07-11-2023, 05:42 PM | #1 |
Rep 228
Jack Points
How nice of BMW to provide these convenient jacking points.
Does anyone have any idea what style (P/N) of scissor jack these hard-points are designed for? |
07-11-2023, 05:45 PM | #2 |
Not great. Not terrible
7445
Rep 2,700
You can get pucks for those anywhere.
For example, just search "BMW Lift Pad" in Amazon. https://www.amazon.com/s?k=bmw+lift+...s_ts-doa-p_1_8
Current: 2024 BMW X3 M40i.
07-11-2023, 05:58 PM | #3 | |
Rep 228
///M TOWN16543.50 |
07-11-2023, 06:11 PM | #5 | |
7445
Rep 2,700
https://f30.bimmerpost.com/forums/sh....php?t=1979927
Trogster459.00 |
07-11-2023, 06:22 PM | #6 | |
Rep 228
JustinHEMI7445.00 |
07-11-2023, 06:46 PM | #7 |
Commander-In-Chief
2122
Rep 8,924
You can fine the OEM BMW which fit the jack point ones online or at you dealer but they, of course, are more expensive than the Amazon ones.
Trogster459.00 |
07-12-2023, 08:10 AM | #8 |
Rep 175
I didn't use anything other than the flat pad on my floor jack with my 135i. I never had any issues.
But, my G87 has, um, more of it to love, so I just ordered the amazon pads to fill the rectangle on the lift points. |
07-12-2023, 10:29 AM | #9 |
this is the way
18151
Rep 8,527
I've been using hockey pucks forever but my currently daily which is lowered requires I jack the front slightly to get enough clearance for the jack/puck in the rear. I see there are prime day deals on the BMW pads so I also pulled the trigger. Since they sit partially into the jack points it'll provide me the extra clearance I need.
07-19-2023, 07:53 AM | #10 |
Rep 92
Sorry if this is a stupid question, but given this setup, is this car not meant to be used with jack stands? How would you use the floor jack to get the car up and then get a jack stand on that same point?
07-19-2023, 08:23 AM | #11 |
Commander-In-Chief
2122
Rep 8,924
On my F82 I put jack stands at the control arm pickup points.
07-19-2023, 09:56 AM | #12 | |
16544
Rep 8,425
I drive my car on to a wood block on one side only to get the front end up slightly Then I used the front stiffening plate’s center jack point and I lift the car with a low profile floor jack with a hockey puck sandwiched between them… Then I place jack stands at the front two jack points, also using hockey pucks (My wife is Canadian 😂 Super easy to change the oil or remove wheels
Tag18150.50 |
07-19-2023, 10:15 AM | #13 |
this is the way
18151
Rep 8,527
07-19-2023, 01:27 PM | #14 |
7445
Rep 2,700
There are jack points front and rear (rear diff).
