03-21-2024, 10:50 PM | #23 | |
Rep 7,526
From my experience with Carbotech 1521 on F87 M2C, you can't get everything. On my M2C, I had a scary period of zero bite in heavy rain in low temps with the CT1521 pads. The dust and noise was significantly better and I also liked the reduced bite in most conditions since those brakes are crazy overboosted. However, BMW / Brembo aren't dumb and they don't put dusty pads on just to annoy you. There are often some tradeoffs. The large surface area of these brakes demand a high mu compound to satisfy ECE-R90 tests in all conditions. I'm not saying the EBC Red or iSweeps aren't good options, they may be great for this platform, but no one else reported issues with CT1521 for F87C or F10 M5 either and I immediately noticed the difference in bad weather. |
deleted_807865_k0a0df9ee6877.50 aerobod4254.50 |
03-21-2024, 11:14 PM | #24 |
Rep 1,489
Based on Chris’ post I hope the Isweep pad switch is a good decision. The M2 is our Arizona car so low temps are infrequent and we don’t drive in the rain often. Retirement offers many lifestyle scheduling options.
In any case, I’ll post my thoughts after my local shop has completed the install. Meanwhile I’m still fighting a losing brake dust battle…….. |
03-22-2024, 12:49 AM | #25 | |
Rep 7,526
03-22-2024, 02:39 AM | #26 |
Mark 42
1105
Rep 730
The dust issue, was the worst experience of any car I’ve ever owned in 25 years and would consume my joy of driving the car knowing the aftermath cleanup ahead after a quick drive.
I Just had European Auto Source install the isweep 1500 pads on my car today. So far brake feel is identical to stock. I’ve driven 100 miles and my wheels still look black (stock pads turned my black wheels bronze brown within 25 miles). I will do a post/review with more pics asap. The pads still dust, but it’s not like the “cinnamon” like dust of the OEM pad. |
03-24-2024, 05:07 PM | #27 |
Rep 1,352
so can you or someone in the community explain the difference between the isweep 1500 and 2000? By your post it seems there is more dust with the 2000s than the 1500s. Are there anymore differences? Do the 2000s have better stopping power?
03-24-2024, 05:35 PM | #28 |
Rep 227
The cF on the 2000s is slightly higher then the 1500s. I understand the 2000s can handle a bit more heat while dusting a little more (still less than stock) while giving up some cold initial bite. I am in TX so we don’t see super cold temps. I won’t take the car out unless it’s 50 or above in winter here. Not my daily. I have cup2s so they get slick in cold weather. So far very linear pedal feel. Good modulation and no squeal coming to a stop.
chris7197598.00 |
03-25-2024, 01:35 AM | #29 |
Rep 7,526
If I get a G87 (my F87 comp just got totaled so I'm thinking about it), I will have a tough choice between Endless MX72 and IS2000. No one has run MX72 on this platform that I have seen yet and iSweep is very unknown outside of G8x forums. MX72 isn't the lowest dust thing either, but it's a known quantity.
04-01-2024, 02:42 PM | #30 |
Supreme Allied Commander
4091
Rep 55,812
Drives: F80 M3
Porterfield R4-S is an excellent option and shipping right now. It has been and still is our best seller on the F87 M2C. It's also made in the right here in CA, USA.
https://hpautosport.com/product/port...ads-g8x-m3-m4/ Last edited by HP Autosport; 04-01-2024 at 02:49 PM.. |
M_Power Rob4549.00 |
04-01-2024, 03:40 PM | #31 |
Rep 1,489
As a consumer with absolutely no financial interest in the subject, I highly recommend the iSweep 1500 brake pads if you’re replacing the OEM set.
I’ve noticed no difference in grip, stopping power etc. or whatever is the proper terminology, with a significant (emphasis) reduction in brake dust. Now, in all fairness, I don’t track and for the most part drive relatively civil compared to some of you guys. If you’re thinking about a switch, consider this product. YMMV |
Ronin761437.00 |
04-01-2024, 03:48 PM | #32 | |
Rep 1,352
04-01-2024, 03:59 PM | #33 |
Rep 1,489
PS, I forgot.
Absolutely no squealing, squeaking, screeching, squawking, or further alliteration. |
deleted_807865_k0a0df9ee6877.50 |
04-05-2024, 09:40 AM | #34 |
Rep 1,489
Update on the iSweep 1500.
150 miles on the new pads; wheels are still bright and clean. I resisted changing pads for 2500 miles anticipating less dusting after break in (no pun intended) but to my dismay it continued. Anyway, this was a great decision for me however…….. YMMV. |
chris7197598.00 |
04-05-2024, 04:22 PM | #35 | |
Professor
4231
Rep 2,833
04-05-2024, 04:33 PM | #36 | |
Rep 1,489
PrickyMcPrik29.00 |
09-17-2024, 10:12 AM | #37 |
Rep 96
Anyone running endless pads? What’s your experience with them? I’m Currently running EBC RP1 pads and not exactly happy with them. I do quite a bit of track driving (I live 45 mins from the Nurburgring and Spa) and also do a lot of high speed driving on the autobahn. I also don’t have the time to swap between pads for my sporadic trips to the Ring.
09-20-2024, 11:16 AM | #38 |
Rep 1,148
i have been debating switching out pads. my car is pretty new and not even at the 1200 mile break in. i do have aftermarket wheels that are silver and although they are ceramic coated my car always looks like it’s dirty cause of the wheels.
i was having issue justifying buying new pads as there are many other mods i would do first but i am now experiencing noises which is pretty odd for brakes this new. i have owned numerous M’s in the past and you can’t get away from noisy brakes but never had them start so early i’m debating from the tried and true isweep but also stumbled on PSI brakes and heard good things. they look to be the most expensive of the options out there |
