BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      08-27-2024, 08:00 PM   #1
apez
Drives: BMW G87 M2, F25 X3
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
How can I clear check tire pressure warning (pressure is fine).
Hey folks so after a autocross day my car is not happy with my tire pressure. I guess I was letting air out to often and it thinks I might have a leak. I don't.
Tire pressure holding steady at 32f 34r, but I have the same warning m every time I start the car along with the persistent "i" symbol.
How can I clear this?
      08-28-2024, 01:58 PM   #2
WhiteRqbbit
Drives: BMW M2 G87
Mine has started to do the same. It keeps telling me to check, but I have been just ignoring it, haha.
      08-28-2024, 04:36 PM   #3
vranko
Drives: G87 M2, A90 Supra
Same. After a low pressure condition (seems to be triggered below set pressure by ~5psi) the warning doesn’t clear even after adding air. It’s been happening to me after every autocross. I always have to go back to tire setting and do a reset.
Vehicle Status —> Tire Settings —> Perform Reset
      08-28-2024, 04:38 PM   #4
apez
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
Good to know a reset fixes it. Any specific conditions need to be met for a reset?
vranko113.00
      08-28-2024, 05:23 PM   #5
vranko
Only to set your cold pressures to where you usually keep them. You also need to be at a stop to start the reset then drive for a few minutes. It will count up to 100%
      08-29-2024, 12:06 AM   #6
nype
nype's Avatar
Drives: BMW M240i / BMW X5 35d
What does the myBMW app show regarding recommended and current pressure?
Do you have the corrrecf tire type / size set in iDrive?
      08-29-2024, 06:30 AM   #7
apez
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
I hadn't looked in the app, but same thing I get every start (note this temp is from the end of a drive, cold they are 32f/33r).
Again, I am not actually loosing pressure. I just adjusted it a lot over the course of a day or two for autocross.
nype163.50
      08-30-2024, 02:06 PM   #8
JABCAT
Professor
JABCAT's Avatar
4152
Mine randomly gives me a low pressure warning when they are at the correct pressures. I hit perform reset and don't even get down to the end of my street before the warning is gone & everything's back to normal. I never look at the app.
      09-14-2024, 12:13 PM   #9
ScottyRyan2019
Licensed Professional Slacker
ScottyRyan2019's Avatar
Drives: 2024 M2 and 2025 i4 M50
  [10.00]
  [10.00]
2024 BMW M2  [9.50]
Mine did this constantly after swapping TPMS onto new wheels. Kept tires aired at door panel 32PSI. I would perform reset and next day back to the same. So i I went and aired up to 35 PSI and problem went away
2024 M2 and 2023 Mazda CX-30
      09-14-2024, 12:14 PM   #10
apez
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
To update, I did do a reset and have not seen the same error again since.
Search this Thread:
Advanced Search
