04-06-2023, 01:12 AM | #1 |
Rep 26
Solving EDC deterioration?
There have been many, many threads across multiple E9x M3 forums about EDC issues. I have read most of them, and copy in Mr Helmsman here Helmsman as he has been in most of them with good advice. Thank you sir.
I too have the deteriorating EDC problem. 2010 LCI E92 comp/ZCP with 85k miles and original Sachs EDC struts/shocks. Over the last year I have had the EDC suddenly revert to the stiffest setting, sometimes when the car is off and then turned on again, and sometimes while the car is running. No warning lights, no error codes. EDC button on the console lights up as usual. Often pulling and re-seating the front plugs on top of the struts would reset back to normal EDC operation (with some difference between modes, but not major) for a time. But in recent weeks it seems like there is nothing I can do to restore normal EDC operation – I seem to be stuck in firm setting forever. Still no warnings or codes. Logic (and reading all the many threads on EDC) suggests that this is probably a failed strut – 85k miles is a fair distance, and a deterioration over 12 months of on/off behaviour fits with this idea. I realise for others it may be other things. Can I please hear from any one who has had this issue and SOLVED IT. Did you get new OEM Sachs struts and get full EDC operation back? Did you fit new after market EDC compatible struts (eg B6 damptronic) and solve the problem? Did you fit either of those and STILL HAVE the problem? Thanks in advance. I feel it's time to focus on solutions to this issue, as there are plenty of people with the problem but no clear indication of how solvable it is. (And, yes, I do realise that replacing with Ohlins R/T and coding out EDC might just be the best solution)... |
04-06-2023, 09:22 AM | #2 |
Rep 7,129
Bravo, rarely see posts in the appropriate sub forums these days...
Any feedback will be interetsing to follow, lets see. Ps. DBTW did you read the one about resetting the aging compensation for chocks/module? Not suggesting that that would be an issue here but the topic is interesting, while getting around to buy a tool for the job... |
DrFerry6731.50 MrBlueSkies18.00 |
04-06-2023, 03:38 PM | #3 |
Rep 129
This is an interesting one for sure. My EDC is coded out, but I'm subbed to this for updates because I do have a friend that is experiencing this issue with his e90.
04-06-2023, 04:39 PM | #4 |
Rep 26
Yes, and I tried that function using my Foxwell reader/tool. It had no effect on the feel of the struts - they remained in the stiff setting. This makes me think that something in the EDC "system" is over riding the instructions from the EDC-K module. The most likely culprit is a failed strut, as I would have thought a failed acceleration sensor and/or broken cable would trigger a fault/code from the module. And a failed module would surely trigger a code. If the valve/solenoid in a strut is simply worn out, and not capable of responding to the signals from the the module, then they all default to the stiff setting. I don't know why, but that seems the most likely explanation. Hence why it would be good to hear from someone who has experienced this and had the problem solved by fitting new struts.
04-06-2023, 05:23 PM | #5 | |
Rep 466
MrBlueSkies18.00 |
04-08-2023, 10:32 AM | #7 | |
Rep 7,129
Although the spec says "individual damper control", the module control/separate between front and rear axel only. I.e. each damper has its own connection but the current output is the same to both front resp both rear. |
04-08-2023, 10:47 AM | #8 |
Rep 117
So there are 4 outputs from the edc module, one to each of the dampers? And is it in the front or rear right fender?
Do the cables from the edc module to the dampers unplug from the module or are they integral fly leads? Sorry for the thread hijack, will make sense in the future. No more questions after this post. Last edited by Adam M; 04-08-2023 at 11:17 AM.. |
DrFerry6731.50 |
04-08-2023, 11:34 AM | #9 | |
Rep 7,129
04-09-2023, 09:06 AM | #10 |
Rep 4,178
@Helmsman - May not be related to this post, but have you measured EDC amps/volts while the car is in motion? Is EDC adaptive based on road conditions, or is it a fixed damping based on the selected mode Comfort, Normal, or Sport?
DrFerry6731.50 |
04-09-2023, 03:29 PM | #11 | |
Rep 7,129
Cheers |
DrFerry6731.50 |
04-10-2023, 02:12 AM | #13 |
Rep 7,129
Here we are mate:
https://youtu.be/pgm0fi2F0r8 https://youtu.be/3ijwMphbwvs One video, straight driving without "loading" the dampers. Although there's no sensor that I know measuring load, believe acc.meeters and maybe steering angle input. The other video during "load" by steering back/forth. Module need 5km/h driving before it kicks start. |
DrFerry6731.50 |
04-10-2023, 07:18 PM | #15 | |
Rep 26
DrFerry6731.50 |
04-10-2023, 09:35 PM | #16 | |
Rep 7,129
My EDC changed years ago (had the car for 9y), already at around 25k miles so couldn't possibly be due to be worn out at that point. Originally it was a massive difference between Comfort and Sport. Anyways, learned to live with it... |
04-14-2023, 03:27 PM | #17 |
Rep 466
EDC test in ISTA Comfort/Sport?
Hi. Wanted to see if anyone else is seeing the same results with testing the EDC in ISTA. There is a EDC module test where you can confirm the status setting of the EDC when you push between Comfort-Normal-Sport.
What I wanted to confirm is: 1) When I have the EDC on Comfort (no lights on the EDC button), --> ISTA says Comfort 2) When I push it to one light on the EDC Button, which should be Normal --> ISTA says Sport 3) Then when I set the EDC Button to Sport, which is 2 lights --> the ISTA test says Comfort ??? I also ran a similar test in the Foxwell scanner and same phenomena happens. I'm a '08 non-ZCP M3. |
RocketyMan230.50 DrFerry6731.50 |
04-28-2023, 12:29 AM | #18 |
Rep 362
Drives: E53 X5, E83 X3, E93 M3
Interesting. I will need to investigate this as well!
+1 to using ISTA. ALWAYS appreciate the factory/dealer SW.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
DrFerry6731.50 |
01-14-2024, 03:18 PM | #20 | |
Rep 7,129
02-27-2024, 07:14 AM | #21 |
Rep 7,129
Quick update on the ProTool with regards to the EDC: While it seems like an extremely capable tool (vs for instance Carly) and include reset of various ECU adaptations, it turns out it doesn't support the EDC adapt.reset.
Had a mail chat with Bimmergeeks who immediately came back, confirming they currently didn't have the feature but they could see the shock adjuster function when looked specifically for it. Lets see what they possibly come back with. After recently measured the shock current again - which seems to have gone down a little = stiffening up - I'm eager to reset and see what happens incl measure again. |
pirategenes25.50 DrFerry6731.50 |
