06-07-2016, 12:34 AM | #1 |
BimmerPost Supporting Vendor
3890
Rep 54,576
Drives: F80 M3
Ferodo F2x F3x F87 F8x DS1.11 Race Pads
DS1.11
The DS1.11 is one of Ferodo Racing's latest endurance race pad offerings. It has slightly less bite at high temps. vs their older DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. The DS1.11 can be thrashed all day without having it burn up or fade, it's easy on discs, and doesn't have many of the judder or vibration issues that competing products have. If you want an extremely solid, all around race pad that will perform well and last a long time, the DS1.11 is the perfect choice. Fits all F2x F3x F8X F87 with 4 piston front and 2 piston rear brakes. ***Will not work on Carbon Ceramic Brakes*** $787.59 for the complete front and rear set Order here: https://hpautosport.com/product/fero...-11-race-pads/ Last edited by HP Autosport; 07-16-2023 at 12:08 PM.. |
07-14-2016, 09:50 PM | #3 |
Rep 3,456
Drives: Harrop E90 M3
Which pads are louder, these or the RS29? Assuming the Pagid has more bite than these pass will?
07-15-2016, 01:23 PM | #4 |
3890
Rep 54,576
Drives: F80 M3
