09-21-2021, 01:49 PM | #52 |
BimmerPost Supporting Vendor
3890
Rep 54,576
Drives: F80 M3
AP1648
APF-40 Application: F87 M2 Competition ***Please allow 7-10 business days of lead time*** |
10-28-2021, 10:00 PM | #55 |
3890
Rep 54,576
Drives: F80 M3
Porterfield R-4 Racing Compound for your BMW M2 Competition
01-02-2022, 08:29 PM | #62 |
3890
Rep 54,576
Drives: F80 M3
R-4 Racing Compound
For over two decades, the Porterfield Carbon Kevlar brake pad has given racers abroad a definite world class friction material suitable for virtually any racing condition. Designed specifically for heavy duty motorsports, the Porterfield R-4 brake pad was our first and is our origi- nal Carbon Kevlar brake pad. Being able to maintain an average of a .50 friction level within a very wide temperature range gives the R-4 pad astounding versatility and makes it very suitable for a wide array of vari- ous track conditions. With use of the latest ceramic technology, the Carbon based semi- metallic R-4 materials allow the pads to absorb tremendous amounts of heat and dissipate it at a very even rate, while at the same time insulating excessive heat from calipers. Another inherent characteristic of our carbon kevlar material is how quickly the pads warm up to race temperature which is quite helpful during restarts, and when track time is limited. Optimum R-4 operating temperatures are 450oF and above. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the Carbon Kevlar material will give extremely consistent modulation and predictability smooth release characteristics up to thresh- old. Another benefit of our R-4 compound is that even with the high friction levels and broad temperature ranges, the unique properties of our compound allows the rotors life to be extended to the maximum. This is truly the most rotor friendly racing brake pad material ever. Road courses, oval track, rally, vintage racing, autocross, club events or professional racing events. Tested and raced in countless types of competition ve- hicles, the R-4 compound from the outset has established its reputation as a Championship winning brake pad material. |
03-08-2022, 05:46 PM | #66 |
3890
Rep 54,576
Drives: F80 M3
R-4 Racing Compound
For over two decades, the Porterfield Carbon Kevlar brake pad has given racers abroad a definite world class friction material suitable for virtually any racing condition. Designed specifically for heavy duty motorsports, the Porterfield R-4 brake pad was our first and is our origi- nal Carbon Kevlar brake pad. Being able to maintain an average of a .50 friction level within a very wide temperature range gives the R-4 pad astounding versatility and makes it very suitable for a wide array of vari- ous track conditions. With use of the latest ceramic technology, the Carbon based semi- metallic R-4 materials allow the pads to absorb tremendous amounts of heat and dissipate it at a very even rate, while at the same time insulating excessive heat from calipers. Another inherent characteristic of our carbon kevlar material is how quickly the pads warm up to race temperature which is quite helpful during restarts, and when track time is limited. Optimum R-4 operating temperatures are 450oF and above. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the Carbon Kevlar material will give extremely consistent modulation and predictability smooth release characteristics up to thresh- old. Another benefit of our R-4 compound is that even with the high friction levels and broad temperature ranges, the unique properties of our compound allows the rotors life to be extended to the maximum. This is truly the most rotor friendly racing brake pad material ever. Road courses, oval track, rally, vintage racing, autocross, club events or professional racing events. Tested and raced in countless types of competition ve- hicles, the R-4 compound from the outset has established its reputation as a Championship winning brake pad material. AP1648 APF-40 M2C application |
