09-27-2024, 07:59 PM | #1 |
Rep 358
Hoosier Track Attack Pro
Got them!
Can't wait to get them on the track.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43 |
10-02-2024, 12:09 PM | #4 |
Rep 358
Last weekend I had my GYSC3R. I will run the H-TAPs this upcoming Saturday at COTA
2022 M850i
M2diamondblack45.00 Charley13542.00 |
10-04-2024, 11:22 PM | #5 |
Rep 105
Very interested how they stack up vs the SC3R. I've ran the SC3R in 305/30/19 and now I'm rocking 295/35/18 in the RE71RS
@DutchBoysRacing
10-06-2024, 02:00 PM | #6 |
Rep 134
Zion will hit us with some wisdom soon. I saw the car in action this weekend and the tires looked like they held up well and kept pace.
10-06-2024, 05:26 PM | #7 |
Rep 358
TLDR: These are impressive tires. I hope that I get 5-6 track days out of them.
So far I have run 3 different 305/30/19 tires:
So I was at COTA yesterday with the Hoosier Track Attack Pro tires. 305/30/19 square running Carbotech XP20 front pads. 6 Days earlier I was also at COTA on the GYSC3R with G-Loc R12 front pads and a 200 lb passenger. Because I had a passenger it's not quite an apples-to-apples comparison. Those who take a passenger can attest that you pull back a bit (or you would be wise to). Also comparing laptimes to times I got a few months ago with the GYSC3R isn't quite apples-to-apples because COTA has recently been repaved in preparation for the upcoming F1 race. Yesterday with the H-TAP and no passenger my fastest lap was 2:26. Last week with a passenger and GYSC3R my fastest time was 2:30. My fastest time a few months ago before the repave my fastest time with GYSC3R was 2:28. Now I openly admit that my line and lap performance could use some improvement and lacks consistency. Here are some observations about the H-TAP's
My conclusion is that the Hoosiers might be slightly better than the Nankangs and are close in performance to the Goodyears. Considering that the Goodyears only last 3 days the Hoosiers could be a great option if they last 5-6 days like the Nankangs. Just be aware that when they get hot you might slip out a bit when pushing it through sharp corners. As a bonus they are made in the USA so there won't be import problems like there have been with the Nankangs for most of this year. I will add pictures after future track days.
2022 M850i
10-07-2024, 10:14 AM | #9 |
Keep Up the RPMs
1163
Rep 518
Drives: M3CS
Thank you for the feedback. Did you heat cycled them before track use? I wonder doing so might actually extend life another ~2 days.
Cheers,
BoB |
10-07-2024, 10:32 AM | #10 |
Rep 358
Sorta but I am not sure how good of a job I did. 2 days before I went to the track I drove aggressively on some country roads, bed some new brake pads, and did some higher speed serves to hear the tires chirp a bit. I got them up to 120 degrees according to the TPMS. I am unsure if that was sufficient for a heat cycle.
2022 M850i
BackOnBlack1162.50 |
10-08-2024, 11:09 PM | #11 |
Rep 358
Also another data point:
Nankang CR-S: 31 lbs Goodyear SC3R: 29 lbs Hoosier TAP: 24 lbs
2022 M850i
M2diamondblack45.00 |
10-09-2024, 01:16 AM | #12 |
Car Geek
4252
Rep 3,901
10-09-2024, 08:55 AM | #13 |
Rep 358
It's like the old saying- "eventually all sandpaper is the same grit" but now it is "all equal size tires are eventually the same weight"
2022 M850i
aerobod4251.50 |
