12-08-2023, 10:48 AM | #24 |
Rep 154
I'm sure you're fine to shut the car off when you get to your destination. BMW engineers need to make these cars 'stupid proof'. If it was really bad to shut the car off right after some spirited driving we'd be hearing about all kinds of issues.
Lots of people do cool down laps at the track but the amount of times I have absolutely sent it on the last lap and then brought it right back into the paddock and shut the car off I can't even count. Enjoy it!!!!!! |
Geighty72684.00 |
12-08-2023, 10:59 AM | #25 | |
Car Geek
4255
Rep 3,902
With synthetic oils and cooled turbo bearings with an auxiliary electric pump that can operate after the engine is switched off, there isn't a problem. |
Geighty72684.00 |
12-08-2023, 11:21 AM | #26 | ||
Rep 1,236
12-08-2023, 11:26 AM | #27 |
Rep 2,536
Listen, at Thermal Raceway for the BMW M Driver's Package, my G82C had 800 miles on the clock and we were doing race pace laps. Did a couple of cool down laps (mostly for the brakes since the carbon ceramics started to squeal fairly loudly and off to the paddock to turn the car off. It's fine. These cars are over-engineered.
Also, I never buy used M cars for this reason lol. Always and I mean always make sure the first owner was not a "Demo" car out of SC or CA.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs:2020 M2C HS Executive, 6 Speed 2017 M3 YMB Executive, 6 Speed, ZCP Everything else: 2024 Wrangler 4Xe 2024 MK 7.5 GTI |
12-08-2023, 11:35 AM | #28 | |
Rep 1,236
I figured that any demo car has been driven hard early in its engine life at least a few times. And used is probably magnified to that point! Speaking of M Drivers Package- currently waiting for my email so I can sign up and go. It’s comforting knowing BMW has put so much into these engines. |
Bumpinjeep6206.50 |
12-08-2023, 02:36 PM | #30 |
Rep 1,236
For anyone who’s curious, this is what my maintenance looked like. Curious what the “1200 mile svc for M” consists of compared to a non M? Maybe non M’s don’t require 1200? Not sure.
12-09-2023, 07:56 AM | #31 | |
Rep 1,548
On my regular commute run I didn't engage in spirited driving. On road trips when it was time to refuel I'd leave the freeway but almost every time by the time I got the gas station pump the engine had time to shed some heat load. However, I'd use this time to check the oil level before shutting off the engine. There is the concern about the hot turbo hardware "cooking" the oil (even synthetic oil) in the turbo bearings. With car engines that will circulate oil possibly even coolant to help remove heat load from the turbo this helps alleviate the concern about the heat load in the turbos. However, the exhaust valves can only shed heat via low temperature running which is idle and the time they spend on their valve seats. Exhaust valves can run dull red hot when the engine is working. So even with car engines with post shut down oil/coolant circulation I still either give the car a chance to cool down by easy driving the last mile or two to my destination or give the engine a minute or so of idle time prior to shut down. |
12-09-2023, 08:05 AM | #32 | |
Rep 1,548
But I had the M2 in for an early oil/filter service (on my dime) at 647 miles. A multi-point inspection was done. (No charge for parts or labor.) Oil/filter change done and I was charged $124.62 for for parts plus $50 for labor. Tax added $16.59. Total cost was $191.21. |
Geighty72684.00 |
12-09-2023, 04:47 PM | #33 | |
Rep 1,236
12-10-2023, 05:52 AM | #34 | |
Rep 140
12-10-2023, 07:49 AM | #35 | |
Rep 1,548
The engine experiences break in just fine. Even as is often (always now...) the case synthetic oil is used. Years ago when I worked on my cars and even rebuilt 2 engines an early oil/filter service was SOP for newly rebuilt engines. And these were filled with regular oil -- the oil the engine was going to use for the rest of its service life -- and no break in additive was used. This is what my auto tech buddies told me to do and what I observed them doing when I assisted in their engine rebuilds. The only special lube used was at least with aftermarket cams the cam maker included a can of special grease to apply to the cam lobes to give them extra protection at initial engine start. And when assembling the oil pump the gears were coated with Vasoline to help ensure prompt gear pump priming. (Videos of engine assembly -- BMW, M-B, Porsche to name some of them -- show the tech using just a bit of oil at assembly time. Based on my experience not as much oil as I would use. But I believe the engines are spun -- cold and using an electric motor -- to among other things circulate the oil through the engine. When I rebuilt engines I used an electric drill motor and an adapter to spin the oil pump -- with the engine not turning -- to ensure the pump primed and then to continue to run the pump to fill all the oil galleys and bearings and until oil appeared at the valve hardware. (I did this with the valve covers off.) This insured that upon first start the critical parts of the engine would have oil from the get go.) So for my new vehicles unless the owners manual forbids it I change the oil/filter early. Between ~500 to ~1000 miles. Then again at end of break in: 1200 or with some cars 2000 miles; then again at 5K miles. For these early oil/filter services I do not have the service reminder reset. When that tells me the engine is due to be serviced I book the vehicle in for whatever service the reminder says is due which for my MINIs and BMWs has been primarily an oil/filter service. |
Searay55555381.00 Geighty72684.00 |
12-10-2023, 03:59 PM | #37 |
Rep 148
First time you roll into it in 3rd gear in a chilly morning and do a rolling burnout your life is forever changed.
-GT3M2 |
12-10-2023, 06:17 PM | #38 | |
Rep 1,690
Almost as irresponsible as flooring it all the way to redline in 4th gear on the highway. I would never do that either. Nope, not me, upstanding citizen. In Mexico. |
12-11-2023, 09:42 AM | #39 | |
Rep 298
Searay55555381.00 TorontoRedCoastie122.00 |
12-11-2023, 10:50 AM | #40 |
Rep 1,548
One tech claims the oil is special based on smell? A new engine stinks due to the amount of sealant used (which is replacing gaskets). These sealers are very pungent smelling. Just resealing a camshaft cover has the work area stinking to high heaven. But sealer applied to the camshaft cover(s), possibly intake manifold, oil pan/sump, front engine cover, the engine is going to smell to high heaven. And even though the sealer is applied by a machine which puts down just the right amount and in the right place still some sealant gets squeezed out into the engine. Sometimes one can see bits of this sealant in the oil drained from a new engine or bits in the oil filter canister oil or even caught in the filter element.
The BMW S58 engine training document does not have any warning regarding an early oil change. There is nothing in any owners manual (or factory service manuals) I've had access to that cautions against an early oil/filter service. This for BMW, M-B, MINI, Dodge, Porsche, VW, GM (Chevy/Pontiac), Ford, and Datsun/Nissan. And I almost forgot motorcycles: Yamaha, Harley and Honda. It has been my SOP for years to have the oil/filter service done early. This was what the professional techs told me to do. And what used to be the norm. Never had a service advisor or tech tell me the early oil change should not be done due to some special oil in the engine. Some service advisors balk at what they refer to a quick-y lube service because just the oil/filter service is not a high profit service but all have agreed to let it be done. In all the years I've never had a tech tell me the new engine oil is special. In fact I had professional techs tell me the opposite that new engine oil is not special. Well, it does need to be up to the task of lubing the engine over its service life. But beyond that... Too late for me but one with a new car/engine will its factory fill oil could obtain a sample of the factory fill oil at the 1st oil change and at the same time obtain a sample of the oil the engine will be filled with and have both of these samples analyzed. If the oils are different, have different additives, the analysis results will show that. |
aerobod4254.50 Kevin_The_Clean14126.50 |
12-11-2023, 11:11 AM | #41 | |
Car Geek
4255
Rep 3,902
It is also strange that a dealer would add Ceratec to the oil when the owners manual clearly states "Do not use oil additives. Oil additives can damage the engine". None of the non-M vehicles have a break-in oil service (such as for all B58 engines). In some markets the first oil change isn't until 2 years from vehicle delivery. |
deleted_807865_k0a0df9ee6877.50 Baller198.50 |
12-11-2023, 04:52 PM | #42 |
Rep 75
I’ve been slow with how I progressed the car to shifting close to red line…. Pre break-in period allowed me to get used to the car and I just slowly started shifting her higher and high as my miles built up.
Was at a gas station two days ago and the attendant was swooning over th car and asked if I could let her rip when I pulled out. First time I hit the limiter for a sec or two before shifting to 2nd but I have 1600 miles on her and feel safe doing it. |
12-11-2023, 08:29 PM | #43 | |
Rep 4,655
And those that are adding te Ceratech additives to your oil mix so early on in the engines life, why in the world would that be a good idea at this early stage... ? That part I really REALLY don't get. Fear based marketing is a curse. Last but not lease, a great rule of them is to keep is simple with the S58. Just because it's a stout engine & almost bullet proof doesn't mean to ignore common sense knowledge. Never drive a high performance motor hard & shut it off right away. The coolant will re-circulate with the engine off but not the oil. So... don't drive it hard & put it away wet.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
12-11-2023, 10:07 PM | #44 |
Rep 510
Drives: BMW G87 (2024),BMW E82(2009)-s
Now that you ask… the only difference was the blinker sound. It was extremely loud after the break-in service. They must have change the blinker fluid… not using it ever again!
