BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      10-22-2024, 09:52 AM   #309
CadolinaRipr
CadolinaRipr's Avatar
446
Drives: BMW M2
r33_RGSport or any others...
Any way to experiment easily between the G80 and G87 maps on the Racechip?
Just a curiousity.
Lost2386.50
r33_RGSport13907.00
      10-22-2024, 12:22 PM   #310
Angmar
Angmar's Avatar
Drives: G87 M2 2024
Originally Posted by JMcLellan View Post
I did a bit more driving today and switched between Maps 3,4, and 5. In 1st and 2nd gear (my car is 6mt) I'm feeling some shaking/hesitation as it revs up. I assume that is the traction control/LSD doing it's job to maintain traction? I did some rips in both DSC on and MDM mode. I did not try turning traction off, or turning off MDM and setting the 1 thru 10 traction scale on the low end.
It feels like traction control doing it's job but wanted to see if others have had similar symptoms where there was maybe clutch slippage. I assume that should not be a concern with running those maps. My car is completely stock aside from the racechip.
That is for certain traction control kicking on… put it on level 3 or 4 and it will allow a bit more wheel slip without letting you get squirmy.
JMcLellan2975.50
r33_RGSport13907.00
      10-22-2024, 12:27 PM   #311
Angmar
Angmar's Avatar
Drives: G87 M2 2024
Just a curiousity.
I mean you really only have 2 options buy 2 race chips a g80 and g87 or have it reprogrammed after testing the first setup.
r33_RGSport13907.00
      10-22-2024, 12:32 PM   #312
CadolinaRipr
446
Drives: BMW M2
I want option 3. The ability to reprogram/flash myself to switch back and forth. Didn’t know if that was somehow possible.
r33_RGSport13907.00
      10-22-2024, 12:37 PM   #313
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
You can switch it back and forth by sending request to whichever reseller you purchase it from.
Just remember, you only get 1 time free reprogramming within 2 years of ownership when purchased new, then $149 per reprogramming.
If you want to reprogram the module yourself, you will need to be investing a lot of money with them to have the tool and access to reprogram, like what I have.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for everyday DEAL!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • CSF • SPL and more...
Accepting - Visa, MasterCard, American Express, Discover, Paypal, Venmo, Cash App, Amazon Pay, Affirm.
      10-22-2024, 01:40 PM   #314
Angmar
Angmar's Avatar
Drives: G87 M2 2024
Honestly as soon as you drive with the g80 mapping your not gonna want to set it back to the g87 tuning anyway….The difference is that big and you always can just run one of the lower maps if you want to tone it down.
      10-22-2024, 09:29 PM   #315
V series
Drives: 23 M5 & 24 M240i
For those running the G80 tune, are you auto or manual?
      10-22-2024, 09:31 PM   #316
Angmar
Angmar's Avatar
Drives: G87 M2 2024
I have the auto.
      10-22-2024, 10:20 PM   #317
LeggoRacing
LeggoRacing's Avatar
397
Drives: M2
I have the auto.
Any videos of the car doing pulls? I just wanna see it 🥂
      10-23-2024, 07:25 AM   #318
Angmar
Angmar's Avatar
Drives: G87 M2 2024
Sorry no but I drove it to work today so if I can make a video doing a pull on the way home without dying I’ll get one for you.
      10-30-2024, 09:05 AM   #319
Der Doktor
Drives: BMW M2 2025 auto
Hi everyone, I curious about data-logging the racechip.
Does anyone have experience with OBD data-logging?
I'm curious to see, if you could run map 7 with healthy values for the usual indicators, like timing, throttle position, WGDC, AFR and so on.
My ideas is to identify the highest map for the fuel I use, that has the car still running with healthy values.
I saw the datasheets from racechip's own dyno-testing, they used 102 RON and added 10% ethanol, to reach their top performance figures.
So this clearly tells me, that some timing must be pulled on map 7, maybe to an unhealthy degree.
I got the new 480 PS 2025 M2, unfortunately racechip doesn't have an offer for this model yet.
Also got the MHD Monitor License to do data-logging.
When possible I'll do my own testing and will be happy to share results.
Now I'm mostly curious if anyone did proper logging with the racechip installed.
      10-30-2024, 12:15 PM   #320
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
The race chip does not offer data logging, so if you want to do that, you will need to use a third-party data logger. im not familiar with these products as I would use the Jb4 if I want a tuner that can datalog.
https://x-ph.com/sale/
Phone number 702-494-9435
      11-05-2024, 03:34 PM   #321
Dave07997S
Dave07997S's Avatar
1480
Drives: 2024 BMW M2 Toronto Red 6MT
Hey guys what map can you run with the OEM clutch before it starts to slip?
(Sold) 2020 Ford Mustang GT 6MT PP1 444rwhp
2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk, 2001 BMW M3
      11-10-2024, 09:11 AM   #322
Angmar
Angmar's Avatar
Drives: G87 M2 2024
Assuming your clutch is low miles and in good condition I doubt it will slip on map 7. However, it’s going to for sure significantly increase the wear rate. I saw one guy on here with only 600whp and already had clutch slip at 7300 miles. The fact that BMW was concerned enough about it to derate the engine on the manual M2,3 and 4 to protect it says a lot. I guess it depends how well off you are….If you can’t afford to potentially have to replace the clutch early then maybe stick to the lower maps. Obviously a lot of it is how hard you drive it as well. I see a lot of g82\80s on the road being driven slower than I drive my grand Cherokee lol….
      11-18-2024, 05:49 AM   #323
zjldmd
zjldmd's Avatar
101
Drives: 2023 M2 & 2023 M8C
  [0.00]
Installed the Race Chip - ‘23 Automatic
Highly recommend getting/using:
1. Long flathead screwdriver - to unlock the little white tab on connector A
2. Long 90 degree pick tool - to get underneath connector A clip (where little white tab is). Once I used the long pick tool, stock connector A slid right off.
3. Long hemostats (purchased @ Harbor Freight). This was very helpful in reconnecting the female Race Chip connector A to the stock (removed) male connector A - I do not have small hands.
The other connections (B & C) are easy.
Short drive + butt dyno = big difference on highest settings
As others have done, I mounted the Race Chip under the cover where master cylinder is. I did have to unplug the electronic suspension plug to route the cables.
Lost2386.50
BroDoze2495.50
r33_RGSport13907.00
      11-27-2024, 12:33 AM   #324
ToneM2
You look like you're doing surgery
zjldmd101.00
      11-27-2024, 12:53 PM   #325
mike@x-ph.com
      11-30-2024, 03:15 PM   #326
Crazyotter
General Patton
Crazyotter's Avatar
462
Drives: 2023 X5M/2025 M2
I’m picking up my M2 in January and RC is going to be my first upgrade for her.
Just wanted to confirm that I can/should put a 2025 G80 RC tune on it and it’ll work perfectly.
Besides the rear wheels breaking loose a lot easier, have there been any other drivability issues?
      11-30-2024, 03:47 PM   #327
Angmar
Angmar's Avatar
Drives: G87 M2 2024
I haven’t had any issues at all for my part. As far as can you I would say yea but should you is up to you.
      11-30-2024, 05:12 PM   #328
Crazyotter
General Patton
Crazyotter's Avatar
462
Appreciate the quick response. I think I should lol
      12-01-2024, 11:09 AM   #329
mike@x-ph.com
why not get a G87 specific RC since you have an M2?
      12-02-2024, 10:37 AM   #330
Crazyotter
General Patton
Crazyotter's Avatar
462
For whatever reason RC is only adding like 88hp and 60lb of torque for the G87 tune but around 140hp and 110lbs for the G80 tune.
Sounds like the M2 can handle the extra hp so unless someone has a good reason to NOT do it, that’s my plan.
I’m assuming that the G80 Base tune is the best option since they have matching hp
