03-23-2023, 05:03 PM | #23 | |
Rep 1,272
Fyi the car incorporates alot more steel than aluminum . If you take a look at the technical diagrams you can see for yourself. Most the suspension of an M car is not aluminum , contrary to what most people believe.
///M3 2024 G80 Competition - Starting Lineup
///M4 2016 F82 Competition , 2019 G30 540i , 2008 E92 335i - Retired { Psalm 71:1-24 } |
03-23-2023, 05:08 PM | #24 | |
this is the way
19934
Rep 8,933
BimmerFix1783.00 |
03-23-2023, 05:15 PM | #25 | |
Rep 1,272
I’m constantly learning something new everyday just by interacting with you good folk. I just know metal , that’s about all my expterise extends too. A complete rookie when it comes to car geometery & suspension.
Tag19933.50 |
03-23-2023, 05:20 PM | #26 |
this is the way
19934
Rep 8,933
OK, I see the discrepancy is with it not being labeled properly. I added numbers next to the bullet point so you can see what's what. What they refer to as 'front struts' are nothing more than the front V part of the strut brace.
One cool thing about this is that the aluminum brace in the pictures above actually extends all the way to the firewall and back to the other side boxing everything in. Last edited by Tag; 03-23-2023 at 05:44 PM.. |
03-23-2023, 05:33 PM | #27 | |
Rep 1,843
Edit: nine numbers* Last edited by zero21; 03-23-2023 at 05:41 PM.. |
Tag19933.50 |
03-23-2023, 06:06 PM | #29 | |
Rep 1,012
03-23-2023, 06:21 PM | #30 | |
Commander-In-Chief
2366
Rep 9,019
M2 technical manual
03-23-2023, 06:51 PM | #32 |
Retired Major
1062
Rep 763
Anyone knows if modern BMW platforms have rear subframe issues (looking at you E36 and E46)?
2023 G87 ///M2 (production began Jul 4th 2023) 2008 E90 335i | Silver Grey | Terra | Piano Black | 6MT | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | |
03-23-2023, 06:59 PM | #33 | |
Rep 3,615
I have not heard about it in quite a while, but that does not mean if you are tracking the living $hit out of it that it is not going to happen. Last edited by T_U_D; 03-23-2023 at 07:11 PM.. |
Albator_IIII1062.00 |
03-23-2023, 07:24 PM | #34 |
Rep 347
So the additional bracing is basically the same setup that's used on the G80/G82 then correct? It is using the entire front end? If it works for the M3/M4 then all the better. They mentioned in the video about dampers and other suspension parts having same part numbers.
03-23-2023, 07:38 PM | #35 | |
Rep 3,615
03-23-2023, 08:19 PM | #36 |
Rep 1,843
Read back through the press material at launch and there's a whole section on this. I'm not sure how I read right through that and didn't pick it up.
03-23-2023, 08:25 PM | #37 | |
Rep 1,272
Maybe he can shed some more light , i’d like to see the full document as well.
zero213276.00 |
03-23-2023, 09:17 PM | #38 | ||
this is the way
19934
Rep 8,933
There was also a technical training doc posted for the previous gen F80/2, but I never saw one for the F87 ever materialize. Only someone with access to the G87 version (if it even exists) would be able to post it. Until then all we have is the G80/2 one to go by. |
GregW / Oregon2365.50 |
03-24-2023, 08:39 AM | #40 |
Rep 296
Here are the next 2 pages of the technical reference guide which is available on the M3 forum and a good read as I would assume a lot carries over to the M2. The first image index numbers are referencing the front end image posted earlier in the thread.
03-24-2023, 08:55 AM | #41 |
Rep 1,012
Are those brakes or chip clips?
Chet for short213.50 |
03-24-2023, 09:16 AM | #42 |
Rep 296
03-24-2023, 09:42 AM | #43 |
Rep 1,843
Uh, what? The rear brake caliper/pad is the only part of the braking system people complain about.
03-24-2023, 09:48 AM | #44 |
Ghostrider
195
Rep 142
Drives: M140iX,Z4M40i,M8 comp,M2g87
Braking will make the wheels dirty....
