11-26-2016, 04:57 AM | #23 |
Rep 577
11-26-2016, 03:34 PM | #25 |
Rep 577
11-27-2016, 01:26 PM | #26 |
Rep 577
OK... I have to hold my hands up, I have made a mistake. I thought I had carried out 2 stock runs on the dyno and 2 runns with tunning box on but, I had never turned it off, actually I had not connected the remote switch properly so the system was full power.. Here is the dyno showing only the box on
11-27-2016, 01:44 PM | #27 |
Rep 577
OK... I have to hold my hands up, I have made a mistake. I thought I had carried out 2 stock runs on the dyno and 2 runns with tunning box on but, I had never turned it off, actually I had not connected the remote switch properly so the system was full power.. Here is the dyno showing only the box on. Ignore the stock header on the graph, all runs were full power
11-27-2016, 01:55 PM | #28 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Pretty interesting you got 388bhp stock.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
11-27-2016, 02:03 PM | #29 |
Rep 577
None of the runs were stock... The unit was permanently switched on.. The remote switch to turn the unit on off was not connected properly, my bad! So the 398bhp is the first run the rest I was suffering heat soak, seeing Temps up at 80deg c
11-28-2016, 12:25 PM | #31 |
Rep 577
12-10-2016, 02:07 PM | #32 |
IG @bmwF9xG80
3817
Rep 7,595
Drives: G80 M3, X4M, G07 X7m50
Any Dynojet shops?
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
12-10-2016, 06:55 PM | #34 |
Rep 2,577
Probably you should go back dyno it before you have IC & DP.
Lemania 2320
12-11-2016, 04:26 AM | #35 |
Rep 577
12-23-2016, 12:04 PM | #36 |
Rep 577
Done some runs back to the back
5th gear 60 - 80mph Stock = 3.8 seconds Stienbauer = 2.8 seconds Last edited by kiysersosae; 12-23-2016 at 01:04 PM.. |
12-23-2016, 08:29 PM | #38 |
Rep 577
12-27-2016, 10:54 AM | #39 | |
Rep 577
4th gear 60-80mph Stock was 3.1sec Stienbauer was 2.7sec That was with a full tank of fuel too. I also used my own stop watch this time just to clarify the meter I was using, it seems that the app is a little erratic so I went with the stopwatch times.. I done around 4 pulls with tune on and 4 with it off. Last edited by kiysersosae; 12-27-2016 at 02:28 PM.. |
12-27-2016, 03:54 PM | #41 |
Rep 577
Would be good if someone who has a tune doing some similar tests! I also just read evo mag and that tuned 40-60mph time in 4th that I pulled is the same as the new Audi tts time.
12-28-2016, 07:33 AM | #43 |
Rep 577
