BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      01-28-2024, 10:04 AM   #1
ZPD
ZPD's Avatar
664
Drives: 2022 M850i GC, 2023 G87
A caution for those with Millway Camber plates
I took off my Millway Camber plates when I switched to coilovers with Vorshlag camber plates and I noticed that several of the T nuts were bent. It looks like it was over torqued when I had the alignment done.
If you use Millways with your stock or HAS suspension then make sure your alignment guy uses the correct torque.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
baron951866.00
M2-Bob250.50
GenXG87217.50
      01-28-2024, 11:21 AM   #2
RockCrusher
Yikes!
      03-02-2024, 06:58 PM   #3
GenXG87
GenXG87's Avatar
218
Drives: 2023 M2 & 2018 M2
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
sheesh surprised they didn't snap the bolt. My guess is they used an impact on them. I just looked at my Millways today while I had them out doing my Ohlins R&T. Nothing like that but I notice that they do not slide as freely as they used to either. Pretty tough to adjust the camber.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, Pagid RSL29, BM3 Stg2, MAD CAI, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts
IG: Follow ME: genXg87
      03-07-2024, 04:27 PM   #4
M3SQRD
M3SQRD's Avatar
3906
Drives: G20 330ix,F22 240iX,e92 M3
That’s a poorly designed camber plate. All of the vertical load (preload + % of applied load carried by the bolt) is reacted by two small flanges with the load distributed over a small area. Puts both flanges of the flanged nut in pure bending (acts like a cantilevered beam) + transverse shear. Not surprised to see it fail that way. Over-preloading may have contributed to the failure but it wasn’t all due to preload.
      03-08-2024, 10:57 AM   #5
ZPD
ZPD's Avatar
664
I don't disagree with you at all. Worse yet- if the flange nut is half way through the slot then the load area is miniscule. If someone chooses to run millways I would recommend setting the camber on the plates all the way so that the marker on the top is at 20 and then have your alignment shop dial in what you need using the stock lower camber adjustments.
2022 M850i
      03-08-2024, 11:43 AM   #6
M3SQRD
M3SQRD's Avatar
3906
In the 30+ years of tracking, this is one of the worst I’ve ever seen. There were some poor designs in the 90s! On Millway’s, the worst part is you can’t easily see it (unless you remove the wheel, stick your head past the brake rotor with a flashlight and look up) but there could be one failed.. then two failed…then three failed…strut lets go midcorner. Anyone using these better be inspecting them very frequently and, if you track your car, between every session.
      03-10-2024, 05:39 PM   #7
GenXG87
GenXG87's Avatar
218
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
Well I got stung by the Millway Camber plates this weekend.
I made a video about it. Basically after the Ohlins install it was very difficult to adjust the camber and one of the tower bolts wouldn't torque.
I did some research to figure out the torque on these things. I really feel like they need to include new high quality hardware. The factory bolts are torque to yield so technically they shouldn't be loosened and retorqued without replacement.
The stock torque is 29nm and then turn 90 degrees. I am reusing the stock bolts. So when I torqued the first time using this, it 'felt' too much based on my wrenching experience.
Fast forward. I happened to have a set of Millway Uniball Camber plates and was like, well this is a good time to swap and I will rethink this torque spec.
Well bad news. Can't use the Uniball plates with the Ohlins. Millway includes a couple adapters for two different shaft diameters. The Ohlins includes an adapter that is designed to fit into the stock strut hat. The Uniball diameter is not the same as stock.
So, I decided to harvest parts from the Uniball plates to get up and running.
Regarding torque. I have settled on 50nm torque. I will be monitoring this at the track to see if the camber moves and/or bolts start to loosen.
The video shows basically the bad part and what I did to fix it.
      03-10-2024, 08:15 PM   #8
ZPD
ZPD's Avatar
664
GenXG87 Sorry that you are going through this. I had lots of problems trying to get the millways to work with my coilovers and wound up getting the Vorshlag. I had Vorshlag on my previous car and should have gone that route in the first place. Just so you don't repeat the same mistakes that I made- Millways will not work with 2.5" or 2.25" springs. I had Millway make me adapters (before I knew that the flanged nuts were damaged) and it just creates too much stack height. I had less than an inch of suspension travel.
Another plus for Vorshlag is that they are in Texas. Millway is in Sweden so you might have a delay in response and of course, shipping will be high.
2022 M850i
GenXG87217.50
      03-11-2024, 02:57 PM   #9
aerobod
Car Geek
aerobod's Avatar
As far as I can tell the Millway fittings for clamping the camber plate are M8. Assuming they are non-stretch bolts that are either class 10.9 or 12.9, the maximum torque to avoid fitting damage is 33Nm for 10.9 and 40Nm for 12.9 bolts, based on the torque table Millway provide: https://www.millway.se/atdragningsmoment.
ZPD664.00
      03-12-2024, 08:16 AM   #10
GenXG87
GenXG87's Avatar
218
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
I looked at that too. This is easily addressed by them providing bolts for their camber plates and torque specs.
I've looked at bolt options. I haven't been able to find a 12.9 e torx bolt. I can get hex socket cap screws.
Most likely will be switching to Vorshlag since the Millway uniball will require a different adapter for the Ohlins shock and not being able to change to 2.25 or 2.5 spring.
aerobod4254.50
      03-12-2024, 08:23 AM   #11
GenXG87
GenXG87's Avatar
218
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
Dang. I appreciate the info. I think that is what I'm going to do. I know their spec options even ask for what strut so I feel comfortable knowing the fitment will work.
      03-22-2024, 11:25 PM   #12
kevinG87
kevinG87's Avatar
Drives: g87 m2
Thank you for the informative post. Can you let me know which spring diameter (2.25, 2.5, 60mm or stock/sport spring?) I should pick for the Vorshlag? I am on Ohlins R/T.
      03-23-2024, 05:28 PM   #13
GenXG87
GenXG87's Avatar
218
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
My new Vorshlag plates are arriving this week. This is what I got coming. At some point I may change out the springs and perches for a 2.5” spring setup.
      03-23-2024, 09:39 PM   #14
kevinG87
kevinG87's Avatar
Drives: g87 m2
Can you do a detail review and fitment? I really want to go with your setup.
GenXG87217.50
      03-24-2024, 10:01 AM   #15
GenXG87
GenXG87's Avatar
218
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
Sure thing. I’ll do my best to get some good pics. Not sure if I’ll have time to get it on a lift so it may be floor jacks and jack stands to swap them out.
      10-25-2024, 08:32 PM   #16
yoon_209
Senpai
yoon_209's Avatar
Drives: 24' M2
Any review on the vorshlag? I hear they make clicking noise but want to hear from your experience?
I'm between these or millway or groundcontrol
IG: it.g.ma_g87
Search this Thread:
Advanced Search
