      06-27-2022, 03:03 AM   #1
tranquility
sportscars only
tranquility's Avatar
Drives: 2011 Z4 sDrive 35i
What's the WORST design aspect of your vehicle or other vehicles you know of?
For my car (2nd gen Z4), it's gotta be the HORRIBLE rainwater dispersing 'sys' (whatever the term is...). I'm not a technical expert, but apparently this is a common prb and is caused when some seal fails so that water instead of channelling safely away, goes into the trunk behind some panel and can even flood the battery and roof's hydraulic pump sitting underneath the trunk's floor. Can't believe they designed something so flimsy, relying on just some lousy rubber seals. Funny thing is that they thought of this potential hazard and bothered to encase the battery in some foam material and even put the pump on stilts!!! How about saving all that engineering brainpower and just make a simple and effective waterway!
/rant
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
      06-27-2022, 06:14 AM   #2
its55
2008 BMW E92 M3
281
Drives: BMW M3
I suppose w/ the E9x M3 its got to be the rod bearing tolerances.
      06-27-2022, 08:03 AM   #3
Chihuahua
Chihuahua's Avatar
4469
Drives: E30 329iS, E65 Alpina B7
My company car 2020 Ford Escape. It's worst feature is the whole thing.
      06-27-2022, 09:29 AM   #4
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [8.01]
The way dirt gets trapped in the rain channels in the trunk area of my F87.
      06-27-2022, 09:47 AM   #5
Westside Guy
Westside Guy's Avatar
7263
Drives: 22 Z4 M40i, 21 228i Retired
The horrible location of the cup holders in my 2022 G29 Z4.
The passenger cannot even rest their arm on the center console and the driver's elbow constantly hits the cups.
BMWGirlFL6834.00
POBEP415.00
M8Bimmer1398.00
      06-27-2022, 09:59 AM   #6
BMWGirlFL
BMWGirlFL's Avatar
Drives: Z4 M40i
And large cups don't fit.
      06-27-2022, 10:03 AM   #7
GTF
GTF's Avatar
Drives: 2021 M340i, 2024 X1
I've been buying new vehicles since 1968, and could always find major or minor irritants, but far fewer as time went by. The last several purchases have been about perfect....Porsche Macan S, BMW X-5, and an M340i. The only comment on the M340i is that the horn requires way too much pressure. Wish my earlier purchases were that perfect. Also would have liked a silver and nice metallic red as color options.
      06-27-2022, 10:17 AM   #8
jp1984
Drives: an E92
E9x cup holders as a design flaw made consciously.
      06-27-2022, 10:43 AM   #9
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2012 BMW 335i  [5.25]
2012 BMW 335is  [5.00]
2008 Infiniti QX56  [0.00]
1967 Chevrolet Corv ...  [10.00]
2001 M Roadster  [10.00]
2022 BMW 540i  [0.75]
2009 528i  [9.50]
On our new G30, there is no automatic fan setting for the HVAC. The owner's manual says to set the "intensity" manually. Just wow. Or perhaps I don't understand how to automate it. Every other car we own will automatically vary the fan speed, except for the Z.
      06-29-2022, 06:39 PM   #10
It’s the stupid stuff that drives me crazy. If it’s not broken, don’t fix it. For example, the climate control was a knob for the temperature. If you wanted to go from heat to air, you just spun the knob and went from 74 degrees to 60 in no time. NOW, you have to press the stupid arrow 14 freaking times!!! No big deal most of the year but during season change, it’s a pain in the ass to go from heat in the morning to AC in the afternoon.
The auto for wipers was a flick up on the stalk in the 2000s. They then changed it to a button on the end of the stalk. Perfect! They changed it back to a flick up.
Don’t even get me started on the cargo area of the Xs. I had two areas that were secure. On had a net and the other a strap. It was great for holding washer fluid, windex and whatever other nonsense. They are gone. No way to secure anything.
And what about 21 inch wheels for winter wheel and tire package? WTF? Don’t the engineers know a narrower contact patch is better with a bigger sidewall? I’m now at 295s. Winter set up used to be 19s or 20s with 255s and then 275s.
OK. Rant over.
      06-29-2022, 11:05 PM   #11
BimmerMat135
Drives: E82M/S213 E450 A/T
The wiper control arm on the F31 every time you need windshield washer you have to des activate the rear wiper. Also if you start the car with the rear wiper « on » you have to use the rear window washer to get it going what a stupid design.
      06-30-2022, 04:51 AM   #12
HighlandPete
Drives: BMW F11 535i Touring
Still automatic, BMW give you one additional feature of choice.
Just choose the 'intensity' level you prefer, for range of airflow, and leave the Auto function to do the rest. Each have their own characteristic curves for blower control, air distribution and air flap control.
BTW, 'intensity' levels (different automatic programs) have existed for about 20-years. In a 5-series, since the E60.
      06-30-2022, 04:59 AM   #13
HighlandPete
It’s the stupid stuff that drives me crazy. If it’s not broken, don’t fix it. For example, the climate control was a nob for the temperature. If you wanted to go from heat to air, you just spun the nob and went from 74 degrees to 60 in no time. NOW, you have to press the stupid arrow 14 freaking times!!! No big deal most of the year but during season change, it’s a pain in the ass to go from heat in the morning to AC in the afternoon.
Isn't the answer in the name "Climate Control"? For me, it is "set and forget". Mine has an Auto setting with a built in thermostat.
      06-30-2022, 06:18 AM   #14
grannyknot
grannyknot's Avatar
1010
Drives: 2008 Z4M coupe
/rant
Well for an E86 Z4 MCoupe it would be the rain water holding system otherwise known as the bird bath or duck pond.
It's a feature on the rear deck lid/hatch that allows birds to enjoy hours of swim time, it is also has the added feature of encouraging rust on the submerged metal.
2008 E86 M coupe
      06-30-2022, 06:34 AM   #15
Tambohamilton
Drives: E91 330d
When you engage auto wipers on the e9x the status light is right behind the rim of the steering wheel, so you have to crane your head around to see what it's actually doing or press the button (again) until you get a response.
Also in RHD models the pedal offset sucks! I wouldn't need a dead pedal if the actual pedals were in the right place, and the pedals could be in the right place if the dead pedal wasn't there. And the clutch pedal sits too high.
I can't disable the interior lights when opening a door or unlocking, and they don't even poll the light sensor to figure out if they might be needed or not.
I'm sure there are more, but I've forgotten them for now...
      06-30-2022, 07:25 AM   #16
HighlandPete
You do have the option to switch interior lights off.
      06-30-2022, 09:55 AM   #17
AndyBrad
Drives: M3 e92
Im new to BMW so you may all love this but...
indicators. You go to press them gently and they click on and then return to center. so you go to turn them off and end up putting them on in the other direction. Maddening.
POBEP415.00
      06-30-2022, 10:28 AM   #18
///MPhatic
The Seeker
///MPhatic's Avatar
15364
Drives: OG M2 • Exige
2018 BMW M2  [8.75]
Off the top of my head...
BMW M2 - Long fart sound upon throttle lift in gear
Lotus Exige - No seat rake or height adjustment (because everyone is the same size)
Acura RDX - Door integration into the rear quarter panel lip
IS 350 FSport - Trans tunnel encroaching into the driver's footwell
      06-30-2022, 11:15 AM   #19
Tambohamilton
Drives: E91 330d
Where/how?
      06-30-2022, 11:45 AM   #20
HighlandPete
Where/how?
Should be in the User Manual.... Just press the main interior light switch (while lights are on) until the lights go out. They will stay off until you press again to switch on. Which you can do anytime you want the lights.
I don't run my interior lights in summer, haven't done so for 20-years in my BMWs.
      06-30-2022, 11:56 AM   #21
dutchm2
dutchm2's Avatar
Netherlands
1762
Drives: BMW M...
Not the worst but if I could ask I would love to have the native wide body as M cars most do have! It will gives a much better looking!
....Life is too short to drive boring cars
F87 Coupé M2 LCI DCT
BMW F20 M140i gone | BMW E81 120i UA71 gone
      06-30-2022, 04:59 PM   #22
charlescm14
Drives: 2018 X3 m40i. RS5 sportback
Apologies, but wanting real M styling on a M-light should not count as a " worst design aspect" . I Drive an M-light ( X3 M40i) , and I would love to have the styling of the real Ms, but I did not buy one. BTW Your car is already beautiful
as it is. But, we gotta respect that the boys( and girls) who own real M cars deserve the design and performance upgrades they paid for.
Just my 2 cents, but like I said, I think your car is already really great looking !
happy driving
dutchm21762.00
paquet631.50
ai38868.50
