BMW 2 Series Technical Topics (G42) Cosmetic Modifications (Exterior, Interior, Lighting)
      02-02-2022, 06:47 PM   #1
mblaucoupe135
Drives: 2022 M240i
rear fog lights
Does anyone know if the g42 comes with rear fog lights? On my f22, I was able to modify the light switch and code them so i could turn them on. Not that I really needed them very often but they are kind of cool.
      02-06-2022, 03:29 AM   #2
Dynamodux
Drives: Bmw m240i
I would suspect so, it's a requirement here in the uk to have fog lights
      02-11-2022, 03:28 PM   #3
Nicolas05
Nicolas05's Avatar
296
Drives: BMW g42 M240i
Off course it has… Here you go…
      02-11-2022, 03:52 PM   #4
mblaucoupe135
Drives: 2022 M240i
Originally Posted by Nicolas05 View Post
Off course it has... Here you go...
Awesome thank you! Now I just have to figure out how to turn them on in a US car!
      05-18-2022, 10:06 PM   #5
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
Where is the switch located?
      05-20-2022, 08:41 AM   #6
mburg
MBurg
mburg's Avatar
64
Drives: '22 230
If you look at the light switch cluster, you will see that there are two 'blank buttons' on the far left that you cannot depress. Photos of the light switch cluster on European models show one of these buttons has a fog light symbol. Based on experience with prior US models, likely you need to remove the switch cluster and take it apart so that you can cut off tabs on the button that keep it from being depressed. You would then need to code the car for rear fog lights, also as in past models.
      05-20-2022, 11:44 AM   #7
tubingchamp
tubingchamp's Avatar
111
Drives: 2023 G87 M2
Why do they exist, but are unable to be toggled on?
Is it automatic, like when you turn the wheel or something?
      05-20-2022, 12:21 PM   #8
Brett_C_F30_G42
Brett_C_F30_G42's Avatar
The front fog lights are automatic when you turn the wheel but you can't manually turn them on like the F chassis cars. It sucks
Miami Bimmer Club, member
SCCA, competition racer
2022 BMW M240i xDrive
Instagrams: bmw_2er_g42
      05-20-2022, 12:53 PM   #9
xcelir8bmw
xcelir8bmw's Avatar
I did the button tab thing and coded on my prior X2M35i.
But I was able to figure it out.
I need the coding info for this vehicle.
      05-20-2022, 12:55 PM   #10
tubingchamp
111
Drives: 2023 G87 M2
Ya, my wifes 22' S3 has the button for them as well..
No idea why they'd give you less options.. Even if they just included it into iDrive settings or something it would be fine. Lol
      05-20-2022, 09:20 PM   #11
MPR
MPR's Avatar
1951
Drives: 22 M240i
Are rear fog lights just the rear tail lights lit in the US? I don't see based on the pics above what you'd consider a rear fog light.
roho3323160.50
      05-21-2022, 04:46 PM   #12
blue135
Drives: 2008 135i Convertible. SRG Z4
Just for reference, earlier US BMWs required a change in the headlight switch (to the Euro version) to be able to add rear fogs. Sounds like later models have the switch already in place, just need lights, wiring and coding to make it work.
      05-22-2022, 06:30 PM   #13
allfitat55
Australia
124
Drives: 2022 M240i
2022 BMW M240i  [0.00]
If you look at the pic again you will see an extra light on the driver's side which is brighter than the DRL's that will be the Fog light it's generally brighter if not as bright as brake lights
      05-22-2022, 09:33 PM   #14
MPR
MPR's Avatar
1951
Drives: 22 M240i
Why is that desirable? It looks like the passenger side light is blown out and the owner didn't fix it
      05-23-2022, 03:34 AM   #15
allfitat55
Australia
124
Drives: 2022 M240i
In heavy fog conditions, the fog light is brighter than DRL or parkers whilst driving thus not being rear-ended in heavy fog.
      05-26-2022, 05:03 PM   #16
Zyvin
Drives: BMW 230i
I like this mod. I wish all U.S. cars had them. Of course then people would try to make both sides come on thinking it’s a defect, and defeat the purpose.
      05-27-2022, 12:01 PM   #17
xcelir8bmw
xcelir8bmw's Avatar
You can code both sides and I used this as a get off my ass light in my x2.
      05-27-2022, 04:18 PM   #18
allfitat55
Australia
124
Drives: 2022 M240i
I like the idea of both sides. I know mine has fog lights at the rear (AUS version) Not sure if it's one side or both. Do you know where to go to code this in Bimmercode?
      05-27-2022, 04:36 PM   #19
tubingchamp
111
Drives: 2023 G87 M2
Ohh, good call. Does it help?
I usually put hazards on for a couple clicks.. Have not noticed it helping yet.
      11-11-2023, 10:50 PM   #20
BlueLEDz
BlueLEDz's Avatar
222
Drives: 2023 BMW 230i
I know this is an old thread, but has anyone been able to confirm if the US spec G42 has the rear fog light LEDs installed?
      01-24-2024, 01:56 PM   #21
Saturns
Saturns's Avatar
175
Drives: G42,570GT,Lp5704STS,F36,F34
as per above... Did anyone figure this out? Do we actually have that bulb installed in that area and how do we turn it on. Thanks for any input.
      06-22-2024, 07:07 PM   #22
BadgerDog
BadgerDog's Avatar
Drives: 2017 BMW M2
2017 BMW M2  [9.96]
Bit of an old thread, but I stumbled into it looking for an LED replacement bulb for my F87. In case it's helpful to any of you here is a detailed thread on doing this with the F87 (all steps required including coding locations which might give you a clue for the G87):
https://f87.bimmerpost.com/forums/sh....php?t=1450178
As you can see, the switch is present (just disabled), the bulbs work, and are installed. Bare minimum required is to modify the switch and code in the option. I've done that and it works a treat.
Both sides light up on the F87. NO IDEA why that would defeat the purpose as was stated above in this thread. Seems better to me as it gives a sense of stereoscopic scale (how close you are). One side is better than none of course.
Also useful for flashing at tailgaters.
One thing I wasnt aware of before doing the mod: if your headlights are off, turning on any fog lights will turn on the headlights. So if you go to flash the rear fogs you may be flashing your headlights also...
Front fogs can also be manually toggled on with coding (might be linked to in that same thread) but for us at least its just a -slightly- brighter angel eye and is overall completely useless. Maybe you G87 guys have better lighting in that regard...
Hope this helps someone. Cheers.
