05-22-2023, 11:15 PM | #1 |
Rep 45
exhaust button valve fully open?
Tried to search the forum first but did not find the answer so trying to ask current G87 owner for the question:
When you press the exhaust button near the gear shift, does it fully open the exhaust valve like you put the engine sound to Sport Plus in driving mode? I know that when in Sport vs Sport Plus the valve on the exhaust open differently resulting in “half opened” exhaust vs “fully opened” exhaust. So I’m wondering if you just press the button on any mode, does it function equivalent to Sport Plus exhaust notes? Curious! FYI user manual @ page 131 only said it will put the exhaust in a “sporty nature” lol. |
05-23-2023, 07:52 AM | #2 |
Rep 3,016
Drives: 2019 M2 Competition
This will do it and its a really easy install:
https://www.kiesmotorsports.com/prod...3612373?aff=25
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
05-23-2023, 08:36 AM | #3 | |
Rep 2,983
Drives: A Family Sedan
I guess you can’t code that stuff because the DME controls it, so only a tune would right |
Ravenseal2726.50 |
05-23-2023, 09:34 AM | #4 |
Rep 1,408
Forgot the name of the company, but I paid around $200 for my previous G80. Will be re-installing on G87. Not sure if they are still available though. Got it from Mike. mike@x-ph.com
05-23-2023, 12:23 PM | #5 |
Not great. Not terrible
7442
Rep 2,700
So I still don't know what that fuckin button really does. I've tried it, and I hear a change in sound, but I'm not sure if it's manipulating valves or just changing the piped in sound. To me, it should be a simple 1 and 0 button, valves open or valves closed, but I'm sure the Germans put a lot more engineering into than that.
Current: 2024 BMW X3 M40i.
05-23-2023, 12:42 PM | #6 | |
Rep 1,545
Accentu8702.50 |
05-23-2023, 01:44 PM | #7 | |
Rep 45
It should be in a manual just freaking say the button put the exhaust on equivalent of what sport or sport+ mode sound and/or increase the pump in audio etc. and it literally just say: Attached photo |
Sherlock997217.00 |
05-24-2023, 12:11 AM | #8 |
Rep 2,983
Guys, the flaps only open in Sport and Sport+, not in Efficient.
Put the engine in Sport and push the button. You’ll hear the change in exhaust tone to a lower and louder tone. The button does nothing in Efficient. |
twenty2twos37.50 Rx-7ames1892.50 |
05-24-2023, 04:44 AM | #9 |
7442
Rep 2,700
So is is operating the valves, changing the piped in sound, or both?
05-24-2023, 07:58 AM | #10 |
Rep 2,983
JustinHEMI7442.00 |
08-17-2023, 09:47 AM | #11 |
Rep 178
Thread being revived, but has anyone found a way to fully open the exhaust? Just heard my buddies 2023 G80 M3 with the Dahler kit and it sounds more aggressive which I liked.
Assuming our exhaust is the same on all the G8X platforms, this explains it pretty well. I also found this other valve controller for much cheaper. https://irlllc.com/products/irl-valv...roduct-reviews |
08-17-2023, 12:29 PM | #12 | |
Commander-In-Chief
2115
Rep 8,918
Chris13002333.50 |
08-17-2023, 12:30 PM | #13 |
Private Low Class
300
Rep 278
Somebody commented on a DIY solution about a month ago -- where you can physically unmount the valve controller box(es), manually rotate to open, and re-mount in a way that they stay open all the time. I think he was from another model forum and I can't find it at the moment. If it were that simple I think I would prefer it to a valve controller or coding. Not sure if it has some negative side effect such as damaging the solenoid, etc.
08-17-2023, 02:00 PM | #14 | |
Commander-In-Chief
2115
Rep 8,918
08-17-2023, 02:02 PM | #15 |
Commander-In-Chief
2115
Rep 8,918
Muffler button
If in Sport of Sport+ mode it closes the valves to make it quieter. Does nothing in Efficient mode.
08-17-2023, 02:17 PM | #16 |
Rep 2,983
08-17-2023, 06:49 PM | #17 |
Rep 291
Newb question perhaps but after watching the install video above, is this just a sort of piggy-back module for controlling the valves to full open? It didn't look like any of the actual hardware was touched.
Also wondering if this would make any noticeable difference with the stock exhaust. Last edited by nype; 08-18-2023 at 12:23 PM.. |
08-17-2023, 06:58 PM | #19 | |
Rep 2,983
Valves seem to open more in Sport+. Still don’t open 100% without aftermarket interference. |
08-18-2023, 02:40 AM | #20 |
BMW M on my mind
337
Rep 460
I tested this earlier after reading this thread. The M exhaust sound button works in all three drive modes - either in Efficient/normal, Sport or Sport+ mode. I heard the difference, although notably less in the normal efficient mode - but still a change when engaged. It gets more pronounced in Sport and Sport+ mode - obviously the loudest/deepest increase resulted in Sport+.
22 G80 M3 Comp xDrive
23 G80 M2 MT 24 G05 X5 50e |
08-18-2023, 12:26 PM | #21 | |
Rep 2,983
On the outside, the exhaust flaps only open with the exhaust button ON in Sport/Sport+. |
08-18-2023, 01:20 PM | #22 |
BMW M on my mind
337
Rep 460
Wow, it is very convincing. Not that I do not believe you, but I am going to check this operation again outside the car.
