      12-24-2023, 12:35 PM   #23
TheNine90
Drives: bmw
Originally Posted by Milk1010 View Post
Can this be done in BimmerCode?
No, will need esys for doing that.
      12-25-2023, 12:22 AM   #24
Milk1010
Drives: BMW 230i
Does your car give the same message when trying to turn off the lights while moving though?
      12-25-2023, 01:49 AM   #25
TheNine90
Drives: bmw
I havent tried that before.
      12-25-2023, 06:56 PM   #26
Milk1010
Drives: BMW 230i
Could you test it out and see if it gives you the same message
      12-27-2023, 02:23 AM   #27
TheNine90
Drives: bmw
Currently dont have a vehicle to test it with.
      01-03-2024, 09:31 AM   #28
PP3121
Drives: 2023 M240i
The way my house is set up the neighbors get mad when I back into my driveway with the lights on at night
Suggest some sun blocking shades/window treatments!
      01-04-2024, 08:28 AM   #29
PRINCE THUNDERNIGHT
PRINCE THUNDERNIGHT's Avatar
Drives: 2023 BMW M240i XDrive G42
Tell the neighbor to F off?
      01-04-2024, 09:06 AM   #30
Pentland
Drives: BMW M240i (G42)
Bit unnecessary.
Drive nose first into your property or, as the neighbour seemed polite enough to request rather than tell you to switch your f***ing lights off, just explain you’ve looked into this but it can’t be done.
      01-05-2024, 05:40 AM   #31
M2siast
M2siast's Avatar
Drives: A Family Sedan
2023 BMW M2  [9.67]
Why is it hard in the G42? It should be simple to do in BimmerCode. It’s not even an expert function. It should be right there.
What options do you see? I’m confused as to why it’s not showing up for you and people are saying it can’t be done.
      01-06-2024, 12:14 AM   #32
Milk1010
Drives: BMW 230i
The option to allow exterior lighting switch off is in BimmerCode however even with the setting set to allow the switch off it will still give a message saying that lights cannot be turned off while driving
      01-06-2024, 12:16 AM   #33
M2siast
M2siast's Avatar
2023 BMW M2  [9.67]
Did you choose in position 0 and A? (If I recall them)
      01-28-2024, 12:36 AM   #34
Milk1010
Drives: BMW 230i
Yes, I coded the option “in position A and 0” and whenever I press the off button while driving it gives me a warning message and doesn’t turn the lights off
      01-28-2024, 03:15 AM   #35
M2siast
M2siast's Avatar
2023 BMW M2  [9.67]
Bummer. Wondering why it works on the G87 and not on the G42…
      01-30-2024, 06:15 AM   #36
Milk1010
Drives: BMW 230i
On the G87 you can turn the lights off while moving with just that coding?
      01-30-2024, 06:17 AM   #37
M2siast
M2siast's Avatar
2023 BMW M2  [9.67]
Yes.
      01-31-2024, 08:09 PM   #38
Milk1010
Drives: BMW 230i
Yes.
So you have the automatic lighting control set in position A and 0 and the exterior light switch off allowed?
      01-31-2024, 08:10 PM   #39
M2siast
M2siast's Avatar
2023 BMW M2  [9.67]
LOL
      02-03-2024, 06:45 PM   #40
Milk1010
Drives: BMW 230i
LOL
Any other code you changed?
      02-03-2024, 08:08 PM   #41
M2siast
M2siast's Avatar
2023 BMW M2  [9.67]
Sorry man I thought it was funny that we were having the exchange about the same thing, so I went and double checked. The app says “to prevent the headlights from coming on while in off, switch to position A”
My car is coded to position A. Change yours from position A and 0 to just A, and it should work!
      02-04-2024, 10:33 PM   #42
Milk1010
Drives: BMW 230i
No worries dude. I changed my code to that and it still doesn’t work though don’t think there’s any other settings I’d be able to change unless I go into expert mode. Might just be something specific to the G42 but I’ve see people on other forums with the same question as me and nobody seems to have found a solution.
      02-04-2024, 10:43 PM   #43
M2siast
M2siast's Avatar
2023 BMW M2  [9.67]
That’s really strange!!!! I don’t understand why that is…
      02-05-2024, 09:12 PM   #44
Milk1010
Drives: BMW 230i
I’m just as confused as to why you can’t code in that function. I’d understand bmw not allowing to from factory but I’m surprised nobody has found a way to code it in.
M2siast5997.50
