10-20-2022, 08:45 AM | #1 |
Rep 404
Any experience with RevShift solid rear subframe mount bushings?
Want to do solid subframe mount bushings in the next year or so and leaning toward RevShift because FCP Euro sells them. It's not that I expect to have to return them for wear or anything; I just like to stick with FCP Euro on principle where possible.
Reviews on RevShift's other stuff seem to be... mixed. But I haven't seen any on their solid subframe mount bushings, and those seem like a really straightforward part. Anyone use this part and/or have any thoughts? Last edited by IamFODI; 05-27-2023 at 02:11 PM.. |
10-20-2022, 09:00 AM | #2 |
Rep 3,412
Go with solid aluminum, if you're pulling the subframe might as well do it once.
Not a Doctor, those are just my initials.
10-20-2022, 09:10 AM | #3 | |
Rep 404
https://www.fcpeuro.com/products/bmw...vshift-asb-e9x |
DRLane3996.00 |
10-20-2022, 09:52 AM | #4 | ||
Rep 3,412
10-20-2022, 10:32 AM | #5 |
Rep 404
10-24-2022, 12:44 AM | #7 |
Rep 120
I have these subframe bushings (2-piece aluminum) in my car. No noticeable difference between these and other E9X that I have driven with Turner or MRF bushings. I went with these because of the claims around "sandwiching" the subframe which I have no clue whether makes any difference at all. The important thing is it doesn't make noise.
IamFODI365.50 |
10-26-2022, 01:32 PM | #8 |
Rep 875
That look interesting and probably make installation easier. But from the pic, it doesn't look like the part inserted into the subframe are round? Maybe it's designed for easy of installation. Not sure if it has any long term effect?
05-27-2023, 10:51 AM | #10 |
Rep 404
Coming back to this as I'm planning to order soon.
I just emailed Revshift about e92zero's question and a couple more. We'll see what they say. For now, I'm kind of leaning toward another option like Bimmerworld. Hard to imagine Revshift knows more about how to build a product for this platform than Bimmerworld does. Let's see if Revshift comes back with anything potentially mind-changing. |
05-27-2023, 04:25 PM | #11 |
Rep 404
Wow. Got an amazingly fast answer – on a weekend, no less. Nice counterpoint to all the allegations of horrible customer service.
No, they're not round; yes, that's for easy installation, esp. in out-of-round bores. Apparently they provide 6 points of contact with the bore. On the "sandwich" aspect: they allege that one-piece designs can allow the subframe to move up to an inch vertically. Has anyone heard of that happening? If it were, wouldn't there be a lot of failures in short order as the steel subframe bores basically shredded the aluminum bushings? The fact that that's not happening makes me feel like it's not an issue. Maybe the "sandwich" aspect of the Revshift bushings was necessary because of the not-entirely-round 2-piece design – i.e., less-tight fit with fewer points of contact = more potential for movement. They also said the flange cutouts on all other designs are not functional, which is why their flanges go all the way around. Not sure how to reconcile that with TMS's instructions for their aluminum subframe bushings, which say you have to make sure the flanges are oriented correctly.... Revshift seems to be the only company making solid aluminum subframe bushings like this. AKG's offering is the only one I've seen that seems to be 2-piece, and they look round; all the others I've seen – Bimmerworld, TMS, Precision Works, CMP, etc. – are 1-piece and round. Makes me wonder if there's a reason... |
04-04-2024, 09:27 PM | #12 | |
Rep 2,145
Drives: 2011 E92 M3
Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
04-19-2024, 01:57 PM | #13 |
Rep 458
04-28-2024, 09:05 PM | #14 | |
IG: limited.slip
335
Rep 1,922
FWIW every solid mount I've installed (Bimmerworld, Turner, AKG, CMP) have a nice interference fit where the subframe moving over the mounts is definitely not an issue. |
05-06-2024, 07:07 AM | #16 |
Rep 5,804
That’s one way to market your two-piece hexagonal subframe bushing…scare everyone by telling them your subframe is going to move by up to 1” while driving, if you don’t use ours I’ll stick with BimmerWorld. Unless I missed them, I don’t recall ever reading a thread discussing not being able to press fit a cylindrical subframe bushing into circular holes in the subframe or threads talking about subframes falling of a car while cornering. Good job RevShift
