03-11-2015, 06:48 AM | #67 |
![]() 1867
Rep 1,340
A lot of the guys on that corvette forum don't really seem to be standing up for the corvette like you would expect. They seem disappointed that the corvette couldn't deliver, or that it was advertised under false pretenses. I think a lot of people will be quick to jump on the fact that the GTR had octane booster, but they make a valid point that nissan explicitly advertises the Nismo to run on 93 octane in order to perform as advertised where as it seems like the corvette is unable to perform as advertised on 91 octane. So I think you can't really use that argument against the nissan. One of the members did some data tracking on exit speeds of both cars on the turns and the GTR is significantly quicker out of the turns than the corvette. The adjustments that GM will make to the corvette my improve the corvette's times, but I'm not sure if they'll ne able to overcome the acceleration the GTR produces on the turns.
03-11-2015, 08:02 AM | #68 | |
![]() ![]() ![]() ![]() ![]() 289
Rep 833
I knew from the beginning that something was going wrong with this test car as well. RP comments did not match other track reviews and it seems that the alignment in the rear is the cause of this. With the release of the A8 z06, you would think that MT would use that option when comparing to a DCT equipped competitor. Why not make the playing field even if there is an option to do so? Finally, I agree with your point about the octane and what the z06 is advertised as. But you know what, they also put in the manual that for optimal performance, run 93. So why neuter the z06 when you are putting octane booster into the GTR. Each of these circumstances alone do not have a significant effect but together can cause serious discrepancies. Chevrolet should have taken more steps to ensure a proper testing vehicle but isn't the job of MT to report fair and unbiased findings. I think the biggest fail is that MT did not do their due diligence when conducting such a high profile comparison. |
03-13-2015, 03:02 AM | #69 |
![]() 1867
Rep 1,340
i think you're putting too much blame on Motortrend. Historically, they have favored GM so it really makes no sense for them to make an effort to put the Nismo at an advantageous position over the corvette. (Think back to how they favored the zr1 over the GTR, as well as the z28 Camaro). 9/10, they use cars that they can get their hands on, so it is incorrect in assuming that they chose the MT version of the corvette in order to afford the GTR the advantage with its dual clutch transmission. Also, the difference between how the Nismo is advertised versus how the corvette is advertised is as follows. Nissan explicitly state that in order for the GTR to perform as advertised, 93 octane is recommended. GM however advertises the corvette as producing 650hp and 650ft lbs of tq with the use of 91 octane if I'm not mistaken. So really, we have one manufacturer claiming that in order to achieve 'X' performance levels, you must use 'X' fuel where's as the other manufacturer claims that 'X' performance can be achieved using 'X' fuel, however under a pretense of uncertainty. This scenario is no different than the fiasco that happened with the first generation GTR's launch control system. I think nissan learned something from that...finally, the responsibility of ensuring that a product's functionality is at its absolute best is largely at the hands of the manufacturer, not the medium by which the manufacturer uses to test and advertise their product.
03-13-2015, 07:49 AM | #71 | |
Rep 833
Nissan did learn, hopefully Chevrolet does as well. |
03-13-2015, 05:29 PM | #72 |
Rep 6,924
Motor Trend retested the Z06. Z06 in the GTR comparo had non oem rear caster specs for some reason, -2 degrees.
Carlos has new Z06 figure 8 video up on youtube. In comments section he mentioned Randy was much happier with the car with correct rear caster. He was quicker around Big Willow. Carlos also commented on how much better it was around figure 8. He completely changed his tune about the car, he absolutely loved it. Followup test should be up on MotorTrend soon, according to Lago. Last edited by hellrotm; 03-13-2015 at 11:22 PM.. |
03-14-2015, 02:59 AM | #74 | |
![]() ![]() 3526
Rep 4,540
UPDATED 3/14/2015 Last edited by DocWeatherington; 03-14-2015 at 04:53 AM.. |
03-14-2015, 02:08 PM | #75 |
Rep 6,924
03-19-2015, 12:20 PM | #77 | |
Rep 6,924
The manual Z06 was 2.1 secs quicker around Big Willow, beating the Nismo GTR by .70 secs. http://www.motortrend.com/roadtests/..._track_retest/ |
03-19-2015, 12:27 PM | #78 | |
Rep 833
03-19-2015, 01:14 PM | #79 | ||
![]() 862
Rep 3,385
03-19-2015, 01:19 PM | #80 | |
![]() 30
Rep 242
ffs did anyone actually read the article? to save face, GM optimized the alignment AND damping just to suit this particular track. and who knows what other mods their frantic little engineers may have made. |
03-19-2015, 01:23 PM | #81 | |
Rep 450
What GM did was almost the equivalent to what Ferrari does in trying to win every comparo. |
03-19-2015, 06:05 PM | #82 | ||
Rep 6,924
In the initial test Nissan employee provided octane booster for the Nismo. While the Z06 ran on 91 octane. Lets call it even. |
03-19-2015, 10:58 PM | #83 |
Rep 833
03-20-2015, 01:08 AM | #84 |
![]() 1867
Rep 1,340
Nope.
03-20-2015, 01:09 AM | #85 |
![]() 1867
Rep 1,340
And for the people that are too lazy to read, the automatic actually was slower on the track that day than the manual. In fact, it was still slower than the Nismo's original time. Mind you, this automatic car had identical tweeks the manual car also had as far as the alignment and dampening goes.
Pretty disappointed about the overheating issue with the zo6, though. Especially if you're looking to track the car on a regular basis. Maybe the standard version is the way to go. And by standard, I mean the naturally aspirated version. Last edited by Mingwan; 03-20-2015 at 01:20 AM.. |
03-20-2015, 08:25 AM | #86 | |
Rep 833
03-20-2015, 02:43 PM | #87 | |
![]() ![]() 1211
Rep 1,545
