BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      10-27-2024, 12:20 AM   #23
aerobod
Car Geek
aerobod's Avatar
Originally Posted by BroDoze View Post
How do you guys feel about spacers with little or a lot of surface area? The high-dollar lightweight ones have huge openings on them for weight reduction. This leaves much less mating surface area. Does that mean more or less bite/clamping? Or, does the smaller surface area bite that much harder into the other surfaces?
Friction is independent of surface area of a solid material (as long as the material doesn’t deform or lose integrity), so the clamping force and consequent total friction force will be the same. Basically half the area and twice the pressure on that area leads to the same friction.
IanH170.50
      10-27-2024, 12:37 AM   #24
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2025 G87 M2  [9.83]
Shocked no one’s mentioned anything about scrub radius.
Spacers increase it. It’s not necessary a good thing. Most will notice the steering feels heavier after installing spacers.
I run spacers. But there are drawbacks to it. A couple positives too. But it’s not ideal.
https://suspensionsecrets.co.uk/why-...heels-spacers/
2025 G82 M2 6MT /// 2025 X5 40i X
      10-27-2024, 07:59 AM   #25
IanH
Drives: '25 M240xi
Like I said in an earlier post, anything inside of like 25mm you're not significantly affecting the scrub radius
The discussion on scrub radius really comes into play when you are changing both the offset and wheel width by large amounts.
2025 M240i Xdrive TNM/Cog - On Order
aerobod4222.00
