BMW 2 Series Technical Topics (G42) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      11-28-2022, 05:22 PM   #1
MPR
MPR's Avatar
2066
Drives: 22 M240i
Ramps for oil changes
Looking for what the other DIYers out there do to get the car in the air for an oil change.
I bought a set of ramps from harbor freight today but the front bumper is too low and hits the ramp before the wheel has a chance to climb it.
I was trying to avoid jacking up the car and using jack stands since nobody is able to confirm where the front jacking point is, and ramps seem so much easier.
Thinking of either:
1. Jack up driver's side from side jack point high enough to slide ramp under driver's side wheel, repeat for passenger side. Both front wheels will now be on ramps. Opposite steps to get car off ramps.
2. Buy 8" wide x 2'-3' long pieces of wood to work as ramp extensions
Is anyone else in the same boat and have any pointers?
      11-28-2022, 05:51 PM   #2
apez
Drives: BMW G87 M2, F25 X3
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
The only other suggestions I have seen is the jack stands that work with your jack, so you can use the same jack points for both jack and stand.
I wish there was more clarity around this for sure.
      11-28-2022, 06:05 PM   #3
MPR
MPR's Avatar
2066
Drives: 22 M240i
There are dimples that make a circle shape in the metal under where the front axle is, so I assume it's the jack point. I just don't want to experiment on my car.
      11-28-2022, 06:37 PM   #4
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
I am in the same boat. Following the same threads for oil changing. I really want to try to jack up from that apparent front center jack point, but I too don't want anything to break. I have RhinoRamps which of course are too steep
I will check with the G20 folks, I'm assuming the underside will be almost identical since they are both based on the CLAR platform.
      11-28-2022, 07:12 PM   #5
P_Chris
P_Chris's Avatar
170
Drives: 2022 M240i
2022 M240i  [0.00]
I use race ramps 8" wheel cribs.
https://www.raceramps.com/garage-ser...ibs/p/rr-wc-8/
2022 M240i
      11-28-2022, 07:18 PM   #6
MPR
MPR's Avatar
2066
Drives: 22 M240i
https://www.raceramps.com/garage-service/cribs/p/rr-wc-8/
That's essentially the same as my idea 1 above, right? They are basically just the resting area of ramps, without the slanted part.
How do you get the car onto those?
      11-28-2022, 10:28 PM   #7
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
I'm guessing the idea is you lift the car using one of the 4 jack points. Then throw this under the wheel and lower the car onto the crib. Negating the need for jack stands, but still need a jack. Only useful when not needing to remove the wheels
Race ramps has lower profile ramps, but not at all useful for doing any work under the car like oil changes
      11-29-2022, 08:20 PM   #8
apez
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
These are definitely pricey, but look interesting: https://rennstand.com/product/rennstand/
$500 for 2... the ramps are definitely cheaper, but at least with these you could take wheels off.
      11-29-2022, 08:25 PM   #9
MPR
MPR's Avatar
2066
Drives: 22 M240i
Way too expensive.
To take wheels off I just jack up the corner I want to remove. Granted, I can only remove one wheel at a time.
Until someone solves the front jack point mystery, I'm going to jack up each side of the front and slide a ramp under the wheels
      11-29-2022, 08:27 PM   #10
Soylent
Soylent's Avatar
1252
Drives: 2025 M4C
I used a QuickJack before I got my lift. Very easy to use.
      11-29-2022, 08:37 PM   #11
MPR
MPR's Avatar
2066
Drives: 22 M240i
I think it goes without saying a quickjack makes it super easy, but the goal is to not spend $1,000+, not even close to it. Not sure if that was said directly yet.
      11-30-2022, 08:37 AM   #12
bobkat09
bobkat09's Avatar
159
Drives: 2023 M240i RWD
I use two floor jacks. One on each side of the car and raise them both incrementally high enough to slide my Rhino ramps underneath the wheels.
Works good enough to do oil changes
MPR2066.00
      11-30-2022, 08:46 AM   #13
KmtbS
KmtbS's Avatar
Drives: 22 M240i
Here's my method. Drive front wheels onto 2x4 blocks to gain clearance for my jack, raise car from the center jack point, place jack stands on each side.
MPR2066.00
      11-30-2022, 09:59 AM   #14
MPR
MPR's Avatar
2066
Drives: 22 M240i
Are you using the area that has a few indents in the shape of a circle?
      11-30-2022, 10:31 AM   #15
KmtbS
KmtbS's Avatar
Drives: 22 M240i
Yes
      11-30-2022, 10:52 AM   #16
Ruebarb
Ruebarb's Avatar
423
Drives: BMW G42 M240i
I used these $159. They had the correct angle, just wish the car was higher, I just barley managed to get under it, but it was just enough. If you are not thin, this won't work.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
MPR2066.00
heelsmj361.50
      11-30-2022, 11:00 AM   #17
MPR
MPR's Avatar
2066
Drives: 22 M240i
I may stick with my $45 harbor freights. Jacking it up is going to suck, but once I figure out an extension setup they will be awesome.
      11-30-2022, 03:45 PM   #18
PNTDG42
Drives: G42, F97 LCI, EBA R35, Z34
3. Dig a 18-24" deep hole that fits between the front tires
      11-30-2022, 03:51 PM   #19
MPR
MPR's Avatar
2066
Drives: 22 M240i
Funny guy.
PNTDG42524.00
      11-30-2022, 06:02 PM   #20
MPR
MPR's Avatar
2066
Drives: 22 M240i
Change of plans, going to return the ramps and get HF's 3 ton jack stands with the flat surface for the pad adapters. Going to use the assumed front jacking point.
      11-30-2022, 06:09 PM   #21
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
Think I might do the same. Mind reporting back if you do end up using the assumed jack point? So far it's seems at least 2 other members have used it with no problems
      11-30-2022, 06:11 PM   #22
MPR
MPR's Avatar
2066
Drives: 22 M240i
Yeah, as of now I plan to do the oil change over the weekend, I'll report back with pics.
TJZ67201902.50
apez848.00
bobkat09158.50
Search this Thread:
Advanced Search
