F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Dragy accuracy
ARMA SPEED
      04-25-2022, 09:17 AM   #1
daronk
daronk's Avatar
Drives: BMW 335i
Not sure if this has been discussed but how does something at 10 Hz accurately display hundredths (0.01). @10Hz and 60mph it updates every 8.8ft. Is hundredth only the internal clock so it would only display say 3.56s and next possible post would be 3.66s?
Looking at purchasing but need some accuracy reassurance first. I would expect the refresh to be much higher to justify accuracy of the posted times in .01 resolution.
Thanks
sspade2468.50
      05-01-2022, 07:30 AM   #2
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Regardless of the engineering questions. It's been proven to be fairly accurate. I myself have proved it to be within a few hundreds or sometimes thousands of actual time slips.
It's no worse than the margin of error you get with a timing system at a track.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      10-26-2022, 06:11 AM   #3
mode.grau
mode.grau's Avatar
Drives: 17 340 M-Perf Ed. Fashion Grey
I can only assume (and hope) the software is analyzing the trend of data points and interpolating to get the last decimal place. Of course that means you have a margin of error, but over the course of 30-100 data points (@10hz), your margin of error should be fairly low.
2017 340i M-Performance Edition (ZE0) - Individual Fashion Grey // Extended Black Merino Leather - xDr 8AT - THP - MPPSK
Previous Cars:
2017 340i xDrive 8AT
2019 Golf R 6MT
      01-01-2023, 05:38 PM   #4
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
Inertial sensors and timers is how. The AIM Solo 2 has a 10hz GPS and gives the same functionality and racers use AIM. The counterpoint being they also use transponders for the official times. So you probably have a bit of a point.
f30post
