09-05-2022, 10:16 PM | #11023 | |
Rep 11,192
M_Six19170.50 |
09-05-2022, 10:29 PM | #11024 |
Rep 7,539
As far as I know, Amcrest makes their own. But I'm no expert. I saw a YouTube where a cyber guy explained the idiocy of the NDAA and SEA the way they were written. They ban U.S. gov't entities from using cameras produced by Hikvision or Duhua. But those companies sell their equipment to dozens of other companies to be rebranded, so you could be buying from Company A and still have a banned Hikvision camera. He lists the Hikvision OEM rebrands at 3:11 in this video. I don't see Amcrest listed.
P111727.00 |
09-05-2022, 10:35 PM | #11025 | |
Rep 7,539
09-05-2022, 11:48 PM | #11026 | |
Rep 11,192
09-06-2022, 08:03 AM | #11028 |
Rep 1,002
The problem with doing that is that the NVR does not route for the cameras, so you cannot talk directly to them or use any of their built-in features like email alerts and programmed image uploads when plugged into the NVR's PoE ports.....
09-06-2022, 08:58 AM | #11029 |
Rep 7,539
Right. It's essentially an air-gapped system, so you'd need a monitor on the NVR or some fancy routing setup. Or does the NVR not act like a switch where you can set up routing through it? I suppose you could put the entire NVR system on its own vlan.
09-06-2022, 10:20 AM | #11030 | |
Rep 1,002
I have our NVR hooked up to the big screen TV via an HDMI input, but only really use it when I'm watching TV and hear something unusual outside. Amcrest's NVR's all only support USB mice for their sole input, and don't include the HID code to operate a USB keyboard. The MacOS SmartPSS app does an OK job for looking at videos and stuff, although it seems to be written in Java and has more than its share of buggy quirks. My DW uses the Amcrest iOS app on her phone to check in on OCD psycho dog when I'm not home, and I have never heard her complain about problems using it other than latency when re-pointing a camera using PTZ.....
M_Six19170.50 |
09-06-2022, 11:13 PM | #11031 |
Rep 1,593
Did you buy the cameras already re-flashed or do it yourself? I tried a quick search for custom FW but only found people DIY'ing and posting questions on forums.
- Jeff
bosstones' flickr |
09-06-2022, 11:24 PM | #11032 |
Rep 14,249
Drives: G82 M4C X-Drive
Garage List 2025 BMW M2 [10.00]
2022 G82 M4C X-Drive [9.89] 2018 F80 M3 CS [9.90] 2018 BMW i3 REx [5.00] 2015 BMW i3 REx [0.00] 2016 BMW F80 M3 [7.29] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [0.00] 2006 Audi S4 25Quattro [7.00] |
FML my 40 year old HVAC system took a dump a few days ago, right before one of the worst heat waves in Socal I can remember. It's easily 95 degrees in my house.
First purchase was a new furnace, blower, coils and condenser/heat pump. $14k. Of course, it takes a few days to get the parts and install, so in the meantime I got one of these portable AC puppies for my home office because my head started to hurt from the heat and zoom calls were becoming awkward with my shirt off:
2022 G82///M4 Competition X-Drive - KW-HAS, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 Ordered • 2025 ///M2 |
M_Six19170.50 Esteban53654.50 JJ 911SC26551.50 RickFLM411825.50 deleted_397282_c43ae5ea84160.50 infinitekidM2C4297.50 Dino GT35069.50 |
09-06-2022, 11:35 PM | #11033 |
Rep 7,539
Been waffling between getting one of these for the garage or going with a mini-split. I need the cooling more than the heating, so a mini-split is a bit of overkill. But the costs aren't that far apart. And the mini-split doesn't take up floor space.
09-07-2022, 01:17 AM | #11034 | |
Rep 7,237
Only 15 years old but it runs all year set at 70F so it might see an early death, lol. Couldn't stand to be stuck in 100+ temp with no A/C. |
RickFLM411825.50 |
09-07-2022, 04:04 AM | #11035 |
Scott Langenthal
155
Rep 148
Drives: 2022 Toronto Red Metallic X4MC
Carbon Fiber 50th Anniversary Roundel
Purchased a BMW 50th Anniversary Carbon Fiber Emblem Roundel from bimmerplug.com after seeing an M5 at Detailer's Domain with one. It goes over the top with a piece of double-stick tape.
Scott "Retired and LOVING it"
2022 Toronto Red Metallic X4 M Competition (Current Ride - Scarlett) 🚘 2021 Mineral Gray Metallic M340i xDrive (Retired) 2017 Melbourne Red Metallic 340i xDrive (Retired) 2002 Mineral Grey Metallic 330xi (Retired) |
jmg19268.00 |
09-07-2022, 08:28 AM | #11036 |
Rep 11,192
09-07-2022, 09:10 AM | #11037 |
Rep 7,539
According to that cam comparison guy, Amcrest is a U.S. firm that sources Dahua cameras. Not sure if that means Amcrest reflashes them or not. But I'm using Synology Surveillance Station, so totally different software for viewing. Once I have my cams set up, I may set up a firewall rule to keep them from sending anything out of the network IP range.
09-07-2022, 09:57 AM | #11038 | |
Rep 14,249
09-07-2022, 10:03 AM | #11039 | ||
Rep 14,249
09-07-2022, 10:21 AM | #11040 |
Rep 7,539
Yikes. My HVAC contractor just quote a mini-split for the garage at $5500. Even if I could find someone to do it for half that, it's still way more than a floor unit. Looks like I need to shop for a floor unit. Luckily we're just about out of the major summer heat, so I have until next year to find and install one.
jmg19268.00 |
09-07-2022, 10:42 AM | #11041 | |
Rep 5
If you are decent at DIY you can buy a DIY minisplit from mrcool or some others. They are really easy to install. I installed one in my office space I built into my garage/shop and they are really easy to do. |
09-07-2022, 10:48 AM | #11042 |
Rep 7,539
Just dipping my toes into the DIY arena. I'm nowhere near confident enough to try that yet. I can still screw up a free lunch given the chance.
09-07-2022, 11:44 AM | #11043 | |
Rep 14,249
09-07-2022, 11:55 AM | #11044 |
Rep 7,237
