05-07-2024, 01:19 PM | #177 | |
Rep 152
This makes me wonder if your situation and mine have a different variable or two to make for different experiences. To recap my setup: ZTK package running four VS-5RS 19x9" ET25. What's exactly your setup? Edit: the official SKU from the invoice— VS5RS199ET25-5112-666-B-NSBZ. Cross reference that against yours. Last edited by Jashue; 05-07-2024 at 05:20 PM.. |
05-07-2024, 01:21 PM | #178 |
Rep 789
ZTK package, VS-5RS 19x9.5" ET25, Eibach Pro Springs
M240i Brooklyn Grey
My Build Thread |
05-07-2024, 01:32 PM | #179 |
Rep 789
just gone out and recorded a video
M240i Brooklyn Grey
My Build Thread |
05-07-2024, 01:36 PM | #180 |
Rep 485
Drives: 2022 BMW M240i
Thanks for posting a vid. Kinda sounds like when we used to put playing cards in the bicycle spokes. So no one has a clue as to what is causing the sound? APEX guys haven't weighed in yet? I have the same setup as Jashue coming - ZTK package, VS-5RS 19x9 ET25 all around and I also have the Eibach Pro Kit on my G42. Can the 9 vs 9.5 somehow make a difference?
05-07-2024, 01:42 PM | #181 | |
Cruising the Green Hell
110
Rep 95
viperx100680.50 |
05-07-2024, 01:43 PM | #182 | |
Rep 789
Expert@ApexWheels will this give them notice? Last edited by cannockwolf; 05-07-2024 at 01:49 PM.. |
viperx100680.50 |
05-07-2024, 03:15 PM | #183 |
Rep 485
I sure hope that's not a thing with every set of these wheels because there shouldn't be a sound like this as a norm with aftermarket wheels, especially ones from a reputable brand for not exactly pennies.
05-07-2024, 04:23 PM | #184 |
Rep 6,972
Hi all,
I'm catching up to forum responses this morning. The text here is a repost in some sections from another thread. This ticking noise has cropped up a few times. I’m generally the one answering the phone on the BMW line and I know I’ve talked to a few customers about the issue. With that said, it's a relatively rare issue. It is certainly happening hence the video and the calls but it isn’t happening to every car with these wheels. These are by far our most popular design/wheels for these cars and the vast majority of customers don't get the tick in a way that is audible. We’ve seen this issue on the G chassis BMWs and some of the F8X M cars as well as the A90 Supra once. This will be a longer response, but here is the TLDR: We suspect that our wheels are amplifying a pre-existing noise, especially for cars with certain types of brake rotors. There are a few service bulletins that cover a similar issue with BMW OE wheels. There are more than these 2, but I’ll link the 2 I have saved: https://static.nhtsa.gov/odi/tsbs/20...74009-9999.pdf https://static.nhtsa.gov/odi/tsbs/20...46758-9999.pdf Before I worked for Apex, I worked for a BMW dealer in the warranty department. I do remember a few of the F80 M3 and F82 M4s coming in for a similar issue. In the case of the SIBs, the ticking is coming from the interface between the hub flange and the brake rotor itself and it applies specifically to cars with certain 2-piece rotors (described as lightweight discs in the SIB). This tracks with feedback from our customers as most commonly the noise has occurred either on F chassis cars with the floating rotors or the lightweight rotors common on many of the G chassis models. The SIBs offer the option of installing a small shim they call a friction disc in between the rotor face and the hub. The friction disc for these SIBs is sandwitched between the hub and rotor when installed as recommended. It's important to note that the bulletin also provides some work time for the tech to clean the hub flange. We’ve had a few customers eliminate the clicking noise just by removing corrosion from and cleaning their hub flange as well as the mating surfaces of the rotors on either side. Spacers or anti-seize between the wheel mounting face and the brake rotor can also prevent or reduce the noise considerably. It’s likely that whatever is causing the tick sounds is still there, but the spacer/anti-seize is preventing most of the vibrations from transferring into the wheel which is likely what causes the sound. Think of a large bell being hit with a hammer, then a bell being hit by the same hammer with an inch-thick piece of rubber in between the bell and hammer. The cause of the noise is still there, but it's going to be much less audible. Our forged wheels are quite stiff and have less material than most of the OE wheels that come with these cars hence their light weight. That combined with potentially some of the pocketing machining on the back of the wheel which further reduces the weight of the wheel seems to make the sound more audible with our wheels than OE wheels. With those possible solutions outlined above, it’s important to highlight that this isn’t a structural defect or a deeper issue with the wheels themselves. We’ve seen no indication that there are any safety concerns with these designs or any other problems beyond the annoying sound. If you own a set of these wheels and aren't happy with them because of this issue, please do reach out to support@apexwheels.com. -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
JoeyJoeJo225.00 |
05-07-2024, 04:54 PM | #185 | |
Rep 789
Also is that the same place were the copper grease would go? its no use putting it between the wheel and the hub?
M240i Brooklyn Grey
My Build Thread |
05-07-2024, 05:25 PM | #186 | |
Rep 6,972
I don't know if inserting this disc in between the rotor face and the wheel will fix anything as that isn't how BMW intended for it to be used, but it's essentially a small spacer so in theory it might. Cleaning of any potential corrosion on the hubs or rotor without anything else fixed the problem for one customer as I mentioned earlier. Some of our customers have had success in eliminating the noise with a thin wheel spacer (inserts between the rotor surface and wheel) or a light layer of anti-seize applied to the wheel mounting surface. You need to be careful with anti-seize though as you don't want to contaminate the braking surface of the rotors or get any on the wheel fasteners (bolts/studs) as it can affect torque values/contaminate brake pads. Part of our problem figuring out what is causing this is it seems to be different each time we see it. In your case, does it seem to be coming from all 4 corners of the car? or just 1 or 2? Any difference in cornering vs straight? -Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by Expert@ApexWheels; 05-07-2024 at 05:41 PM.. |
05-07-2024, 05:31 PM | #187 |
Rep 6,972
Also worth mentioning, this rarely fixes it or is the root cause, but its always worth checking the torque on the wheel bolts. The SIB recommends replacing the bolts on cars that are 2 years old, but that's pretty common for work like this at the dealer.
-Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by Expert@ApexWheels; 05-28-2024 at 04:13 PM.. |
05-07-2024, 05:46 PM | #188 | |
Rep 6,972
-Tom
viperx100680.50 |
05-07-2024, 06:22 PM | #189 |
Rep 789
Seems to be the rears, and definitely gets worse in cornering, im going to re-tourqe the wheels and put a little aluminium grease on see if that helps first thanks
M240i Brooklyn Grey
My Build Thread |
Expert@ApexWheels3934.00 |
05-10-2024, 10:40 AM | #190 |
Rep 789
Just done this and it's completely silent
M240i Brooklyn Grey
My Build Thread |
05-21-2024, 01:56 PM | #191 |
Rep 6,972
Some of you may have already seen the reveal of this project on our instagram, but we wanted to reach out to the BMW community on the forums as well to collect feedback about the development of a new wheel design. Project ML-10 Background: After Josh, one of our Senior Product Engineers installed a widebody kit on his race car project, he had to design a custom set of wheels to fit his extreme application. Originally a one off project, when he showed the team what he created, we were floored. And our community was too when we shared a picture on Instagram and Facebook. We’ve made it an official project, but to make this wheel a reality, we need you to decide on some of the details by taking our survey. Need more information? Subscribe to our newsletter and check out project updates along with additional photos on our website.
Ruebarb416.50 |
05-24-2024, 06:42 PM | #192 |
Rep 6,972
Memorial Day Sale: Up to 20% off + Free Shipping*
Celebrate Memorial Day with a new set of Apex Wheels. Save 20% off + Free Shipping* on our Flow Formed SM-10 and 15% off + Free Shipping* on our Forged Sprint Line SM-10RS fitments. This sale ends on Monday June 3rd so don't miss out and get your order in today! Buy Now Apex Flow Formed SM-10: 20% off Our original 10 spoke wheel. Our Flow Formed Evolution line SM-10 design is heavily represented in this sale. The Flow Formed SM-10 features I Beam spokes and a reinforced inner lip. Buy Now Apex Sprint Line Forged SM-10RS: 15% off The Lightest Wheels We Make. Deep discounts on all of our Fully Forged SM-10RS are available making this high-performance lightweight wheel an even better value. Buy Now Apex Accessories: 15% off All Apex Stud Kits, Lug Bolts, Spacers, and Center Caps are discounted and get free shipping. Get your car ready for the track season today. Buy Now Free Shipping All orders of SM-10 and SM-10RS wheels and qualifying Apex accessories will get free shipping* through this Memorial Day sale. *Free Shipping to the 48 Contiguous States only. Questions? Call: 925-245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
05-25-2024, 02:43 PM | #193 |
Rep 789
It's back albeit very reduced compaired to the video, but enough to be annoying, best thing is keep the windows shut lol
M240i Brooklyn Grey
My Build Thread |
05-29-2024, 08:58 PM | #194 |
Rep 270
07-05-2024, 09:12 PM | #195 |
Rep 485
Finally got the APEX wheels in Anthracite and put them on. 19x9 square setup 255/35/19 and Eibach springs. No spacers but I may add a few teeny ones to flush them out. Love the look and the more nimble/lighter driving feel. I'll probably swap the APEX center caps for 50th 50th-anniversary ones that I had on my OG wheels.
07-30-2024, 01:56 PM | #196 |
Rep 6,972
ML-10RT now available for Pre-Order The ML-10RT forged wheel started life as an engineering passion project. You brought it to life. It’s the moment you’ve all been waiting for. The green flag has dropped and the Forged ML-10RT pre-sale is officially underway! Reserve your set now to ensure you receive wheels from the first production batch, and save 15% off + free shipping in the continental U.S. Due to extremely high demand, we expect a number of popular fitments and finishes to sell out, so act fast. Pre-order discounts are based on product availability, and are subject to change at any time. Please note we fulfill orders in chronological order, so the sooner you place your pre-order, the faster you will get your wheels. Features AN EVOLUTION OF PERFORMANCE - The ML-10RT honors the motorsport designs so many of us fell in love with during the golden era of Touring Car and Sports Car racing. However, its ancestry ends there. Our in-house engineering team pulled out all the stops to create a monoblock forged wheel that's lighter, stronger and stiffer than multi-piece wheels of the past. Utilizing the latest forging technology to offer an impeccable design, backed by Real Performance, at an obtainable price point. SIDE-MILLED SPOKES - The ML-10RT incorporates Apex’s extra-deep, side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Often deemed cost-prohibitive by others, this aggressive side-milling shaves critical weight, and adds a sharp contrast in the design of the center spoke area. SPRINT INNER LIP - The ML-10RT borrows the race-proven Sprint Spec inner lip from our Sprint Line wheels, providing critical strength to the unsupported inner lip of the wheel. Adding 32% more material where it matters most. Don’t settle for under-engineered wheels, attack both the track and your cities potholes with confidence 10K TONS OF PRESSURE - To make our forged wheels the strongest we can, we applied as much pressure as possible using a 10,000 ton forge. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure. TRUE MOTORSPORT BLANKS - Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch to give us total control over the final product. INDEPENDENTLY TESTED - We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. Our Touring Line wheels are independently tested by ITS at their Michigan facility following JWL standards but pushed to much higher loads and much longer durations. MACHINED LIP - The ML-10RT is our first forged wheel to feature a machined lip, which really makes it a standout design within the Apex catalog. The lip in combination with the mesh center pays homage to the glory days of motorsport, and is sure to dramatically transform the look of any car. The best part - the machined lip has a gloss clear coat and doesn't require polishing. VEHICLE SPECIFIC SPOKE PROFILES - The lipped design of the ML-10RT inherently limits brake clearance. Rather than making every fitment as conservative as possible, we utilized our extensive 3D vehicle scanning library to shrink wrap each fitment's spoke design around respective OEM and popular aftermarket brake kits. Leveraging our vehicle research and engineering team, we find a perfect balance of concavity and brake clearance. BUILT FOR IMPACT SOCKETS - Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All Apex wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast. OEM CENTER CAP COMPATIBILITY - Love that OEM+ look? Us too. Our engineers went the extra mile and incorporated a flush mounted OEM center cap support into the ML-10RT. Whether you want to show off your included Apex center caps or stick with your OEM caps, the ML-10RT will seamlessly accept both. LASER-ENGRAVED SPECS - As car enthusiasts ourselves, we know how frustrating it is to locate and decipher wheel specs that have been hastily marked on a wheel or become unreadable over time. Our Touring Line wheels have laser-engraved specs on the barrel, in plain sight, making them easy to find and read. Pre-Order your set of ML-10RT today Buy with confidence. With only a 25% deposit initially required for these wheels, you can Pre-Order today and lock in the deep discount and ensure you get your preferred fitment and finish early. Don’t miss your chance to be the among the first to run this all-new Apex design. Check out your vehicles wheel configurator or Fitment Guide for availabile wheel sizes and fitment information such as tire options and brake clearance.
07-31-2024, 05:12 AM | #197 | ||
Rep 789
M240i Brooklyn Grey
My Build Thread |
08-02-2024, 08:34 AM | #198 |
Rep 789
Fitted the friction discs and its completely silent now
M240i Brooklyn Grey
My Build Thread |
Expert@ApexWheels3934.00 Wasp_Factory112.00 |
