04-21-2024, 02:44 PM | #67 | |
Rep 46
Your implying bmw set this car up to be the best it can be which they didn’t. They set it up to conform to what they want from it. Compromise of comfort to handling along with a cost budget and meeting dumbass EU regulations. Any modification from stock would be a compromise in one direction for another or could just be crap in every direction except athletics lol. I could have taken it the wrong way but the impression I get from your posts is your car will shit if you change your wheels to non oem fitment which simply isn’t true. |
04-21-2024, 04:13 PM | #68 | |
Rep 1,319
T-Rexx261.50 |
04-23-2024, 12:49 PM | #69 |
Rep 1,224
I rub at full lock steering.
285/30/20 front 305/30/20 rear Dialed down 1.4’ drop front and back. I’ll likely shave some liner or buy the clearance aftermarket’s. As for ride feedback- I just got them done yesterday so I do not have a ton. I also got much needed alignment…so overall my ride is excellent. I haven’t taken any fast turns or canyons yet (I likely won’t with these wheels) but I assume in all honesty 20 in front might decrease performance, but increase looks. Reason I’m saying that is you have more meat on the tire of course from factory or going with a smaller wheel up front. It’s pretty standard way of thinking. Will you notice? Depends if you track it. My car is a faux track speck- meaning it looks like it’s track ready, but it’s showroom track ready if you catch my drift. If I was building a true track mule or canyon carver, I’d opted for 19 or 18 squared with 295 or 305’s. For cars & coffee standouts, overall looks, and head turning…20 all around is the way to go. |
MineralGreyMetallic1075.00 |
04-23-2024, 06:08 PM | #70 | |
Rep 154
I merely provided engineering commentary (I am a mechanical design engineer) backed by a third party source addressing the pitfalls of choosing wheels with offsets that differs from factory spec and/or employing spacers. That it is. I'll also note that I've made suspension/wheel/tire altercations to many of my own vehicles. Thing is, I actually know what I'm doing in making those choices, rather than merely going for "the bling factor." Now please post a supporting link detailing the specific "dumbass EU regulations" that impact wheel offsets and suspension kinematics. Last edited by m2not1LE; 04-23-2024 at 06:17 PM.. |
04-25-2024, 03:38 PM | #72 | |
Rep 46
Your far more educated than I on this however due to my miss understanding of what you meant I was using it as an example of how cars are not necessarily the best they could be in one way or another due to having to conform to various requirements. I’m interested to know as an engineer do you look at everything on your own cars from a performance / efficiency perspective or is there a subjective feel basis in there too? |
04-25-2024, 06:10 PM | #73 | |
Rep 1,319
04-25-2024, 09:34 PM | #74 | |
Rep 732
G87 understeers way more than I'd like. Never experienced that with my F87. What will help that? |
04-26-2024, 11:17 AM | #75 | |
Car Geek
4240
Rep 3,891
04-26-2024, 02:50 PM | #77 |
Rep 1,865
The BMW wheel offsets are determined by EU requirements for snow chains. Given the choice they would develop a more aggressive offset to widen the cars track. All the manufacturers do this, look at Audi for example. If your spending money on aftermarket wheels there is no real downside to getting a more aggressive offset. A lighter wheel will be great for unsprung mass and has a ton of benefits (ride, suspension response etc).
04-28-2024, 10:42 PM | #78 | |
Rep 154
I strongly urge you to better familiarize yourself with the rules of proper grammar. Every other thing you stated or asked is equally off base. We as a nation are doomed when the vast majority of others are either unwilling or unable to learn from those who know better through both formal education and decades of related real world experience. |
09-05-2024, 09:49 AM | #79 | |
Rep 8
There is lot of myth in these posts. First of all, BMW does not develop M cars anymore for track use. Well they advertise this as a capable track car, but they itself have admitted that most of the M cars will never see the track. Just go through the posts and you see that most of them use them as daily drivers (why on earth I dont understand)
Additionally, they have strict EU rules. I watched the BMW video in the first post with irony. The reason why the went with wider tyres is the weight of the car. Its much heavier than the prev gen and to offer similar performance, they needed much more grip. This is the only reason. Yes sure, different chassis, different suspension etc... but when we get more abstract or look at things higher level, the weight of the car is the issue. Quote:
If you are facing understeer on track and are already going relatively fast then you already are at level where you need coilovers and camber plates. G87 original suspension setup is crap (for track) For my track setup Im going with R19 wheels and 305 tyre (both front and back). It seems the best setup. Best mass ratio, wide range of semis and slicks, coilovers allow to lower the car meaning the center of gravity will be also much lower than on 21 inch wheel. Add front aero details and you have wayyyyy more downforce at front. |
09-05-2024, 02:20 PM | #80 |
Rep 732
Good post above, appreciated.
My alignment guy said a similar thing about under steer. He recommended starting with a thicker front sway bar and then potentially camber plates. Surprisingly I have noticed much better cornering predictability after an alignment, but that could be placebo. |
09-06-2024, 08:26 AM | #81 | |
Rep 255
Consider BMW M themselves have made a 20 and 21 wheel combo to be fitted to the G platform. They call it the ‘M performance wheel’. Therfore if BMW M performance team have made a 20 and 21 wheel, that contradicts the statement that BMW engineers have designed the car for 19 and 20 only so any alterations from that will me detrimental. Furthermore , BMW themeselges have called this 20 and 21 wheel set for sale as their “M performance parts” therfore indicating that not only does it NOT hinder functionality, they are advertising it IMPROVES PERFORMANCE. |
Ronin761414.50 |
09-06-2024, 08:39 AM | #82 | |
Rep 732
It lists tire pressure recommendations for 20/21 with almost identical tire sizes to my aftermarket setup. There's no warning about compromised performance using these configurations. There is nothing in the manual regarding offsets, so it's still an open question for me how my wheel's offsets have affected driving dynamics. Last edited by MineralGreyMetallic; 09-06-2024 at 08:46 AM.. |
T-Rexx261.50 |
09-06-2024, 08:45 AM | #83 | |
Rep 255
And again, BMW themselves have made a ‘M performance wheel package’ in 20 and 21 staggered configuration for ‘better performance’! |
09-06-2024, 08:49 AM | #84 | |
Rep 732
In fact, the only mention I found in the user's manual about offsets is in reference to snow chains. |
T-Rexx261.50 |
09-06-2024, 08:51 AM | #85 |
Rep 255
09-06-2024, 09:01 AM | #86 |
Rep 271
MineralGreyMetallic here is a VERY generic statement from Les Schwab tires about how wheel offsets affect handling:
Too Much Negative Wheel Offset = increased steering wheel kick-back Additional stress on the entire suspension Poor handling https://www.lesschwab.com/article/wh...with%20braking. Some other considerations mentioned in a Motor Trend article: scrub radius affected, wheel kickback, "effective wheel spring rate", wheel bearing loading So yeah, it seems like there is certainly evidence of wheel offset having various affects to suspension performance. However, we have all seen many cars on the road with all sorts of offsets/lowering/camber and the cars still drive. So, what is the true magnitude of these affects???? Hard to say without having all sorts of kinematic modelling and full suspension design models available. These subjects are much more difficult to get actual data available on (as opposed to temperature based subjects where measuring data is much easier). BMW "M-Performance" options certainly seems like a highly reliable data point to what is "totally safe", and then reputable wheel suppliers seem like the next best option for validating a design choice. Third data point I would look to is people who are tracking their car with the wheel choice you are thinking because they have certainly stressed their system more than an average road use case.
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
MineralGreyMetallic1075.00 T-Rexx261.50 |
09-06-2024, 09:05 AM | #87 | |
Rep 271
Can anyone with track experience in the G87 M2 suspension verify setup changes/affect. How would go about "correcting" understeer in low to mid-speed corners (ignoring aero affects)? Stiffen the rear, or stiffen the front?
09-06-2024, 11:14 AM | #88 |
Rep 1,460
The cars are not dialed in to some 'synergistic nirvana' that is and always will be world without end, amen...they are rather dialed into an average use case that also meets regulations across worldwide markets…
THIS is the proper response to “the BMW engineers know all” boys because these boys forget the finance (and government) guys sit in the engineering meetings.
I want to buy your comfort seats.
