11-16-2024, 06:29 PM | #1 |
Rep 2
New, Need some advice/info Exhaust mod
Been thinking about getting my center section of the exhaust removed so its a straight pipe flowing into a twin pipe from the downpipe to the back box.
I've been to a reputable company who did the inspection and couldn't guarantee the car wouldn't go into limp mode because of the change in exhaust pressure etc. and the car being basically brand new. its a 2024 240i xdrive with all the new interior, new software... Has anyone done this yet? did they have any issues? I don't want to map the car or do anything else really power wise just wanting a bit more noise... UK spec car also for info Any help is much appreciated Thanks |
11-16-2024, 08:34 PM | #2 |
Rep 2,560
Don’t know the answer to your question but that exhaust part is described as “ RP Gas.particulate Filter W.front Pipe”. *If* it contains the filter, removing it is illegal.
My only question would be why? |
11-16-2024, 09:54 PM | #3 |
Rep 2,148
Taking a shot in the dark here but my guess is sound + flow improvement.
11-17-2024, 03:42 PM | #4 | |
Rep 2
I know some people have tried using a an mil sensor to trick the ecu into thinking it still there but have seen some other places can still make the car go into limp mode without a map |
11-20-2024, 03:12 PM | #6 |
You got my money?
4043
Rep 5,044
Drives: Ice Cream Truck
Sounds like a typically custom made midpipe to me. Which in the M2, it will not throw a code. So I dont see why it would on a M240I but dont take my word for it. I have no 240i experience.
2025 G82 M2 6MT /// 2025 X5 40i X
11-20-2024, 05:38 PM | #7 |
Rep 2,560
11-20-2024, 05:42 PM | #8 |
Rep 2,148
Yesterday, 10:18 AM | #10 | |
Rep 114
Drives: (G42) m240ix
If you're just looking for a bit more noise, I think a high flow downpipe (Active Autowerks) and a performance axel back muffler (Dinan, MPE, etc., hell even a muffler delete) is going to be more bang for your buck. Blasting out your entire midpipe seems extreme, and without a FEMTO tune I'd really question what kind of gains you'd get anyway. Without doing any kind of research, modifying back pressure may lead to worse engine performance in certain cases. BMW has likely optimized backpressure to some extent and you may not want to dramatically mess with this unless you understand the change you're making. This is something you need to consider. This is, of course, ignoring that you're in the UK which, if I'm not mistaken, already comes with a lower emissions version of the US variant. Tighter emissions in the UK doesn't change the above advice. For the sake of dollar efficacy and not dealing with possible limp mode you can't tune out due to post 2020 DME lock, I would just go with a down pipe and axel back modification as this is going to orders of magnitude easier to deal with and for which tons of documented experiences exists. Granted I've seen documented experience of mid pipe replacements on F series m240s without any consideration for limp mode activation, so maybe it's just your exhaust mechanic trying to cover their ass. If that isn't enough sound for you there's always the infamous obnoxious maxed out popcorn/snare drum tune where you FEMTO unlock and slide your fuel over-run time window all the way to the right.. which all I can advise in that case is "enjoy responsibly" and consider how much your neighbors will hate you at 6 AM. |
Pentland2165.00 |
