11-10-2024, 09:22 PM | #1 |
Rep 2
I'm Between JRZ, Nitron or KW 2 way suspension any Rec?
Hello,
As I progress with building a fun full-time track car, I'm Between JRZ, Nitron, or KW 2-way suspension. Is there any feedback as to what people are using now? |
11-11-2024, 10:32 AM | #2 |
Keep Up the RPMs
1347
Rep 535
Drives: M3CS
Since this would a full-time track car, spend the time and money on 3-way shocks. For such use, I think 3-way shocks make usable difference. I would recommend you put MCS into your list as well. Additionally, the support you will or not receive from the vendor, and manufacturer, are crucial, so pick a shop that specializes on BMWs and knows how to setup the chassis and provides good post-sales support.
There is much to be learned in these threads that are applicable to any chassis: https://f80.bimmerpost.com/forums/sh....php?t=2141229 https://f80.bimmerpost.com/forums/sh....php?t=1934108 https://f80.bimmerpost.com/forums/sh....php?t=1916726 https://f87.bimmerpost.com/forums/sh....php?t=2125130 https://f87.bimmerpost.com/forums/sh....php?t=2051671
Cheers,
BoB |
Hit_Apex3081.50 |
11-11-2024, 11:47 AM | #3 | |
Rep 672
If you want to simplify, call Bimmerworld and have them set you up with a proper MCS kit. Its worth having them behind this (for questions such as what should be my baseline comp/rebound setting, what ride height should I set it at, alignment, spring rates for aero/non-aero etc.). Just my humble opinion. Had good experience with JRZ in the past (purchased through Bimmerworld) and KW Competition (custom valved Clubsport with camber plates). Cheers |
BackOnBlack1347.00 |
