02-11-2019, 09:22 AM | #1 |
Rep 105
ACC Retrofit questions
Has anybody done a retrofit and added the ACC to their X1?
From what I was reading you need the camera and the switch on the steering wheel (and VO code) I have the camera system already installed (collision, pedestrian, and Lane change). Before I spend the money getting those controls I wanted to see if anybody else has successfully done it. |
02-11-2019, 01:22 PM | #2 | |
Rep 376
Drives: 2020 M2C DCT
02-11-2019, 04:59 PM | #3 | |
Rep 83
02-12-2019, 09:28 AM | #4 | ||
Rep 105
02-13-2019, 07:43 PM | #5 |
Rep 105
Update: I added 5FD to my VO and coded Kafas2, no errors and car showed references to ACC in the iDrive. I can't VO code the kombi module because it fails, mentioning multiple values.
I went and enabled a few ibrake options (in kombi) and got a frontal collision warning message in the idrive but my frontal collision warning is still active. I'm thinking it might throw that because I don't have the ACC switch installed, yet. |
02-21-2019, 02:30 PM | #6 | |
Rep 913
I thought VO changes would be to change 5ASA TO 5ATA and remove S544A. On F48 I thought 5DFA is a subset of 5ATA , namely 5ATA is 5ASA+5DFA ? |
PurePulse6451.50 |
02-21-2019, 02:35 PM | #7 | ||
Rep 105
02-22-2019, 08:13 PM | #8 |
Rep 105
On my VO Codes I have:
1AG, 1CA, 205, 248, 249, 255, 258, 28A, 2VB, 2VG, 302, 313, 316, 319, 322, 3AG, 3AT, 3L8, 402, 420, 423, 430, 431, 459, 473, 488, 493, 494, 4F7, 4NE, 508, 534, 544, 563, 575, 5A4, 5AS, 5DP, 610, 645, 650, 655, 676, 697, 6AC, 6AE, 6AK, 6AM, 6AP, 6NS, 6UP, 775, 7HW, 823, 842, 845, 850, 853, 8KL, 8R9, 8S4, 8SL, 8SM, 8TN, 925, 927, 992, 9AA, 9C8 I added 5DF and left all others. |
02-23-2019, 11:11 PM | #9 |
Rep 105
To provide an update to anybody following along... I received the steering wheel controls and finally was able to get them installed (Thanks for the help MJE60 )
I VO coded with 5DF but kept getting an error saying the Frontal collision warning and pedestrian warning was disabled. I tried to remove 544 and re-code, no luck. Tried to change 5AS to 5AT and recode with 5DF.. Still no luck Tomorrow I'm going to try adding 541, maybe with 5DF and see if that helps any. If anybody has any ideas please let me know |
02-24-2019, 02:56 AM | #10 | |
Rep 913
Whilst I think this is not cause of the errors, if you add 5DF (ACC) then 544 (CC with brake function) should probably be removed to prevent duplicate coding. However this is my assumption, I have not checked. Once psdzdata update done, imho VO code changes to your original FA are just - > remove 5AS and 544 and add 5AT + 5DF Good luck Last edited by MJE60; 03-14-2019 at 05:46 AM.. Reason: Incorrect info |
02-24-2019, 01:14 PM | #11 |
Rep 105
So it's looking like ESys just doesn't have some mapping correct. I've been going thru the files and doing some comparison. So far I've gotten it so it'll say the fcw and ped is restricted not inactive. It says it won't auto brake. I'm thinking once I get that cleared up it should let me activate ACC.
03-01-2019, 10:36 PM | #12 |
Rep 105
For anybody possibly following along -- giving an update.
Even though my car has 5AS and 5DP (Pedestrian detection, FCW, LDW, Parking Assist) apparently there is another ECU that is used with ACC+ -- The ECU is SAS, it's installed next to the PMA ECU in the rear of the car. If you don't have ACC+ then everything is handled by KAFAS and DSC2, if you have ACC+ (5AT) then it utilizes SAS and Kafas to calculate everything. I'm going to check the wiring in the car tomorrow and see if its prewired or if a wire would need to be ran from the BDC_BODY/Kafas unit. If it's prewired I found the ECU for $250, if it has to be wired I'm not entirely sure how to handle it. |
03-11-2019, 09:36 PM | #13 |
Rep 105
Final update
I ended up pulling the back lining out and checking for the SAS ECU, unfortunately it's not there nor is there wiring for it. I have no clue oh how to wire that so I'm pretty much DOA.
Taking apart the rear I did find some other wiring not hooked to anything that makes me wonder what it's for. Anybody know? |
03-11-2019, 09:37 PM | #14 |
Rep 105
MJE60681.00 |
03-12-2019, 05:12 PM | #15 | |
Rep 913
Possibly factory tow bar electrics?, or I suspect rear EDC would hook up into loom somewhere in that area (and then into SAS also). Park assist module in rear roof could possibly route through right hand trunk recess also. Looking at ISTA I think there is aux comms signal booster located in rear also (all these are options so would explain some empty plugs/connectors. Last edited by MJE60; 03-12-2019 at 05:17 PM.. |
03-12-2019, 08:43 PM | #16 | |
Rep 105
03-14-2019, 01:08 PM | #17 |
Rep 1
Just purchased a 2018 x1 with the drivers assistance package. I'm also looking into retrofitting. Any news? I was really hoping this would just be a code change since the optical system is already in there.
03-14-2019, 01:27 PM | #18 | |
Rep 913
The short answer is that you would as a minimum require new steering wheel switches and if you do not have EDC (electronic damper control) you would also require a SAS control unit (and cabling to fit it). It appears BMW have routed ACC to work through a different (and rare) control unit to other functions served by the KAFAS camera. One can only suspect it was in order to make sure it was not just a simple code change. PulsePulse64 is investigating whether there is a socket lurking somewhere in the wiring loom into which a SAS module could be plugged. We await his findings, he is to be commended for his efforts. |
03-15-2019, 07:30 PM | #19 | ||
Rep 105
You can tell if you have SAS by hooking up e-sys and checking your ECU list or by removing your rear trim (on the right) and you'd see it bolted right under the rear window. |
03-15-2019, 07:33 PM | #20 | |||||
Rep 105
Unfortunately I don't have much extra to share I've looked to see if I could find wiring out of an F48 that had it but that's been next to impossible. I may end up looking to see if I could get the wiring from an i3 since it's similar. |
03-17-2019, 04:26 AM | #21 | |
Rep 1,646
Is 'normal' cruise control still fitted when ACC is optioned?
I just ordered an X2 with ACC but haven't received it yet. Do you know if you can still use the normal cruise control with braking, instead of the camera-based ACC? cheers
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
03-17-2019, 12:00 PM | #22 |
Rep 913
