11-17-2023, 03:53 PM | #1 |
Rep 33
Tire Sizes for Track Use
Hey there, was curious what the consensus is on tires
size for this car on track use. I know about the different brands. but curious tire sizes and wheel sizes. Thanks! |
11-17-2023, 07:11 PM | #2 |
Rep 334
There are more tire options if you use 19" wheels but an 18" wheel combo will be a few pounds lighter all other things being equal.
As far as width, I fit 295s with zero rubbing. I could fit 305s up front with a 5 mm spacer.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43 |
11-17-2023, 09:35 PM | #3 |
Rep 95
For me 19 square gives me a lot of tire choices, ability to rotate tires, ample clearance between calipers, and a decent amount of sidewall to keep handling sharp while not risking an easy blow-out at a berm. The car appreciates more rear grip but if you enjoy rotating a car through a turn with your right foot, a square setup is more engaging.
11-20-2023, 11:56 AM | #4 | |
Rep 374
gcmak153.50 tj_lethal187139.00 |
11-20-2023, 05:16 PM | #5 |
Rep 2,391
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Keep in mind the 18s generally have better heat dissipation due to thicker sidewalls.
I'm considering a square set of 18s because both RE71Rs and A052 come in 295 35 18.
Pass me if you can.
Sherlock997234.00 DutchBoysRacing162.50 |
11-20-2023, 05:33 PM | #6 | |
Rep 95
275/35/19 (same as OEM) on 19x10 rim (same as OEM but w/12mm more offset). The RE71RS tire profile/shape on the 19x10 looks great to me. |
06-01-2024, 05:45 AM | #9 |
Rep 512
Hey guys I’m also looking into the best wheel and tire sizes for track. My concern is with xdrive cars I understand there is some 1% rolling diameter difference rule otherwise you screw the xdrive up. I don’t really understand it and would appreciate some examples of what I can and can’t do.
Was thinking 18 inch wheels and Nakang AR1s not sure on width and profile |
06-08-2024, 11:32 PM | #11 | |
Rep 92
There are a ton of 275-295 size tires in 18 but getting into the 305+ sizes get a bit tough. Ironically the 305/30/19 SuperCar3R are cheaper than 295/30/18 so
@DutchBoysRacing
07-06-2024, 08:48 PM | #12 |
king of the hills
109
Rep 2,923
Drives: 2011 M3 w/ESS55, 2001 540i/6
Is 3mm between tire and strut tube too close?
Nitto NT01 305/35R18 on Apex wheels |
daddyjaxx109.00 mike082802124.00 |
08-02-2024, 04:00 PM | #14 |
Rep 66
08-03-2024, 06:40 AM | #15 |
Rep 107
Sure thing. I kept it simple for now
Millway camber plates Eibach springs 15mm front spacer (gets you about 4mm clearance from tire sidewall to factory strut), 12mm rear (not really needed ) Front camber -3.4, 0 toe Rear camber -2.2, slight toe in It’s a rather beefy setup and JUST clears everything. The Goodyear is likely the widest of the 305 tires , so others would allow even better clearance and could step the front spacer down to a 12mm. If you run the Titan wheels from PHD you may not have to mess around with spacers Apex 19x11 +22 |
daddyjaxx109.00 |
