04-25-2022, 08:19 AM | #1 |
Rep 102
HIFI vs. HK Amplifier (RAM Booster)
Anyone know if the HK amp and the HIFI amp are interchangeable? I can get a cheap used take off HK amp if it's a direct swap to go from the 205w hifi amp to the 464w HK Top Hifi amplifier. If not Bavsound is what I'll probably do instead.
05-08-2022, 06:38 AM | #2 |
Rep 202
All I know is I love my HK
xcelir8bmw405.50 |
10-28-2023, 12:17 PM | #3 |
Rep 652
Did you ever getting a resolution to this ?
11-05-2023, 02:17 AM | #4 |
Rep 102
I ended up doing the bimmertech amp. Definitely recommend the upgrade if you want to upgrade the hifi system. Even if the HK amp did fit, the EQ would be way off and you'd be missing channels on the speakers.
11-10-2023, 09:02 PM | #5 | |
Rep 652
So did you find out that the HK amp wasn't a direct plug and play swap to the base stereo ? |
11-12-2023, 07:50 AM | #6 | |
Rep 102
Now for the Bimmertech Alpha One speakers, I'd probably choose different next time as the aluminum domes and cones are piercingly clear in some music and difficult to tune around versus poly or woven cones and silk domes https://www.audiotec-fischer.de/en/m...ifiers/up-8dsp Combined with a measurement microphone like a mini DSP U-MIK1 you can get nearly perfect response on a stock hifi system https://www.minidsp.com/products/aco...UaAhFjEALw_wcB Last edited by CTGT2005; 11-12-2023 at 07:57 AM.. |
11-12-2023, 09:07 AM | #7 | |
Rep 652
