      06-14-2022, 01:52 PM   #1
Tag
this is the way
Tag's Avatar
20006
Drives: N-1 starfighter
Question Contest: How much will the G87 M2 weigh?
We know the G87 is based off the G42, but is not equipped with X-Drive. Here are some stats to help you make an educated guess. These figures are for the NA model M240i X-Drive w/AT.
M240i X-Drive w/AT Curb Weight: 3,871 lbs (it's a real porker)
M240i X-Drive w/AT Weight Distribution: 52.6 / 47.4
BMW's global website shows the upcoming M240i RWD is 55kg (121 lbs) lighter than the X-Drive model.
My guesstimates are as follows...
  • Base G87 MT Curb Weight: 3,742 lbs
  • Base G87 AT Curb Weight: 3,780 lbs
  • Base G87 Weight Distribution: 52.1 / 47.9
What are your guestimates? Winner gets bragging rights, will be featured on the front page of bimmerpost and get an all expense paid trip to ///Mexico!
      06-14-2022, 02:11 PM   #2
LivingInSalt
Drives: 2023 BMW M240i
So you think the AT M2 will weigh more than the rwd 240?
      06-14-2022, 02:15 PM   #3
Tag
this is the way
Tag's Avatar
20006
Yes, the G87 has more bracing, two turbos instead of one dual scroll, more cooling, dual full length exhaust pipes, etc. Just my guess, I could be way off, but I sincerely believe it'll weigh more and maybe even more than my guesstimate.
Put in your guestimate.
Germanauto9843.50
Moflow2498.50
koastal384.00
      06-14-2022, 04:39 PM   #4
Project_F87
Project_F87's Avatar
Drives: 2020 M2C LBB 6MT
G87 MT: 3690 lbs
G87 ZF: 3728 lbs
Just my guess but I'm probably way off lol
Instagram: @Project_F87
Tag20005.50
      06-14-2022, 04:46 PM   #5
StickyPickle
Drives: NA
Wasn't confirmed somewhere by BMW that the G87 curb weight will be somewhere between the F87 w/ manual (3,561lbs) and the G82 base w/ manual (I've seen it reported as low as 3,690lbs)?
If so, my guess is around 3,595lbs for the manual G87 and 3,633lbs for the auto. Hoping to lose at least another 50-70lbs with carbon fiber roof and seats
      06-14-2022, 05:00 PM   #6
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
Problem with all G series cars is that they share the same CLAR platform. So no matter what, it won't be as light as the F87.
From Car and Driver, the weight of the 230i is 3,554 lbs.
My guess would be somewhere between the 230i and the 240i's 3,871 lbs.
Splitting the difference is 3,713 lbs. I would imagine that would be the lowest possible weight with the carbon roof and seats.
So manual with low weight options: 3,713 lbs.
Auto without any low weight options 3,803 lbs.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
Tag20005.50
Moflow2498.50
      06-14-2022, 05:52 PM   #7
T_U_D
T_U_D's Avatar
6707
Drives: G05 LCI
2023 BMW M2 (G87) M2 weighs between old M2 and M4 Coupe https://www.bmwblog.com/2022/06/14/2...m2-g87-weight/
      06-14-2022, 06:11 PM   #8
StickyPickle
Drives: NA
It was the M2 and the M4, I mistakenly said the M2CS. In this article, they said the trims mentioned for the weight comparison were that it's heavier than the F87 M2 competition but lighter than the M4 rear wheel drive (doesn't specify base or competition trim) and the M240i xdrive.
"I can't tell you how much it weighs, because BMW wouldn't confirm that, but I did lever out of the engineers that it's heavier than previous M2 but lighter than both the rear-wheel-drive M4 and M240i xDrive"
https://www.pistonheads.com/news/ph-...h-review/45792
T_U_D6706.50
      06-14-2022, 09:17 PM   #9
EXE46
EXE46's Avatar
Drives: 2020 M340i RWD Aka New E39 M5
Can't be that heavy, must be sub 3800lbs for both variants.
Prior's: E36, E46 x2
      06-14-2022, 10:42 PM   #10
koastal
Australia
384
Drives: F87
More than a M4 !!
      06-14-2022, 11:04 PM   #11
solstice
Drives: 2015 M3 6MT
Originally Posted by Project_F87 View Post
G87 MT: 3690 lbs
G87 ZF: 3728 lbs
+1
3871 M240i - 121 RWD - 21 CF seats - 50 CF roof / no moonroof = 3871 - 192 lbs = 3679 lbs.
Add some weight for wider track, beefier suspension, more rubber and additional bracing. Remove some weight for some steel parts replaced with alu and I think your numbers will be very close.
      06-15-2022, 12:31 AM   #12
Project_F87
Originally Posted by solstice View Post
+1
I would certainly be a very happy man if we're on the money here. I can live with a ~90 pound gain from my previous M2C
Tag20005.50
solstice5509.50
m20e30871201.50
      06-15-2022, 01:08 AM   #13
M3WC
+1
$6800 for seats and roof.
CF roof - $3000
Buckets - $3800
Hopefully the G87 is standard no moonroof, that is where the majority of weight savings is anyways.
      06-15-2022, 01:16 PM   #14
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
+1
+more turbos, more intercoolers and piping, plus transmission coolers, etc. The CF roof wont save 50 lbs, the difference between the standard aluminum roof (18 lbs.) and the CF roof (7.5 lbs.) is a measly 10.5 lbs.
Adding up everything else, probably closer to 110 lbs on top of your estimate. I think she will be a porker.
2020 MK 7.5 GTI
Tag20005.50
      06-15-2022, 03:43 PM   #15
solstice
Drives: 2015 M3 6MT
Don’t forget that the M240i comes standard with a huge moonroof. Easily 35-40lbs worth of glass and mechanics.
      06-16-2022, 08:53 AM   #16
ASAP
ASAP's Avatar
10865
Drives: '23 X3 M40i
With an auto perhaps 3750 lbs...
As a point of reference... this is the weight of a 2006 Lexus GS350.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      06-16-2022, 11:24 AM   #17
Tag
this is the way
Tag's Avatar
20006
My guess would be more like 25 lbs for the moonroof. Aside from the glass it's just some rails and a small electric motor. Nonetheless it's a good amount of weight to remove from the roof.
      06-16-2022, 12:02 PM   #18
StickyPickle
Drives: NA
Glass is heavy, wouldn't be surprised if there was around a 50lb difference without the moonroof
      06-16-2022, 12:09 PM   #19
solstice
Drives: 2015 M3 6MT
Yes, the CF roof vs steel and the moonroof delete together should be 50 lbs or more. Here’s a guy weighing the much smaller 135i moonroof at 32 lbs.
      06-16-2022, 12:09 PM   #20
Tag
this is the way
Tag's Avatar
20006
Look at the weight of the glass and frame on an F87, roughly 20 lbs.
2' F87 M2 LCI M2 Competition Lift-up-and-slide-back sunroof
Glass cover: 5.118KG / 11.28 lbs
Frame sliding-lifting roof complete: 4.145 kg / 9.14 lbs
      06-16-2022, 01:26 PM   #21
solstice
Drives: 2015 M3 6MT
And the same site says the complete moonroof kit altogether weighs only 4.145KG which can't be right
Weights on these parts sites are notoriously unreliable. It had the HUD at something like 100 lbs that someone referenced over in the M3 section.
      06-16-2022, 01:27 PM   #22
Tag
this is the way
Tag's Avatar
20006
Not sure what you're referring to. Where do you see that?
