New 2009 2010 BMW Z4 - ZPOST
      03-01-2015, 07:00 AM   #1
italy3541
italy3541's Avatar
58
Drives: Alfa Romeo 4C
Official E89 Factory Brake Upgrade Chart
Mods Please Sticky this.
This thread will be a compatibility chart for the different factory brakes that work on the E89. As many of us know trying to use the search function on this topic gets varied results. And most of time does not answer the question we are looking for.
So instead of having tons of different threads about it I figured it would be easier that have one with a complete list including all the years and also part numbers for the brakes that work.
I will update this thread as people post about what they used to do this upgrade. THIS IS FOR FACTORY UPGRADE PARTS ONLY NO AFTERMARKET KITS.
This will take some time as I have just started to research this and only have very limited findings at this point.
I expect this list to grow a lot as BMW has many different part numbers for the different years.
FRONT KIT ONLY I WILL UPDATE IF ANYONE FINDS A SOLUTION TO THE ELCTRONIC PARKING BRAKE
RESULTS SO FAR:
1 Series
E8X 2004-2011
6 piston BMW BBK
Unsure of compatibility
Part Number Front Left 34116786741
Part Number Front Right 34116786742
Link: http://www.ecstuning.com/BMW-E82-135...aking/Caliper/
Notes: Coming soon
2 Series
F22/23 2014-up
Part Number Front Left:
Part Number Front Right:
Link:
Notes: Plug and Play. Make sure to get 340mm x 30mm rotors for this setup. I have these installed on my car. It only took 1 hour to convert to this setup.
3Series
F3X 2011-UP
Caliper housing left 34116799469
Caliper housing right 34116799470
Link: Coming soon
3 Series
E9X 2006-2011
6 piston BMW BBK
Part Number: 34110444738
Link: http://www.ecstuning.com/Search/Site...4738/ES205607/
Notes: Plug and Play Kit
E90/E92 2007-2013
Link:
Notes:
M3/M4
F80/F82 2014-up
Link:
Notes:
      03-01-2015, 09:07 AM   #2
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
great idea
      03-01-2015, 09:13 AM   #3
italy3541
italy3541's Avatar
58
Originally Posted by Asbjorn View Post
great idea
Thanks, I hope some people who have done the upgrade post and let us know what they did what they used and how it worked out. Along with part numbers. This way I can update the first post.
      03-01-2015, 06:58 PM   #4
ttuner
ttuner's Avatar
68
Drives: z4
yeah this question comes up alot. good idea. thanks.
2011 BMW Z4 35i | FBO | VTT Stg 2+ (EK, 20T clipped)| Motiv PI| Motiv Tuned | Fuel-IT Stg 2 + inline fuel pump | Spec Stg 3+ clutch | MFactory flywheel | 606whp 575Lbs |
      03-02-2015, 03:47 AM   #5
italy3541
italy3541's Avatar
58
I should have some info today on the F3x brakes. Im waiting for a shop to get back to me on the parts needed.
      03-02-2015, 02:51 PM   #6
VailM3
Drives: 2011 Z4 35is
thank god question gets asked every week. I would also mentions the order regards to the upgrade. F30 > euro 35is > M-perormance
      03-03-2015, 07:41 PM   #7
ttuner
ttuner's Avatar
68
Drives: z4
sticky this!!
      03-06-2015, 05:35 PM   #8
italy3541
italy3541's Avatar
58
So my brake upgrade just got delivered today. They are the sport brakes from the M235i. I will post updates once I get them put on and let you know what was needed for them to work. Also I will be taking a look at the rear brakes and trying to figure out if there is a way to retro fit the electronic e-brake to the sport brakes. I would not hold your breath for a solution, as I doubt I will be able to make it work. But I will at least take a look and see if its possible.
      03-07-2015, 03:26 AM   #9
Gunzaro
Cyprus
37
Drives: Speed Racer
Thanks for the info. Was wondering if there were any reasonably priced kits that were an actual upgrade to the stock 35is fronts?
      03-07-2015, 05:59 AM   #10
italy3541
italy3541's Avatar
58
The sport kits from the newer 2,3,4 series are a upgrade. They provide the same stopping power but do not fade as quickly. So you will have better overall brake function. If you plan on tracking your car they are the better option. But if you only drive on the street then the 35is brakes will be fine.
      03-07-2015, 10:52 AM   #11
ForZ4
ForZ4's Avatar
Drives: '14 E89 sDrive3.5is
As someone that keeps looking for this type of upgrade for both aesthetics and/or performance - this is awesome guys, thanks. I'd also be interested in knowing what the performance improvement would be - if possible it would be nice to see some 60-0 stopping distances of stock vs. upgrade.
Personally I'm mainly interested in the realm of the 35is and in an option that would not cause the bypass of the e-brake.
      03-07-2015, 12:39 PM   #12
italy3541
italy3541's Avatar
58
I will be looking into the rear brake/e-brake issue this week. Like I said don't hold ur breath on a solution. I will do my best to try to figure out a way to retro fit it, but I am not sure if I will be able to. It all depends on how it actually is hooked into the rear brake caliper. But I will update If I find anything out.
EDIT: Its a no go on the rear brakes. After looking at it there would need to be a custom caliper designed to house the actuator that controls the caliper for the electronic brake.
      03-10-2015, 12:58 AM   #13
ForZ4
ForZ4's Avatar
Thanks for all your efforts and sharing your findings on this... silver lining: wife will be happy on the $$ not spent... for now.
      03-10-2015, 06:03 AM   #14
italy3541
italy3541's Avatar
58
No problem. I am still working on other options for the fronts. So far it seems most of the sport brakes on the 1/2/3 series will work on the E89. I will update as I find more.
      03-10-2015, 09:21 PM   #15
MTHuynh23
MTHuynh23's Avatar
45
Drives: 11 Z4 35i Atacama Yellow
The new M performance BBK kit bolts on no mods needed.
      03-11-2015, 03:50 AM   #16
italy3541
italy3541's Avatar
58
Thanks for the info. Do you have part numbers and a link so I can add it to the list?
      03-16-2015, 11:03 AM   #17
italy3541
italy3541's Avatar
58
Just a quick update. The brakes from the M235i work on our cars. I just got done installing a set on my car. It took 1 hour to put them on and bleed them. It is a true plug and play setup. Make sure to use 340mm x 30mm rotors with these brakes.
      04-26-2015, 09:15 AM   #18
pavproch
Drives: Z4 3.0i & 330ixT
As I wrote in the other thread, I probably (for sure, but my wife doesnīt know yet...) will be playing with the brakes of my Zet next winter...
As it comes to the rear setup, I will either leave current one in (300x24 mm OEM) or will have it replaced with 35is (324x20 mm) OEMīs components (I simply want to keep the e-brake functional).
Speaking of the fronts, that M235i Sport brakes (SH2NA) setup you built in attracts me a lot (other Performance BBK options mainly consist of 6pot calipers what seems to me a bit overkill for a mere - tuned though - 30i)...
Will you, please, share those M235i parts numbers you gave in? (I presume you went for slotted/holed rotors?)
And I happen to have several subsequent questions:
1. M235i calipers as you got them - were raw or painted? If the latter, which shade?
2. I suspect you left the current 35is caliper carriers (No. 34116773203) in, didnīt you?
3. Did you have to play with DSC settings afterwards (2pot in front instead of a single one)?
And there is one, rather disturbing thought I am having ref. front axle unsprung weight - that is what I am truly quizzical bout... as per ETK, my current OEM set (330x24mm) weights in total someting like 28kgs (60 pounds) inlc. caliper carriers. The M235i setup + 35is carriers (see question #2 above) might be weighting some 33.8 kgs (72 pounds), which means adding 6pounds per wheel of unsprung weight.... I gather this might compromise carīs driving /steering agility quite a bit...
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      04-26-2015, 06:29 PM   #19
ttuner
ttuner's Avatar
68
Drives: z4
Just bought these. they better fit!
      04-26-2015, 11:36 PM   #20
pavproch
As I wrote, 6pots do not grab me at all
      04-27-2015, 03:51 AM   #21
italy3541
italy3541's Avatar
58
I did not pain them. I left them the blue that they came with. There was no carrier bracket to unbolt as it is built into the caliper just like the stock unit. It was a simple unbolt old and rebolt new. I did not have to play with any settings on the DSC. It was a simple plug and play install.It took about a hour to do, I left the rear calipers stock and upgraded the rotors, I did not want to loose my ebrake. For rotors up front I went with Stoptec dimpled and slotted 340mm. For the rear the only option for the factory size was powerstop drilled and slotted. As for part numbers for the calipers, I never looked up what they were. A quick search should give you the numbers. I have some pics in my albums of the setup. Also the pics above of the blue M sport brakes are identical to the ones I put on. It looks like BMW uses the same brakes for the new 3 series and 2 series with the M sport packages.
      04-27-2015, 04:46 AM   #22
pavproch
Thanks for very useful info.
zpost
