BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      12-10-2023, 10:48 AM   #155
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by ZPD View Post
Does the racechip retain your last setting when you start your car or do you have to select it every time? Also, do the M-mode settings select the racechip settings in addition to the app?
Yes, it does. You don’t need to open up the App everytime. Only when you need to change Maps.
No, M mode will not change anything to the RaceChip.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
BLACK FRIDAY SALE is here !!! - Coupon Code "BF24"
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • CSF • SPL and more...
Accepting - Visa, MasterCard, American Express, Discover, Paypal, Venmo, Cash App, Amazon Pay, Affirm.
rons e922018.50
ZPD685.50
      12-14-2023, 08:34 PM   #156
makeitbetter
Drives: 21' X5 xdrive40i
Does it make sense to buy a RaceChip GTS if you're going to be stuck with 91 octane?
For example, why purchase the "additional" maps via the GTS Black if you're only going to be able to use the 91 octane map. Does anyone think that the 91 octane map is different on the "RS" vs the "GTS Black"?
Thanks
r33_RGSport13749.00
      12-14-2023, 10:20 PM   #157
r33_RGSport
Thanks
Yes, they are.
RS map 6 is GTS Black map 6.
Also the benefit of GTS Black is built-in warm-up timer, engine warranty, 1x free reprogramming in 2 years of ownership.
Lastly, better resale value.
      02-12-2024, 05:42 AM   #158
vTuga
vTuga's Avatar
Portugal
93
Drives: 2020 BMW 330e G20
Originally Posted by r33_RGSport View Post
Yes, they are.
I'm sorry, I got a little confused with your post. Is the map 6 of the RS the same as the map 6 of the GTS Black?
Also, can you use map 7 with 93?
r33_RGSport13749.00
      02-12-2024, 09:38 AM   #159
r33_RGSport
Based of my understanding, yes.
You can use any map with 93.
The better the gas, the better it perform.
Just nothing lower than 91.
      02-12-2024, 11:54 AM   #160
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
It's tough to say since racechip does not allow dataloging to check how the car is reacting, and they also do not share the amount of PSI each map is adding.
Based on my testing, my car with 91 octane seemed to perform more reliably with map 6 than map 7, which might be an indication that it's dropping timing on map 7 (again can't say for sure without datalog).
I would use max map 6 with 91 only
and use map 7 with 93, or if you are mixing a few gallons of E85 with 91
https://x-ph.com/sale/
Phone number 702-494-9435
      02-13-2024, 05:20 AM   #161
vTuga
vTuga's Avatar
Portugal
93
Thank you for both of your answers. What about in the m240i, would that be the same (map 6 max with 91, map 7 with 93)?
I'm still deciding between both.
r33_RGSport13749.00
      02-13-2024, 09:53 AM   #162
r33_RGSport
US maps is made to handle California 91 octane as a minimum gas.
So, yes, even on the M240, map 7 is good for 91 or better.
Just remember, some gas station will cheat you on 91. The minimum I go for testing is Costco 91.
I know, because I assist RaceChip in collecting data and testing the map for US BMWs whenever I have the cars or able to get the cars. Such as most recent are, G09 XM, F95/F96 X5M/X6M, G8x M2/M3/M4, G05 M60i, G42 M240, etc.
vTuga93.00
      02-13-2024, 11:57 AM   #163
mike@x-ph.com
I would use the same map recommendation with the M240 as well.
vTuga93.00
      02-26-2024, 08:20 AM   #164
Chapman1977
Same in the US, you do get 1x free reprogramming within 24 months of purchase. Afterward it is $149/reprogramming.
If you like to switch cars, really worth it.
Other popular brand doesn’t allow you to do it even though it is do-able, they just don’t want to do it to make more money.
Hi there,
I have a GTS (not black!) for a Honda CR-V which is about 30 months old so out of free reprogramming. Currently stationed in Thailand.
Could I send you my unit to have you reprogram it to the G87 M2 that's waiting for me in Europe in the coming summer?
Would really appreciate your response.
Best Regards
r33_RGSport13749.00
      02-26-2024, 02:26 PM   #165
r33_RGSport
Originally Posted by Chapman1977 View Post
Hi there,
Best Regards
Unfortunately, GTS can’t be reprogrammed to G87 since it uses GTS Black.
Besides, you will need to contact your regional RaceChip office to handle your case.
      03-03-2024, 10:47 PM   #166
Chapman1977
Thank you for your reply - will do that once I'm in Germany
Best Regards
2024 G87 M2 Zandvoort Blue / Cognac Interior
r33_RGSport13749.00
Jonyxz39.00
      03-04-2024, 01:45 AM   #167
baron95
baron95's Avatar
1868
Drives: BMW G87 M2
Originally Posted by rons e92 View Post
I got a commitment from my advisor and tech that they'd never do a full read of the ECU on my car..
With all due respect, if you ever have an engine failure (which is the only time any of this matters) BMW will absolutely insist on a full scan before authorizing warranty repairs.
It's not in the hands of the dealer. In fact, depending on how costly the repairs are, BMW NA will send a regional tech in.
G87 M2 BSM On Order
      03-04-2024, 07:28 AM   #168
rons e92
60-130 Enthusiast
rons e92's Avatar
If I have an engine failure at this point, it's not going to BMW for a repair. My car is pretty modified now and I wouldn't expect BMW to warranty the drive train being I've switched fuels and turned it up quite a bit.
I didn't want them scanning my car because I didn't want it flagged by bmw.
baron951868.00
lutfy306.50
      03-04-2024, 08:17 PM   #169
baron95
baron95's Avatar
1868
Drives: BMW G87 M2
Yes, I've watched your latest video - great stuff, keep it up - and know you are now fully unlocked on E, etc.
I was posting more for the benefit of those like me, who are on the fence about doing a piggy back stealth mod or not.
It's not an easy choice. Racechip can take you from the detuned G87 to the CS/CSL power level for $700 bucks. If it was not for the new Ista ability to cross check parameters from the multiple computers when the powertrain scan is run, a lot more people would be plugging in the Racechip (and similar). The comprehensive scan at the touch of a button is what is deterring me.
G87 M2 BSM On Order
rons e922018.50
lutfy306.50
      03-10-2024, 02:00 PM   #170
CadolinaRipr
CadolinaRipr's Avatar
444
Drives: BMW M2
Anyone turn their racechip up to 7 yet? What boost pressures you seeing? Did some pulls at level 5 and it was amazing, but I am curious what pressures others are seeing at 5 and 7? TIA.
r33_RGSport13749.00
      03-11-2024, 04:00 PM   #171
mike@x-ph.com
i used map7 for a while on my car, cant tell you the boost since racechip does not datalog, i suspect its another .5 to 1 PSI more than map 6.
i got more power than map 6 but it was not as consistent. some pulls were great; others were not. i suspect it was dropping timing on some of the pulls but cant tell for sure without data logging.
      03-24-2024, 03:35 PM   #172
thinking
Drives: BMW M2 G87
Has anyone looked into MOSSELMAN ITRONIC? At first glance, it looks like it's giving really good numbers compared to RaceChip.
https://www.mosselmanturbo.com/en/it...p-s58-g-series
rons e922018.50
      03-25-2024, 07:24 AM   #173
WhiteRqbbit
Drives: BMW M2 G87
For the money, it seems like going with unlocking would be the better idea.
      03-25-2024, 11:45 AM   #174
mike@x-ph.com
+1
      03-25-2024, 12:43 PM   #175
WhiteRqbbit
Drives: BMW M2 G87
So, has anyone gotten real numbers from this yet from a dyno?
      03-25-2024, 04:16 PM   #176
CadolinaRipr
444
Drives: BMW M2
Dyno #'s -> https://g87.bimmerpost.com/forums/sh...2&postcount=70
Dragy #'s -> https://g87.bimmerpost.com/forums/sh...&postcount=108
That is all I have seen so far...
Search this Thread:
Advanced Search
