BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      02-04-2012, 03:38 AM   #23
IntegraXTR
Drives: MY08 E92 M3 and MY15 F80 M3
Just used this method recently, worked like a charm!
2008 Alpineweiss III E92 M3
Amuse/Varis/CAE/BBS/BRIDE
IG: Integraxtr
      02-04-2012, 09:55 AM   #24
Pauldramos
Pauldramos's Avatar
Drives: Dinan '11 M3
Awesome! This worked like a charm. Don't be afraid to pull with force because that is what it needs... One of the most helpful posts. Thank You!
      02-08-2012, 06:42 PM   #25
NELSON.MLGB
NELSON.MLGB's Avatar
Drives: 2010 E92 JB M3
wat is the part number?
      04-13-2012, 03:19 PM   #26
kwike92
kwike92's Avatar
Drives: 2014 M5 CP
nice job! i was too scared to scratch my paint, no i pulled the front wheels off and popped the fender liner and for the passenger i had to drop down the washer fluid resv.
2014 M5 Comp Package.
      04-29-2012, 11:08 PM   #27
Waynedude
Drives: 10 M3 Vert
Awesome DIY! I just got the OEM black chrome grills/gills and following this I did all in 20 min! Your tape idea was perfect and worked like a charm. Thanks man!
      06-04-2012, 08:34 PM   #28
AlexTek
AlexTek's Avatar
11
Drives: BMW M3 E92 2011 ZCP
Hey man thanks! You've saved my fender...
Placing a screwdriver between the gills and the fender, will damage the fender easily.
Change them in less than 5 minutes... Piece of cake with your method.
Things needed:
Tape 3M clear for boxes
Your 2 hands
THanks!
BMW M3 E92 2011 ZCP 6MT
- Upgrades:MS Stage 2 Intake + Turner Test Pipes + BPM Stage 2 Tune with Coding; Fox Red Novillo/Carbon Leather/Competition Package/Premium Package 2/Convenience Package /Enhanced Premium Sound/Satelite Radio
      07-10-2012, 04:43 PM   #29
Peahi
Peahi's Avatar
13
Drives: 2012 M3 CPE
Man! Awesome DIY!!! Thanks!!!
I followed your instructions and kapow....all done with both sides in under 15 minutes....then I changed the grills, also under 15 with the other DIY here.
So easy. Cal from MS Sonic said the hardest part was just pulling and the sound it makes...he was so right. The tape method makes it very easy.
      07-10-2012, 09:36 PM   #30
AlexTek
AlexTek's Avatar
11
Yes this method rocks big time. BMW should include this method as instructions with a set if Gills.
      10-11-2012, 06:54 PM   #31
MasterP
Drives: All the M's
This was great! Took me less than 20 seconds for each side.
      10-11-2012, 06:59 PM   #32
BimmerM
BimmerM's Avatar
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
2013 BMW X5 M  [0.00]
2011 BMW M3  [0.00]
Awesome, glad it worked out for you.
      10-13-2012, 03:14 PM   #33
ERinEC
Drives: '11 AW E92 M3
Worked as advertised for me as well. Thanks for the write up!
      10-16-2012, 12:34 PM   #34
dadealus
Drives: 13'E92 M3
Worked perfectly thanks
      12-02-2012, 12:10 PM   #35
Weechard
Drives: 2013 MW m3
Thanks for the write up. I'm going to give this a shot
      12-13-2012, 06:59 PM   #36
1LRM3
1LRM3's Avatar
Drives: LRP M3 E92, MR M3 E93
2013 BMW M3  [8.00]
+1
      12-17-2012, 03:40 PM   #37
Bonziii82
Bonziii82's Avatar
Drives: Frozen White 24 M3 CS
Thank You!
      12-24-2012, 09:32 AM   #38
dreamspeed
dreamspeed's Avatar
Drives: 6MT
This worked great, you might have to use more force then you think though
      01-11-2013, 05:27 PM   #39
aitsu
Mmmmm.. torque....
aitsu's Avatar
Drives: Imola Red F80 M3
Thanks for this. I just used both of your DIY's to do the side gills and grills.
Grills (which I did on my e92 335i) are still a bit of a pain in the ass, but the gills were pretty painless with this method.
2018 Imola Red F80 M3 ZCP
2016 Yas Marina Blue F82 M4 ZCP
2011 Le Mans Blue E92 M3
2010 Le Mans Blue E92 335i
      02-03-2013, 10:31 PM   #40
Zeus69
Zeus69's Avatar
Drives: 2011 E90 M3
An earlier reply in this thread said that Side Gill removal on the E90 is harder than the E92/93. Will the "tape" technique work on the E90? Has anyone tried it successfully?
      03-12-2013, 01:09 AM   #41
andv1
Drives: 09E90 SG/FR 6MT
Just to add, I successfully used this tape method to remove and replace my side gills on my E90. As some have stated, tape it, use one hand to pinch the gills as best as you can while you grab the tape and give it a pretty good solid tug (I know, I know). Reference your new gills for tab placement and reference points for squeezing.
      04-07-2013, 12:47 AM   #42
scm6079
scm6079's Avatar
Drives: '16 M3, Lotus Exige S260
After struggling for a bit to figure out how to get the gills off I came across this post -- it worked perfect! Thank you SOOOOO much for the DIY and videos. Exactly what I needed.
-Scott
      04-07-2013, 07:25 AM   #43
AlexTek
AlexTek's Avatar
11
-Scott
+1
      05-19-2013, 06:55 PM   #44
skidmarq
Drives: 2015 F82 M4
...and yet another "thank you" for the detailed instructions. This made the install a breeze...
m3post
