BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      10-25-2024, 08:16 PM   #1
it.g.ma_g87
Senpai
it.g.ma_g87's Avatar
Drives: 24' M2
Recommendations for CAMBER Plates
Looking at vorshlag, millway and ground control. My cars front camber is not equal after lowering on HR VTF (surprise LOL). Want plates to fix this.
Any reviews of any of these plates?
IG: it.g.ma_g87
      10-25-2024, 08:26 PM   #2
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Other brands might be easier to obtain, but we still go out of our way to import/stock Millway. They make fantastic parts.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
Polo088161653.50
      10-25-2024, 08:36 PM   #3
it.g.ma_g87
Senpai
Drives: 24' M2
Can you provide any insight as to why you recommend Millway over the others? Very interesting thread regarding experiences with Millway.
https://g87.bimmerpost.com/forums/sh...1#post31014011
IG: it.g.ma_g87
      10-25-2024, 09:02 PM   #4
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Those look like they were damaged from over-torquing or impacted into place.
The good part is having the camber plates designed to have those threadnuts replaceable, as only the inserts need replacement and not the entire camber plate. That's forward thinking.
Polo088161653.50
      10-26-2024, 11:01 AM   #5
tylerdurdem
Drives: 2023 BGM M2
I have Vorshlag, no complaints.
      10-26-2024, 03:30 PM   #6
M_Power Rob
Drives: '23 M240 and '23 M2
Honestly haven't heard of H&R's causing this issue...sure the place you took it to didn't have an issue with their alignment?
      10-27-2024, 12:51 AM   #7
it.g.ma_g87
Senpai
Drives: 24' M2
any issues with clicking or noise?
IG: it.g.ma_g87
      10-27-2024, 10:13 AM   #8
tylerdurdem
Drives: 2023 BGM M2
Nope.
      10-28-2024, 03:57 PM   #9
Ehloo
Drives: 15 x5 m
not understanding fully the point of camber plates. from what i understand you can adjust camber. i would personally like to adjust my front camber and bring the wheels back out. less camber. Would camber plates achieve that or just add more negative camber
      10-28-2024, 04:05 PM   #10
it.g.ma_g87
Senpai
Drives: 24' M2
you cannot adjust camber on the stock strut of the fronts. Camber plates allow you too
IG: it.g.ma_g87
Polo088161653.50
      10-28-2024, 08:33 PM   #11
youloze
Drives: 2020 BMW 330i
Not trying to hijack the thread, but do any companies make an adjustable control arm to adjust camber in the front? I've Googled and looked around, but haven't found any. I'd rather have adjustable arms than camber plates.
      10-28-2024, 08:44 PM   #12
IanH
Drives: '25 M240xi
Unequal camber in the front usually means subframe off center. Did they try to fix it that way? (This was my experience on other cars at least)
2025 M240i Xdrive TNM - Dinan Springs - CF Goodies - More in process
      10-29-2024, 05:25 PM   #13
Ehloo
Drives: 15 x5 m
figured that and might be going this out. too much camber in the front and wheel fitment doesn’t look right. was going spend some money on a 5mm spacer but the camber plates seem like a better option
i am reading not all springs work with certain plates. i have AST Has. anybody know which plates work
      10-29-2024, 09:41 PM   #14
it.g.ma_g87
Senpai
Drives: 24' M2
Gotta do some research man…
IG: it.g.ma_g87
      10-29-2024, 09:59 PM   #15
LeggoRacing
LeggoRacing's Avatar
397
Drives: M2
If springs are meant to work with stock hardware then milway plates will work
      10-29-2024, 11:07 PM   #16
Xspeedracer
Auto Tech by day, track guy or car events on weekends
Xspeedracer's Avatar
Drives: 2023 M2
2023 M2  [10.00]
https://www.splparts.com/g8x-m3-m4-2022/ but you better know what your doing and have the car on a alignment rack to make changes it can be very time consuming
      10-30-2024, 09:27 AM   #17
youloze
Thanks! Steep, but I have SPL on my other car and they are top notch.
