BMW M2 Forums 2023+ (G87) iDrive, Nav, Stereo, Bluetooth, Electronics
      01-15-2024, 03:01 PM   #1
M2compcharlie
M2compcharlie's Avatar
Drives: BMW M2 H
BimmerCode coding issue
I tried to code auto/start stop off, 5 times turn signals and no hazard lights on harsh braking and none of the changes have worked. I used the same process as I have done with my F87 and Bimmerocde showed a successfull coding message but once disconnected, the coded changes weren’t there. Has anyone else had the same? Maybe BMW have found a way to stop aftermarket coding on the latest cars?
      01-15-2024, 03:17 PM   #2
fangelov
Just to make sure you turned the car off and back on before checking for the changes?
      01-15-2024, 03:18 PM   #3
M2compcharlie
Drives: BMW M2 H
Yes I did and still no changes
      01-15-2024, 05:05 PM   #4
NewToM
NewToM's Avatar
Drives: M2 G87 Brooklyn Grey
2024 BMW M2 G87  [9.12]
Did you code from the M2 or M3. I believe that there are more options under the M3. I can tell mine worked because my ambient lighting is purple.
      01-15-2024, 06:53 PM   #5
JABCAT
Professor
JABCAT's Avatar
2256
I'm having issues connecting after it connected once. I was able to code the B&W audio and no warning message on the screen at start up.
Re: auto stop/start, you don't have to code it off, you can program it off for both M buttons & once you hit the button to turn it off, it doesn't come back on for any drive mode.
      01-15-2024, 10:07 PM   #6
sammyj
sammyj's Avatar
Drives: G87
I’m sorry to ask but did you actually check your settings in idrive after coding? Like 5 blink turn signal doesn’t actually make your turn signal blink 5 times, it just gives you that additional setting under your 3 times. You still need to go into idrive and enable it…
Just a thought, as it confused me for a bit too!
Whoever said "money can't buy happiness" clearly never drove an M2.
aerobod3625.50
Rx-7ames1894.00
Sculpin276.50
      01-16-2024, 04:14 AM   #7
M2compcharlie
Drives: BMW M2 H
Thanks for the suggestion and I will try doing that now 👍
NovaChris205.00
      01-18-2024, 11:31 PM   #8
Rx-7ames
Rx-7ames's Avatar
1894
Drives: '23 M2
2023 BMW M2  [5.00]
This was me too! I thought it just didn't work. Then, one day, there it was in the settings.
      01-26-2024, 01:17 PM   #9
JABCAT
Professor
JABCAT's Avatar
2256
Which settings is the blinker under? I've gone through every settings app ( I think) and don't see it.
      01-26-2024, 01:38 PM   #10
Rx-7ames
Rx-7ames's Avatar
1894
Drives: '23 M2
2023 BMW M2  [5.00]
Exterior lights. Duh! Just kidding. I looked for 10 minutes one day and then did a face-palm.
M2siast5876.00
      01-26-2024, 01:44 PM   #11
JABCAT
Professor
JABCAT's Avatar
2256
Much appreciated !
