03-30-2024, 08:41 AM | #1 |
Rep 4
Dealer Break-in Service or Joy Ride?
Took my G87 in for the 1,200 mile break-in service. When I picked it up I noticed that both seats were way out of position, very low and pushed back. When I checked the app, I see the following: 3.6 miles, 12 minutes, 17.9 mph average and 11.5 mpg.
Is it standard practice for dealers to take cars out for "test drives" for a standard service like this? Curious about other member experiences. |
03-30-2024, 09:02 AM | #2 | |
Rep 480
03-30-2024, 09:31 AM | #3 | |
Rep 1,853
But is a drive after 1200 mile break-in service standard practice? I don't know. But I looked through my service history file of my 2023 M2. 2023/01/05: Oil/filter service. Odo: 647. Miles driven: 0 2023/05/31: Break-in Service. Odo: 1204. Miles driven: 3 2023/06/07: Tire repair. Odo: 1636. Miles driven: 9 2023/07/26: Tire repair. Odo: 3216. Miles driven: 4 2023/09/21: Oil/filter service. Odo: 4833. Miles driven: 2 2024/03/19: CBS service. Odo: 7196. Miles driven: 3 And my 2024 BMW 230xi. 2023/12/13: Oil/filter service. Odo: 624. Miles driven: 0 2024/01/13: Oil/filter service. Odo: 1799. Miles driven: 1 2024/03/15: Rear tire replaced. Odo: 3259. Miles driven: 4 In the case of the M2 and the break-in service a bit of a road test might be called for. As for the two tire repairs, I imagine the car was driven after to confirm to some suitable level of confidence the repair was good, the tire was able to hold pressure. The 2 miles after an oil/filter service is well not that onerous. And the 3 miles after the 1st CBS service (due on time not miles) again a bit of a road test might be called for. The 230xi didn't get driven that much after two oil/filter services. But it did get driven 4 miles after a rear tire was replaced due to a puncture. Run flat tire but I didn't drive it flat. I aired it up to nearly 36psi before I drove the car 5 miles to the dealer during which time it lost 5psi. The amount of air it lost in that short time/drive suggested the puncture was severe. (I had both rear tires of the M2 repaired by both tires were losing just a psi or so every few days.) I agreed with the SA's recommendation to replace the tire rather than repair it. Fortunately the other tire's tread depth was still enough that the other tire didn't have to be replaced to keep the tread depth of the two tires within spec: 30% or less tread depth difference. |
03-30-2024, 11:39 AM | #5 |
Car Geek
4383
Rep 4,011
Driving after a tyre repair is probably to get the tyre pressure monitor to reset and show all pressure are correct, to avoid customer complaints of a warning light on the dash.
03-30-2024, 11:49 AM | #6 |
Rep 776
03-30-2024, 01:48 PM | #8 |
Rep 1,897
No, they just give the car back to you without checking any of the work they've done.
03-30-2024, 02:11 PM | #9 | |
Rep 1,753
Drives: 2020 X3MC
03-31-2024, 01:18 AM | #10 |
Rep 4,473
2024 BMW M2 Toronto Red 6MT
(Sold) 2020 Ford Mustang GT 6MT PP1 444rwhp 2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk, 2001 BMW M3 |
03-31-2024, 02:19 AM | #11 |
Rep 493
The cars been out for a year now - almost everyone who wanted to take it out for a spirited drive already has by now. Think you're okay. Enjoy it!
03-31-2024, 04:16 AM | #12 |
2JZ-GTE
3188
Rep 4,177
no wash, no driving, no ECU updates.
03-31-2024, 09:03 AM | #13 |
Rep 1,853
03-31-2024, 09:07 AM | #14 | |
Rep 1,853
The car gets vacuumed and maybe the driver's seat is moved but I have seat position tied to the key and the seat is correctly positioned when I get in the car. |
03-31-2024, 09:20 AM | #15 | |
Rep 1,853
Standard operations performed at each scheduled service Maintenance work Verify the Check Control messages. Check the Indicator and warning lights. Reset the CBS display. Inspect the tires, adjust the tire pressures and reset the Tire Pressure Monitor. Check the parking brake functionality while the vehicle is being driven into the workshop. 1200 Mile Running-in Service (RIS) Maintenance work Change the engine oil and oil filter. We recommend Original BMW Engine Oil SAE OW-30 fully synthetic, PIN 83 21 5 A2A F99 Change the fluid in the rear axle differential. Deactivate the 1200 Mile RiS via diagnostic path Under Maintenance Work: Tires - check the tread depth, wear pattern, outer condition, and inflation pressure. If necessary, correct the pressure. Reset the Tire Pressure Monitor. Final Inspection - road test with check of: Steering Shock absorbers (visual) Transmission |
03-31-2024, 01:38 PM | #16 |
Rep 1,671
Won’t speak to other dealers, but my Arizona tech, at the 1200 mile service, shot a video while the car was on the lift.
He pointed out every inspection area in the 3+ minute video which was emailed to me prior to checking out at the front desk. Gotta love that. |
03-31-2024, 02:39 PM | #17 |
Rep 1,052
Mine did the same. Sent a link to the vid. Basically a walk through inspection. AZ also but this was Chapman Chandler I think you said yours was North Scottsdale?
03-31-2024, 03:54 PM | #18 |
Rep 1,011
Sometimes a road test is needed for verification. If diff fluid was replaced I could see a need for a quick drive to get it worked in. A few miles could literally be around the block depending on traffic pattern.
04-01-2024, 10:30 AM | #19 | |
Christmas Poo
1664
Rep 1,432
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
