09-09-2021, 02:50 PM | #1 |
BimmerPost Supporting Vendor
4169
Rep 2,320
ACM | E90 M3 Track Build
Here's the latest iteration of our friend, Claudio's E90 M3 track car we've been building for him over the last few years. Also attached some photos of the goodies in and under the car that can't be appreciated on the ground
Mod List: Forgeline GS1R Wheels 18x10.5 square StopTech Trophy BBK Ohlins Dedicated Track Coilovers Burkhart brake cooling ESS Tune Alpine GTS DCT software WPC rod bearings w/ APR bolts BimmerWorld P/S reservoir Rogue Engineering Stud Kit Challenge E90 diffuser Aim Solo 2 Aim Solo Smarty Cam Custom Aim solo center console bezel mount OMP WRC-R seats Planted floor mounts Schroth 6pt harnesses Brey Krause harness mounts Rennscot harness supports M Factory Carbon Fiber Driveshaft Akrapovic Evolution exhaust Fall Line Motorsports Half Cage paint matched by IND Interlagos blue side markers by IND Diffsonline 3.64 LSD differential w/ Motul FF track fluid Eventuri plenum intake Hardmotorsport trunk panel replacement H&R sway bars SPL Parts Front lower control arms SPL Parts Front tension rods SPL Parts Front tie rod ends SPL Parts Front sway bar end links SPL Parts Rear sway bar end links SPL Parts Rear toe arms with eccentric lockout kits SPL Parts Rear upper arm links Turner Motorsports Solid Rear Subframe Bushing Kit Do88 DCT Oil Coolerwith carbon air duct Do88 Power Steering Oil Cooler Do88 Radiator CSF oil cooler Trackspec hood luvers Mashimarho fender vents APR front splitter Professional Awesome quick release chassis mounts Professional Awesome splitter struts Professional Awesome front splitter diffuser pieces BimmerWorld front canards Status Gruppe front lip APR 67" air foil Hard Motorsport chassis mounted wing uprights Last edited by Matt@AUTOcouture; 12-28-2021 at 02:20 PM.. |
9
spazzyfry1234378.50 donut_boi997.50 aerosynch322.50 reidetailing646.50 slcook541863.00 sansin16.50 M3 boi3211.00 Rochen_00351.00 Paco1M101.50 |
09-13-2021, 01:56 AM | #2 |
Rep 23
truly love this car and how much attention to detail you guys put into the cars that come through the shop. I really appreciate you guys help on my SS E90. If you don't mind me asking what size wheels are on this car?
Matt@AUTOcouture4169.00 |
09-16-2021, 05:02 AM | #3 |
Rep 291
Awesome build, as always.
09-17-2021, 07:39 AM | #4 | |
4169
Rep 2,320
thanks! |
09-21-2021, 10:43 PM | #5 |
Alex - IG @screamer
647
Rep 483
Incredible work as always ACM team!
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
10-04-2021, 10:18 AM | #6 |
wannabe
252
Rep 819
Incredible as usual.
E90 M3 - 6speed - slicktop - single hump
10-24-2021, 09:14 PM | #7 |
Rep 269
Amazing build. Would you please list the mods? Especially interested in the suspension parts and cooling. Thanks
g.m00149.00 Matt@AUTOcouture4169.00 |
10-27-2021, 07:56 AM | #9 |
Rep 245
List of mods please. This is an amazing build.
10-27-2021, 12:27 PM | #10 | ||
4169
Rep 2,320
08-08-2022, 04:49 PM | #12 |
Rep 259
Your build is amazing!!! 285/35/18 squared??
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position |
reborn10.00 |
