BMW 2 Series Technical Topics (G42) Suspension / Brakes / Chassis
      10-09-2024, 10:35 AM   #1
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
NEW PRODUCT RELEASE: Dinan BMW G42 M240i xDrive Springs & Ride Quality and Handling
Dinan G42 BMW M240i xDrive Springs & Ride Quality and Handling Kit
Part Number(s): D100-0939 (Springs) & D193-0121 (Bumpstops)
Applications:
  • 2022-2024 BMW G42 M240i xDrive
Product Page(s) / Pricing: bit.ly/G42-SK
Release Date: Available Now!
Description: Suspension systems that not only transform the stance of the vehicle but also maintain ride quality and improve upon handling are what Dinan suspensions are known for. This is accomplished by pairing springs sets with bump stops spring perches or both to maintain suspension travel resulting in a smooth ride while also improving mechanical grip and handling. This is what makes Dinan suspension systems unique. While we are able to sell each component separately, it is highly recommended that both the spring sets and the supplemental ride quality and handling kits are used in tandem in order to maintain the Dinan quality standards our customers are used to. Experience the Dinan difference with this combination and enjoy the ride it provides.
Dinan's Performance Spring set for the BMW G42 M240i xDrive provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the car for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot-peened for stress relief to last the life of the car. The increase in stiffness will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip for high-speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle.
NOTE: Dinan Performance Spring sets should be purchased and installed with the corresponding Ride Quality and Handling Kit to achieve the advertised ride height performance and ride quality. While not explicitly required, if the matching component is not purchased and installed you will get less than favorable results in the form of poor ride quality and improper handling traits. While we will maintain a full warranty on product defects any claims against the cars improper handling ride quality traits due to not purchasing the corresponding handling kit will not be warranted.
Features/Benefits:
  • Vehicle lowered 7/8-inch (22mm) in the front and rear
  • 24% increase in spring stiffness in front and rear
  • Substantial reduction in body roll
  • Preset to prevent spring sag
  • Includes (2) front dual rate springs and (2) rear linear rate springs (Ride Quality and Handling Kit sold separately)
P_Chris168.50
      10-11-2024, 05:55 AM   #2
Jayphil
Jayphil's Avatar
107
Drives: 535I xdrive 2011 (M-SPORT)
I am looking for a moderate drop after this winter and retaining right quality is very important for me.
The other thing is that it seems our shocks blows much faster with lowering springs and since I have expensive adaptive dampers this concern me. My previous car ( BMW 535i 2011) and I had H&R spring for 10 years without issue but the drop is to low on the G42 vs what I am looking for.
I was planning on eibach springs but seems like this would be a great option for what I am looking for.
Now wondering does the spring rate of these higher or lower than eibach and how this affect the speed of shock degradation.
How the comfort and ride quality should be vs eibach .
Obviously you may not be able to answer but hopefully I will see customer feedback on these before the end of winter. Maybe to help how similar these are with the one on the G20 M340i, I could go read feedback there.
BMW 535I xdrive 2011 M-Sport with H&R Springs, Niche Form Wheels 8.5 ET35 / 10.5 ET35, Continental DSW06 245/35 & 285/30, JB4 Map 5, ER Downpipe, Megan Racing Quad Exhaust with Vibrant resonators, M5 Diffuser, Orange reflector shaved and removed xdrive badge.
      10-11-2024, 06:18 AM   #3
IanH
Drives: '25 M240xi
Perfect drop, just weighing if I want a fixed drop or the HAS from mss...
I feel like having a fixed drop and $900 in my pocket seems pretty good.
2025 M240i Xdrive TNM - Dinan Springs - CF Goodies - More in process
      10-11-2024, 04:11 PM   #4
Dinan_Engineering
Drives: Any BMW
Can't compare directly to Eibach obviously without some direct spring rate numbers and its hard to do a direct compare to the M340i as they use different style springs in the front in particular (dual rate vs linear) but the ending rates are similar between the two platforms. M240i is a hair stiffer on paper despite my feeling as a driver they feel a bit softer -- given its been quite awhile since I have been able to drive them back to back. Regardless, from a ride quality standpoint the M340i reviews should suffice as a point of reference.
Jayphil106.50
      10-15-2024, 02:43 PM   #5
rern
Drives: F33 435 Xdrive, G42 M240 RWD
Do these work on RWD m240i models?
      10-15-2024, 04:21 PM   #6
kudos
kudos's Avatar
244
Drives: BMW M240i
Is the Ride Quality and Handling Kit model D193-0121? If so it doesn't mention G42 on the website FYI.
E90
      10-15-2024, 04:21 PM   #7
Dinan_Engineering
Drives: Any BMW
Never had a RWD M240i in the shop to test so listed compatibility is specific for the xDrive at this time. If it follows the normal course though the xDrive springs would physically fit a RWD but the front springs specifically would not be ideal and likely be much too stiff on a RWD car and exhibit a reverse rake as a result.
      10-15-2024, 04:26 PM   #8
Dinan_Engineering
Drives: Any BMW
Yes, D193-0121. With how the data breaks up the primary headline for ACES/PIES data proliferation though the 2 series line gets cut off on our website. The sub-text headline still lists G42 at least. Known issue with products that have a diverse application list. =/
      10-15-2024, 04:28 PM   #9
kudos
kudos's Avatar
244
Drives: BMW M240i
My only other question is how many Dinan points does this get someone?
E90
      10-15-2024, 04:51 PM   #10
Dinan_Engineering
Drives: Any BMW
3 total between the springs (2) and bumpstops (1).
      12-06-2024, 01:51 PM   #11
kudos
kudos's Avatar
244
Drives: BMW M240i
How long are these expected to last for just a daily driver?
E90
      12-06-2024, 07:35 PM   #12
Dinan_Engineering
Drives: Any BMW
Somewhat depends on conditions (up north in winter with salt roads obviously will have some effect as an example) but regardless, they carry either a factory matching new car warranty (initial 4yr/50k warranty) and if its out of that it would have a 2 year/unlimited mile warranty -- whichever is longer.
That said, I know folks that have had the same Dinan springs on their car for 20+ years as well.
      12-28-2024, 11:03 AM   #13
kudos
kudos's Avatar
244
Drives: BMW M240i
Dinan_Engineering I just purchased both springs and handling kit. The springs are in stock but it says handling kit is backordered. Any idea when it will be back in stock and shipped?
E90
      12-29-2024, 03:53 PM   #14
megaman905
Drives: G42 M240
Does the ride quality and handling kit work with other lowering springs already installed by chance?
      12-30-2024, 01:42 AM   #15
Dinan_Engineering
Drives: Any BMW
2nd week of January, if not sooner, it appears.
Technically yes but keep in mind that bumpstops are an extension of the spring so mismatched rates between the spring and bumpstop will lead to some minor "inconsistencies" during the transition from spring to bump stop. The bump stops we sell are paired to match with our springs/rates whereas another manufacturer likely has a different rate (albeit still closer then stock bumpstops assuredly).
      12-31-2024, 08:55 AM   #16
IanH
Drives: '25 M240xi
This is my car with the Dinan Springs and Bump Stops. Before and after the best I could manage with my available before photos.
(If you click the picture you can see a higher resolution version)
I will post a review after I have some more driving time in. So far so good its a big improvement towards my goals for the car.
