned immediately
Ran additional error codes via ProTool and BimmerLink and they're giving an additional short circuit to positive exhaust cam, etc:
"146030: Exhaust camshaft sensor, signal: short circuit to B+" / "146030: Exhaust camshaft sensor, electrical: short circuit to positive"
"130F11: Exhaust camshaft sensor, signal: not plausible" / "130F11: Exhaust camshaft sensor, plausibility: pattern invalid"
Other errors are listed in the screenshots are just the standard high flow cat errors
Odd thing is I haven't touched the car for months since initial installation of the high flow cats and JB4 so these errors appear to come from the blue today for some reason.
Any help appreciated as always.
I've attached all of the various Error Reports and Code dumps, JB4 Software version etc
I contacted Terry and Burger a week ago, no resp, followed up yesterday, nothing so far...
Ill keep you updated.
      12-01-2023, 09:54 AM   #146
r33_RGSport
I would say you will get better help at their forum.
It is more concentrated users and owners there.
      12-01-2023, 04:51 PM   #147
mike@x-ph.com
Not sure which email you used but I would email their support team instead of terry directly. Im sure he is swamped with Black Friday orders and support.
      12-01-2023, 05:01 PM   #148
M Division
M Division's Avatar
1245
I used support@
But yes I'm sure you're right.
      12-01-2023, 05:23 PM   #149
ToneM2
Stupid question but did you try disconnecting the jb4 and then clearing the codes and seeing if the car runs without going into limp mode?
      12-01-2023, 05:36 PM   #150
M Division
M Division's Avatar
1245
I did yes, the car is running perfectly with JB4 disconnected and codes cleared.. but I don't want to point the finger at jb4 without speaking to Terry and the guys at BMS to trouble shoot and really work out the root cause. I'm sure it's something simple, I've had nothing but good solid experience with JB4s for 6-7years on many BMWs so I'm confident this is the same.
      12-01-2023, 08:05 PM   #151
ToneM2
I mean things break sometimes, you’re not pointing any fingers. If it runs fine without the piggyback then the issue is the piggyback. Could be something on the board came loose or one of the connectors has some corrosion. I’m sure Burger Motorsports will take care of it.
      12-01-2023, 08:19 PM   #152
M Division
M Division's Avatar
1245
I know what you mean, it could of been a loose connection also although I checked and photographed every connection as I did the uninstall. I didn't notice any obviously connection issue.
I'd like some guidance from BMS on what to check and ideally I'd then reinstall the JB4 to see if the error returns. I just don't want to do that without speaking with BMS first.
      12-02-2023, 05:48 PM   #153
ToneM2
Ok well keep us posted maybe make a new thread about it.
      12-10-2023, 12:15 AM   #154
ZPD
ZPD's Avatar
658
Does the racechip retain your last setting when you start your car or do you have to select it every time? Also, do the M-mode settings select the racechip settings in addition to the app?
2022 M850i
r33_RGSport13642.50
Search this Thread:
Advanced Search
