      04-09-2023, 03:51 PM   #111
zero21
Drives: G87 sold
Originally Posted by sl0m0 View Post
If I was going to delete the seat I'd get a gt4. Need that for the children. I agree it's gonna be a while to get comfy enough with the car to really get the full potential, that's why I am not even going to consider a tune for a while.
Why would you get a cat back exhaust? I thought we were just trying to remove weight from the front
Equal length exhaust sound
      04-09-2023, 04:13 PM   #112
StickyPickle
Drives: NA
Only thing that sucks about installing a lithium battery for weight savings is the weight distribution is a near 53/47 split f/r so it would be removing weight from the wrong end because the battery is in the trunk.
zero213276.00
      04-09-2023, 04:16 PM   #113
sl0m0
Drives: Sedan
You are starting to sound like zero. This is why the battery will not be my first mod, it's on the list for potential mods though.
zero213276.00
      04-09-2023, 04:47 PM   #114
M_Power Rob
Drives: '23 M240 and '23 M2
A quality titanium catback will help with performance (especially with the eventual highflow downpipe and tune) and shed overall weight. A larger benefit than worrying to the point of stressing over exact percentage of distribution from front to back.
      04-09-2023, 05:18 PM   #115
cmgbk75
cmgbk75's Avatar
Drives: G87, G26, E46, Mk6 5K
2023 M2  [8.78]
2022 i4 40  [8.33]
2001 325Cic  [6.67]
Originally Posted by Tag View Post
Have you considered getting black emblems? Regardless, I would also create a template before removing them in case if you ever want to add them back.
I’m going to get those along with the front & rear reflector delete: https://ind-distribution.com/product...smetic-package
zero213276.00
      04-09-2023, 06:12 PM   #116
sl0m0
Drives: Sedan
I know, I was being facetious with zero21. I am curious if anyone is going for the mperf exhaust.
      04-09-2023, 06:25 PM   #117
JustinHEMI
Not great. Not terrible
JustinHEMI's Avatar
7502
Drives: 2024 BMW X3 M40i
I have that set sitting here waiting for my car to arrive. However, now I'm concerned that the addition of paint and ceramic coating may add weight to the car.
Current: 2024 BMW X3 M40i.
cmgbk752671.50
Squidget3813.00
aerobod4257.50
      04-09-2023, 06:27 PM   #118
zero21
Drives: G87 sold
JustinHEMI7502.00
      04-09-2023, 06:41 PM   #119
cmgbk75
cmgbk75's Avatar
2023 M2  [8.78]
2022 i4 40  [8.33]
2001 325Cic  [6.67]
Jesus…. You got me rolling.
JustinHEMI7502.00
      04-09-2023, 06:45 PM   #120
JustinHEMI
JustinHEMI's Avatar
7502
That was the intent.
cmgbk752671.50
      04-09-2023, 06:49 PM   #121
M_Power Rob
Maybe remove the paint from the back half of the car?
      04-09-2023, 10:51 PM   #122
sl0m0
Drives: Sedan
The front half, that's where the excess weight is.
      04-10-2023, 10:28 AM   #123
zero21
Drives: G87 sold
This is now on the options list for me.
Tag20015.00
      04-10-2023, 10:30 AM   #124
Ghostrider.1127
Ghostrider
Ghostrider.1127's Avatar
195
Drives: M140iX,Z4M40i,M8 comp,M2g87
Already delivered , but i dunno when the car will be here.
      04-10-2023, 10:36 AM   #125
Lex Templar
Australia
635
Drives: 2023 M2 AW
Even though I will be keeping my rear reflector stock, the rear reflector delete will be a nice option for many.
      04-10-2023, 11:18 AM   #126
zero21
Drives: G87 sold
Originally Posted by aerobod View Post
The front to rear weight will be accurate, but unless they used the scales on a very level floor, you can get considerable diagonal variations. Also it the suspension has some tension in it you can get a similar effect. I wouldn't take the side to side readings as very accurate without taking those effects into account.
The most they moved with a reposition was 2lbs up and down. Shop owner knows what he's doing and equipment is accurate (former legit race car driver and long time mechanic).
T_U_D6706.50
      04-10-2023, 11:47 AM   #127
aerobod
Car Geek
aerobod's Avatar
Originally Posted by zero21 View Post
The most they moved with a reposition was 2lbs up and down. Shop owner know what he's doing and equipment is accurate (former legit race car driver and long time mechanic).
If the equipment is level, then I would wait a couple of months until the suspension is broken in. the front left and rear right suspension components are currently exerting more downward pressure than the front right and rear left, but bushings not broken in can cause this. It isn't a case of there just being a higher weight on the front left, as otherwise the rear right would be lower and there would be a left to right weight difference.
Assuming besides the floor confirmed as level, all the tyre pressures were at spec before measurement, too? I haven't had dealers be very accurate in setting tyre pressures in the past.
      04-10-2023, 11:50 AM   #128
zero21
Drives: G87 sold
Tire pressure was 33psi. I can go back in a couple months and re-check. My trip through downtown last night definitely "broke-in" my suspension
aerobod4257.50
      04-10-2023, 12:14 PM   #129
T_U_D
T_U_D's Avatar
6707
Drives: G05 LCI
Was Sean (son) around?
      04-10-2023, 12:56 PM   #130
zero21
Drives: G87 sold
No but Abbey did the wheels
Karl is awesome
T_U_D6706.50
      04-10-2023, 01:11 PM   #131
T_U_D
T_U_D's Avatar
6707
Drives: G05 LCI
No but Abbey did with the wheels
Karl is awesome
Guessing the E30 M3 there was Brilliant Red? If so, it belongs to a fellow Sandlapper member.
zero213276.00
      04-10-2023, 04:25 PM   #132
Tag
this is the way
Tag's Avatar
20015
Drives: N-1 starfighter
zero21
BMWBLOG: 2023 BMW M2- The First Unofficial Weight
zero213276.00
JustinHEMI7502.00
