10-02-2023, 01:26 PM | #1 |
Rep 76
V1 G2 Wiring using Front Passenger Fusebox
I hardwired my Valentine One radar detector using power from the front passenger fuse box. I used a fuse tap adapter (such as a Bussmann ATM Fuse tap) and connected it to F69. I chose this one because it was not used and it is switched.
I have attached several pictures of the fuse box and where I ran the wire (red line roughly shows where I rant the wire). I tried my best to tuck in the wire so that it isn't really apparent. I hope this helps others. |
10-06-2023, 07:30 AM | #3 |
Rep 76
I don't know. I haven't tried that. If I were to guess, I would think that it is possible. The fuse box is very close to the glove compartment, and I don't recall that the glove compartment is tightly sealed. It may be difficult to get all the way around the glove compartment because it is pretty tight. Good luck.
mynameisnick4225.00 |
10-06-2023, 11:58 AM | #4 |
Rep 3,065
Drives: A Family Sedan
10-06-2023, 12:36 PM | #5 | |
Rep 259
I did it this way in my Focus RS where you could run the wires up and out the back of the glove box. I am hoping I will be able to do the same in the G87. I'll take a look for myself later today but don't plan on trying to hardwire it until sometime next week. |
10-06-2023, 01:07 PM | #6 | |
Rep 3,065
11-07-2023, 01:28 PM | #8 | |
Rep 259
11-07-2023, 05:28 PM | #10 |
Rep 259
aguycalleddb453.00 miiipilot522.00 |
04-12-2024, 11:39 AM | #12 |
Rep 3,065
