03-16-2024, 03:50 PM | #1 |
Rep 40
PDC iDrive 8 - no noise
Odd issue in iDrive 8 with PDC.
I’ve checked the audio for PDC is enabled and that the volume is turned up, but it never seems to make any noise. I’ve had it once where it made no sound until I was ~5cm from an object, and the rest of the time nothing. Is there some secret hidden setting I’ve missed somewhere? |
03-17-2024, 10:27 AM | #2 |
Rep 475
Drives: Yes
So I had the same thought as you and discovered something. When I’m backing out of my garage straight, there’s no noise, even though the garage door is in the “red” area of the sensor. However, if I turn the wheel so that the sensor detects that I would actually hit the door, it beeps. If I straighten the wheel, it goes quiet again. So I think the sound is more of a “if you keep going, you’ll hit something” rather than a general “you’re close to something” like in other cars.
Does that make sense? |
andrewr45.00 |
03-17-2024, 10:45 AM | #3 | |
Rep 40
